can any one share there automation there some used with google geocode custom component. As I Testing and thinking its going to be good to use all the time
This is what I use now, works fine:
alias: Notify when someone enters or leaves a zone
description: ''
platform: state
entity_id: person.one, person.two, person.three, person.four
condition:
condition: template
value_template: "{{ trigger.from_state.state != trigger.to_state.state }}"
- service: notify.all_devices
data_template:
title: 'Location update {{ states.sensor.time.state }}'
message: "{{ trigger.to_state.attributes.friendly_name }} {% if trigger.to_state.state == 'not_home' %}has left {{ trigger.from_state.state }}{% endif %}{% if trigger.from_state.state == 'not_home' %}arrived at {{ trigger.to_state.state }}{% endif %}"
I use the android homeassistant app which generates various sensors, including the location etc.
- alias: 'Telegram - Whois it'
- platform: event
event_type: telegram_command
event_data:
command: /whois
- service: telegram_bot.send_message
data_template:
message: "{{ states('sensor.redmi_note_8_pro_geocoded_location') }}"
- service: telegram_bot.send_location
data_template:
latitude: '{{states.device_tracker.redmi_note_8_pro.attributes.latitude}}'
longitude: '{{states.device_tracker.redmi_note_8_pro.attributes.longitude}}'
you can customize the trigger as you like
Thanks for sharing this roumen! Works like a charm.
Just had to create a notify group for all_devices.
Is there a way to not notify the person that has the zone change of them zone changing as it adds an extra notification count?
Cheers
If you’re able to implement this without creating different groups I would be interested as well!
Thanks! Works perfect for me. You saved me a lot of time, now I don’t need to create many automations. One automations is enough for all zones and persons
Is this sill OK syntax?
I am not able to run this (changed persons and notification devices ofcourse).
Any help would be highly appreciated.
BR,
Gordan
the question is removed. everything works, just writes in debugging that the state has not changed.
Thanks to everyone in this thread!
My HA has many “zones”, walmart, crappy tire, grocery store, ect.
some zones are side-by-side and a person could go from zone to zone with no “not_home” , breaking some of the automation templates above.
I made some modifications to account for this, and added message “tag”, and clearing of previous /out of date location message
- platform: state
entity_id:
- person.person_1
condition:
condition: template
- service: notify.mobile_app_person_2
message: clear_notification
tag: location
data_template:
title: Location update {{ states.sensor.time.state }}
message: >
{% if trigger.to_state.state == 'not_home' %}has left {{trigger.from_state.state }}
{% else %}arrived at {{ trigger.to_state.state }}
{% endif %}
tag: location
results in messages:
TITLE: Location Update 17:25
MESSAGE: Person 1 has arrived at home
{clear previous message}
TITLE: Location Update 17:26
MESSAGE: Person 1 has left home
MESSAGE: Person 1 has arrived at walmart
TITLE: Location Update 17:27
MESSAGE: Person 1 has arrived at lowes
TITLE: Location Update 17:28
MESSAGE: Person 1 has left lowes
TITLE: Location Update 17:29
where do i put this code?
automation
what type of automation? Sorry im a newb…
that is not an error, just a warning that it is not possible to edit in gui, it is yaml only
This works so well it should be one of the default offered automations. This is perfect. I have struggled with various attempts throughout the years trying to nail down a proper location update. This works a treat, love that it deletes the old notifications too. Beautiful. Thank you.
This might be the most promising one I have seen yet. I put this in today and have only triggered 1 zone so far and it works. I’ve bookmarked this and will report back after some time.
Just to update I have created this Blueprint and it works like a charm. Just copy and paste this into a file (e.g. occupants_tracking.yaml) and save this file in config > blueprints > automation > homeassistant.
After that, you can use this Blueprint via Settings > Automations & Scenes > Blueprints
blueprint:
description: "This automation blueprint is designed to keep informed on your occupants whereabout. It will notify you when someone is back or left the home."
domain: automation
input:
person_entities:
description: "Choose from the list of 'person' entities to track"
selector:
entity:
domain: person
multiple: true
notify_service:
description: "Enter the Notify Service or script such as notify.telegram or notify.mobile_app_device_name to receive notification when the occupant is home or away."
default: "notify.telegram"
selector:
text:
mode: queued
max_exceeded: silent
variables:
person_entities: !input 'person_entities'
- platform: state
entity_id: !input 'person_entities'
to: 'home'
- platform: state
- service: !input 'notify_service'
message: >-
{%- set person = trigger.to_state.name -%}
{%- set new_state = 'back' if trigger.to_state.state == 'home' else 'away' -%}
{%- set people_home = states.person | selectattr('entity_id', 'in', person_entities) | selectattr('state', 'eq', 'home') | map(attribute='name') | list -%}
{%- set people_away = states.person | selectattr('entity_id', 'in', person_entities) | rejectattr('state', 'eq', 'home') | map(attribute='name') | list -%}
{{ person }} is {{ new_state }}. Right now, {{''}}
{%- set group = people_home if new_state == 'back' else people_away -%}
{%- set group_last = group[-1] if group|length > 1 else None -%}
{%- set group_list = group[:-1] | join(', ') -%}
{%- if group|length == person_entities|length -%}
everyone is {{ 'at home' if new_state == 'back' else 'away' }}
{%- elif group|length == 1 -%}
{{ person }} is the only one {{ 'at home' if new_state == 'back' else 'away' }}
{%- else -%}
{{ group_list }} and {{ group_last }} are {{ 'at home' if new_state == 'back' else 'away' }}
{%- endif -%}
Thank you for the master kenobi.
I was struggling a bit but the problem which i had is i named my notifyer my own telegram-username and tried to use notify.telegram… that doesnt work.
So now in my config.yaml i have the notifier named ‘notify.telegram’ and i can use it as default and as designed, way better.
Notifications look nice. Thank you!
