OLED Display lamda function read home assistant sensor
Hey,
I have a working config that i’m struggling to expand.
An oled screen is showing various img’s and mqtt values, rotating between pages.
The final page i’m adding has been stumped, im pulling in sensor data from home assistant (temp / hum) and looking to display it but im hitting issues, i believe with the data type.
I’ve tried chaning %s, %d and removing the .state.c_str() at the end of the line - all with varying levels of fail, none just pass the value which is currently 26.1.
Can anyone shed any light on how i should be pulling in this sensor data?
  - platform: homeassistant
    entity_id: sensor.4_in_1_multisensor_air_temperature
    internal: true
    attribute: state
    name: "Office Humidity"
    entity_id: sensor.4_in_1_multisensor_humidity
    internal: true
    attribute: state
text_sensor:
  - platform: mqtt_subscribe
    topic: oled1/notify
    topic: oled1/notify2
    topic: oled1/icon
font:
  - file: 'arial.ttf'
  - file: 'FontAwesome.ttf'
i2c:
  sda: D2
  scl: D1
  scan: True
time:
image:
  - file: "bell-regular.png"
    resize: 32x32
    type: TRANSPARENT_BINARY
  - file: "down-cloud.jpg"
    resize: 32x32
  - file: "plex.png"
    resize: 32x32
  - file: "down-cloud2.jpg"
    resize: 32x32
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x32"
    pages:
      - id: page1 # Plex currently viewing
        lambda: |-
          it.image(0, 0, id(plex));
          it.printf(38, 8, id(font1), "%s", id(oled1_text).state.c_str());
      - id: page2 # Home Assistant time / date
        lambda: |-
          it.strftime(0, 0, id(font1), "%H:%M", id(homeassistant_time).now());
          it.strftime(0, 16, id(font1), "%d.%m.%Y", id(homeassistant_time).now());
      - id: page3 # SabNZBd download rate
        lambda: |-
          it.image(0, 0, id(downcloud2));
          it.printf(38, 8, id(font1), "%s", id(oled1_text2).state.c_str());
      - id: page4 # Office Temp / Hum
        lambda: |-
          it.printf(0, 0, id(font1), "%s", id(officetemp).state.c_str());
          it.printf(0, 16, id(font1), "%s", id(officehumid).state.c_str());
interval:
  - interval: 15s
    then:
      - display.page.show_next: oled1
      - component.update: oled1
Build error:
/config/oled1.yaml: In lambda function:
/config/oled1.yaml:114:54: error: request for member 'c_str' in 'officetemp->esphome::homeassistant::HomeassistantSensor::<anonymous>.esphome::sensor::Sensor::state', which is of non-class type 'float'
  114 |           it.printf(0, 0, id(font1), "%s", id(officetemp).state.c_str());
/config/oled1.yaml:115:56: error: request for member 'c_str' in 'officehumid->esphome::homeassistant::HomeassistantSensor::<anonymous>.esphome::sensor::Sensor::state', which is of non-class type 'float'
  115 |           it.printf(0, 16, id(font1), "%s", id(officehumid).state.c_str());
*** [.pioenvs/oled1/src/main.cpp.o] Error 1
        lambda: |-
          it.printf(0, 0, id(font1), "%.1f", id(officetemp).state);
          it.printf(0, 16, id(font1), "%.1f", id(officehumid).state);
by changing to the above - %.1f instead of %s or %d, and removing c_str() now lets it build without error, but the display shows nan - for both entries (not a number).
Pretty sure this is down to the string or data type, but im clearly out of my depth.
        lambda: |-
ok got it :slight_smile:
Let’s break %.1f down:
  • % - initiate the format string
  • .1 - round the decimal number to 1 digits after the decimal point.
  • f - the specifier which tells printf the data type of the argument. Here it is a f(loat).
For example, if you would like to print a sensor value with two digits of accuracy, you would write %.2f and with zero digits of accuracy (without a decimal) %.0f.
Sometimes you just need to talk to yourself on a public forum to work stuff out :stuck_out_tongue:
You should mark post 3 as the solution. You’ll get brownie points for that!
I display the picture (file .png) on oled, but it not full. can you get me some advice, please, bros
Start a new topic. This is unrelated to the current topic. Give more details: see How to help us help you - or How to ask a good question
