Hi @backslashv, thank you for helping!
The HA app has the permission to display over other apps, so that’s OK.
From the app logs:
--------- beginning of main
11-25 18:33:44.858 3258 15289 I System.out: [socket]:check permission begin!
11-25 18:33:44.866 3258 15290 I System.out: [socket]:check permission begin!
11-25 18:33:45.813 3258 15211 I SensorReceiver: Sensor updates and sync completed
11-25 18:34:35.803 3258 3258 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
11-25 18:34:40.094 3258 3273 I android.minima: Background concurrent copying GC freed 100339(4208KB) AllocSpace objects, 2(104KB) LOS objects, 49% free, 6013KB/11MB, paused 144us total 386.076ms
11-25 18:34:42.472 3258 3258 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@f23b678
11-25 18:34:42.668 3258 3258 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
11-25 18:34:43.594 3258 15247 I SensorReceiver: Sensor updates and sync completed
11-25 18:34:50.428 3258 3273 I android.minima: NativeAlloc concurrent copying GC freed 98235(4325KB) AllocSpace objects, 29(644KB) LOS objects, 49% free, 6197KB/12MB, paused 194us total 429.266ms
11-25 18:35:13.002 3258 3258 W android.minima: Accessing hidden method Landroid/view/WindowInsets$Builder;->setVisible(IZ)Landroid/view/WindowInsets$Builder; (blacklist, linking, denied)
11-25 18:35:13.007 3258 3258 W android.minima: Accessing hidden method Landroid/view/Window;->getInsetsController()Landroid/view/WindowInsetsController; (blacklist, linking, denied)
11-25 18:35:13.008 3258 3258 W android.minima: Accessing hidden method Landroid/view/WindowInsets;->isVisible(I)Z (blacklist, linking, denied)
11-25 18:35:13.009 3258 3258 W android.minima: Accessing hidden method Landroid/view/WindowInsets;->getInsets(I)Landroid/graphics/Insets; (blacklist, linking, denied)
11-25 18:35:13.009 3258 3258 W android.minima: Accessing hidden method Landroid/view/WindowInsets$Builder;->setInsets(ILandroid/graphics/Insets;)Landroid/view/WindowInsets$Builder; (blacklist, linking, denied)
11-25 18:35:13.010 3258 3258 W android.minima: Accessing hidden method Landroid/view/WindowInsets$Type;->systemGestures()I (blacklist, linking, denied)
11-25 18:35:13.011 3258 3258 W android.minima: Accessing hidden method Landroid/view/WindowInsets$Type;->mandatorySystemGestures()I (blacklist, linking, denied)
11-25 18:35:13.011 3258 3258 W android.minima: Accessing hidden method Landroid/view/WindowInsets$Type;->tappableElement()I (blacklist, linking, denied)
11-25 18:37:47.751 3258 3258 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
11-25 18:37:55.853 3258 3258 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@2b1606a
11-25 18:37:56.010 3258 3273 I android.minima: Background young concurrent copying GC freed 74506(4489KB) AllocSpace objects, 30(664KB) LOS objects, 37% free, 7728KB/12MB, paused 128us total 110.708ms
11-25 18:37:56.175 3258 3258 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
11-25 18:37:56.322 3258 4938 W IMGSRV : glGetString:4370: Override GL_RENDERER PowerVR SGX Clark
11-25 18:37:56.357 3258 4938 W IMGSRV : glGetString:4370: Override GL_RENDERER PowerVR SGX Clark
11-25 18:37:56.724 3258 3258 E WebviewActivity: Cannot set status bar color. Skipping coloring...
11-25 18:37:56.724 3258 3258 E WebviewActivity: Cannot set navigation bar color. Skipping coloring...
11-25 18:37:56.739 3258 15487 I System.out: [socket]:check permission begin!
11-25 18:37:58.861 3258 15216 I WebViewPresenterImpl: Found color -16537100.
11-25 18:37:58.866 3258 15216 I WebViewPresenterImpl: Found color -328966.
11-25 18:38:06.669 3258 3258 E MessagingService: Unable to send activity intent please check command format
11-25 18:38:06.669 3258 3258 E MessagingService: android.content.ActivityNotFoundException: No Activity found to handle Intent { act=android.intent.action.ASSIST flg=0x10000000 pkg=io.homeassistant.companion.android }
11-25 18:38:06.669 3258 3258 E MessagingService: at android.app.Instrumentation.checkStartActivityResult(Instrumentation.java:2058)
11-25 18:38:06.669 3258 3258 E MessagingService: at android.app.Instrumentation.execStartActivity(Instrumentation.java:1716)
11-25 18:38:06.669 3258 3258 E MessagingService: at android.app.ContextImpl.startActivity(ContextImpl.java:958)
11-25 18:38:06.669 3258 3258 E MessagingService: at android.app.ContextImpl.startActivity(ContextImpl.java:929)
11-25 18:38:06.669 3258 3258 E MessagingService: at android.content.ContextWrapper.startActivity(ContextWrapper.java:383)
11-25 18:38:06.669 3258 3258 E MessagingService: at io.homeassistant.companion.android.notifications.MessagingManager.processActivityCommand(MessagingManager.kt:1734)
11-25 18:38:06.669 3258 3258 E MessagingService: at io.homeassistant.companion.android.notifications.MessagingManager.handleDeviceCommands(MessagingManager.kt:703)
11-25 18:38:06.669 3258 3258 E MessagingService: at io.homeassistant.companion.android.notifications.MessagingManager.access$handleDeviceCommands(MessagingManager.kt:101)
11-25 18:38:06.669 3258 3258 E MessagingService: at io.homeassistant.companion.android.notifications.MessagingManager$handleMessage$4.invokeSuspend(MessagingManager.kt:425)
11-25 18:38:06.669 3258 3258 E MessagingService: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
11-25 18:38:06.669 3258 3258 E MessagingService: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:108)
11-25 18:38:06.669 3258 3258 E MessagingService: at android.os.Handler.handleCallback(Handler.java:883)
11-25 18:38:06.669 3258 3258 E MessagingService: at android.os.Handler.dispatchMessage(Handler.java:100)
11-25 18:38:06.669 3258 3258 E MessagingService: at android.os.Looper.loop(Looper.java:214)
11-25 18:38:06.669 3258 3258 E MessagingService: at android.app.ActivityThread.main(ActivityThread.java:7405)
11-25 18:38:06.669 3258 3258 E MessagingService: at java.lang.reflect.Method.invoke(Native Method)
11-25 18:38:06.669 3258 3258 E MessagingService: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:502)
11-25 18:38:06.669 3258 3258 E MessagingService: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:980)
11-25 18:38:06.709 3258 3258 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
11-25 18:38:16.319 3258 3258 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@4d152e1
11-25 18:38:16.409 3258 3258 E GraphicExt: GraphicExtModuleLoader::CreateGraphicExtInstance false
11-25 18:38:16.661 3258 15497 I System.out: [socket]:check permission begin!
11-25 18:38:16.661 3258 15498 I System.out: [socket]:check permission begin!
11-25 18:38:17.091 3258 3273 I android.minima: Background young concurrent copying GC freed 58776(2811KB) AllocSpace objects, 33(852KB) LOS objects, 30% free, 8547KB/12MB, paused 426us total 140.171ms
11-25 18:38:17.268 3258 15211 I SensorReceiver: Sensor updates and sync completed
So it’s that:
Is there something that is missing maybe or not correctly configured in my setup?
