Yes you’ve replied before me
Will try that, thanks
Putting it all together here (with the typo corrected):
sensors:
open_windows:
entity_id:
- sensor.temperature_out
- sensor.temperature_in
value_template: >-
{%- set invalid = ['unknown', 'unavailable'] %}
{%- set outside = states('sensor.temperature_out') %}
{%- set inside = states('sensor.temperature_in') %}
{%- if outside not in invalid or inside not in invalid %}
{{ (outside | float + 0.5) > inside | float }}
{%- else %}
{{ states('binary_sensor.close_windows') }}
{%- endif %}
EDIT
The lion’s share of this thread has been to devise a means of mitigating the root-cause of this issue which was answered early in the thread.
Question: One automation triggered at each restart, why?
Answer: Because the automation’s trigger relies on resources that disappear moments before restart.
The true ‘fix’ is that the state of the sensors shouldn’t go from known to unknown moments before restart. The orderly shutdown of integrations should not cause the entity states to effectively be lost.
Unfortunately, resolving that is an architectural matter (and beyond the average user’s control) so what’s left is to create templates (or whatever) to detect and mitigate the issue when it arises. Basically, it’s a workaround.
I have tested the last code and if that code works, the automation is still triggered… I can see in the History tab that if the sensor is on before restarting, it goes off when restarting and then on again. If sensor is off before restarting, it goes on when restarting and then off again…
I’m wondering if last state is restored at boot for binary_sensor based on templates.
I’ve also tried to turn off the automation when event stop
is firing but it does not work.
Guess I need to less restart HA
Here is my last code:
- alias: Notification - Ouvrir les fenetres, fait bon dehors
initial_state: true
- platform: time_pattern
minutes: "/10"
condition:
- condition: template
value_template: >-
{% set outside = states('sensor.temp_out') %}
{% set inside = states('sensor.temp_in') %}
{{ (outside|float + 0.7) <= inside|float }}
- condition: state
entity_id: binary_sensor.temp_out_falling
state: 'on'
value_template: "{{ now().month >= 5 and now().month <= 9 }}"
- condition: state
entity_id: input_boolean.open_windows
state: 'off'
- condition: state
entity_id: group.all_person
state: 'home'
- service: notify.all
title: "Open"
message: "Windows!"
push:
sound: default
I solved my issue by triggering my automation every 10 minutes and the temp check is done in conditions
The Solution was posted a long time ago but you chose not to use it. Checking every 10 minutes is an inefficient workaround.
I have tested all the code that has been given here and I thank you all for your help but none worked. The code is fine and is completely logic but each time I restarted HA I got a notification because the automation was triggered (due to state being unknown for whatever reason). Even when using {{ states('binary_sensor.open_windows') }}
when one of the entity’s state is not a number.
I have concluded that a trigger with a template or a trigger with a binary sensor based on a template was not a good idea here. Even if it is not efficient, it now work really fine: I do not have anymore a notification when HA is restarted and it work as expected
