Open/close door sensor (EV1527)
I know this is an old topic, but i hope someone can help me.
I try to get the doorsensor working, but i don’t know what goes wrong.
The goal is to turn on the light when door opens, en turn off when the door closes.
This is the code i added to configuration.yaml
# configuration for RFlink
rflink:
  port: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
logger:
  default: error
  # add the following to the existing logger section
  logs:
    rflink: debug
    homeassistant.components.rflink: debug
light:
  # add the following to the existing light section
  - platform: rflink
    automatic_add: true
  # add the following to the existing sensor section
  - platform: rflink
    automatic_add: true
binary_sensor:
  - platform: rflink
    devices:
      ev1527_0e0fb0_0a:
        name: Deur Hal Open
        off_delay: 1
      ev1527_0e0fb0_0e:
        name: Deur Hal Closed
        off_delay: 1
input_boolean:
  my_door_sensor_hal:
This is the code i added to automation.yaml
alias: update_my_door_sensor_hal
description: ""
  - platform: state
    entity_id: binary_sensor.deur_hal_open
    to: "on"
  - platform: state
    entity_id: binary_sensor.deur_hal_closed
    to: "on"
  - service: >-
      input_boolean_turn_{% if trigger.to_state.object_id.split('_')[2] ==
      '0a'%}on{%else%}off{%endif%}
      entity_id: input_boolean.my_door_sensor_hal
But how can i put on the light?
I added the following automation, but it doesn’t work
alias: lamp aan
description: ""
  - platform: state
    entity_id:
      - input_boolean.my_door_sensor_hal
    to: "on"
condition: []
  - service: light.turn_on
    data: {}
      entity_id: light.verlichting_hal_toilet
mode: single
I hope somebody can help me.
