Sets the receiver on Airplay
onkyo --host 192.168.1.11 NSV18
Sets the receiver on Chromecast built in
onkyo --host 192.168.1.11 NSV40
Sets the receiver on DTS Play-FI
onkyo --host 192.168.1.11 NSV42
Turns on the receiver
onkyo --host 192.168.1.11 PWR01
Turns the receiver on Stand by
onkyo --host 192.168.1.11 PWR00
Gets if the receiver is on or off
onkyo --host 192.168.1.11 PWRQSTN
Mute on
onkyo --host 192.168.1.11 AMT01
Mute OFF
onkyo --host 192.168.1.11 AMT00
Gtes if the Mute is on or off
onkyo --host 192.168.1.11 AMTQSTN
Gets the Volume Level
onkyo --host 192.168.1.11 MVLQSTN
Sets Volume Level at:
onkyo --host 192.168.1.11 MVLxx where xx is a number from 00 to 82
Checks for new firmware
onkyo --host 192.168.1.11 UPDQSTN
Responses: UPD00 = Not new firmware, UPD01 New Firmware
Checks Firmware version
onkyo --host 192.168.1.11 FWVQSTN
gets temperature in C° and F°
onkyo --host 192.168.1.11 TPDQSTN
Note:
Reference Information:
[TX-NR474/NR575E/8270/NR575/NR676/NR676E/RZ620/NR777/RZ720/RZ820, DTM-7, DRX-2.1/3.1/4.1/5.1 VSX-832/932/LX102/LX302]
Yellow Zone: “F150C 66” or more & “F210C 99” or less
Red Zone:" F212C100" or more
[TX-RZ920, DRX-7.1/R1.1, DRC-R1.1]
Yellow Zone: “F176C 80” or more & “F246C119” or less
Red Zone: “F248C120” or more
I did not install the “eiscp” package. I am running haOS in a vm and easy_install or pip3 will not work.
However, the onkyo commands work just fine with shell_command so I’m assuming that the eiscp package is integrated with the onkyo integration added via the configuration.yaml file.
Works great. Thank you to all those that have posted info here and elsewhere.
The first 4 are self explanatory, the last one I used to create sensors to show the status of source and listening mode. Not sure if the port is needed in the script.
So, not to hijack the topic or anything…but, I’m running haOS 2022.9.7, and I’ve added my Integra DTR-30.4 receiver to my configuration.yaml.
It has been picked up by Home Assistant as a DLNA Media Renderer…and properly identified as an Integra DTR-30.4. But… I only have volume control. None of the onkyo commands work in terminal. And none of the media_player commands seem to do anything, when directed at the device. And I get a “not supported” error, when I point them at the entity.
Not sure exactly what I’m doing wrong. But this thread seems to indicate that others running haOS, have working onkyo commands, in the command line…and I don’t.
@ellingjs
I have the exact same thing happening with my ONKYO TX-NR626 right now.
I’m lost with all this talk of shell commands, and I would really just like a ‘Lovelace’ card that I can use and to be able to have automations.
As someone who isn’t well versed in any real programming languages and having to learn as I go, this is so frustrating!
I find it extremely frustrating, since Onkyo/Integra has a reasonably robust control app available…so, obviously the network control API is available and active in the unit. I just want to bring THAT control, into my Home Assistant instance, so everything is in one place and I’m not switching apps and have full voice control.
It’s like, the whole reason I bought the receiver, because support for Onkyo was supposed to be built in.
You don’t need any programming skills to get shell commands into HA. All the commands needed are already posted in this topic so it’s just a basic editing of configuration.yaml and placing a single executable file somewhere within the HA directory.
They can. Running successfully HAos with onkyo eiscp command line tool in the config directory. Easy as that. Samba< winSCP you have a myriad of options to do that
I was going through the same ordeal. While the onkyo command does exist in another part of the docker service, it was not available from my terminal window or config yaml file. I finally figured out you need to install it in your running environment (not sure why the other docker instance is some place else and unaccessible - I’m new to HA as well). That said, I resolved this by installing the onkyo command by:
go to your terminal window
at the prompt, type ‘pip install onkyo-eiscp’
It should go out and find some other necessary packages like: netifaces and docopt and then install them all. In the end, you should be able to type the onkyo command alone and get prompted on its proper usage.
hey folks,
anyone with a TX-NR6100?
I cannot seem to get it to switch to an airplay input. I can get it to ‘net’ which includes all the network inputs, but not airplay specifically.
I had the seme issue, it seams that it will detect what’s trying to communicate with it. I was trying to put Spotify, what I see is that I put t on net and just ask Spotify to connect to it and works.
try it and let us know if my assumption is correct.
