Only 1 LED stripe of 3 working - Limitlessled/MiLight Component V6 Bridge (iBox2)
Web interface says 8899. So what? It works on HA as shown in my config.
I did try this config but still only first zone is working… still wondering what is wrong that zone 2 and 3 do not work. On Android app all 3 zones are working fine…
Don’t change the box settings, the defaults work fine.
By “paired in the same way” I meant that you should use the same virtual remote (in the app) to do the pairing for all of them. HA is a bit picky and does not work with all of the remotes.
I will try to unlink all 3 zones and start again… also on linking procedure I will put alive (power ON) only 1 zone per linking proces to avoid some strange signal interferance…
I finally succeeded…
There was nothing wrong with pairing the lights, the problem was in configuration…
Somehow the only configuration which works for me is:
LimitlessLED - Home Assistant
light:
platform: limitlessled
bridges:
- host: 192.168.3.91
version: 6
groups:
- number: 1
type: rgbww
fade: on
- number: 2
type: rgbw
fade: on
- number: 3
type: rgbw
fade: on
But we must know, that all 3 light are the same… So rgbww should working, but works only rgbw on other two…
That is totally bizarre! Glad you found a solution.
