Why? Describe in more detail pls
I’m sorry if I sound dumb but I’m pretty new with HA
my bad! I do have a device called “opemtherm gateway”.
to add the automation, I had to add them in “automation” menu rather than directly through the device. the “+” doesn’t do anything, same for the scripts.
The automation for the external temperature and internal are working fine.
What I would like to have and try to understand, is this scenario for instance:
Automatic temperature: everyday, from 7h30 until 22h30, temperature should be 19°c and outside this timeslot it should be 15°c.
Vacance scenario: I would like to have a button for the scenario “vacation” and force the temperature to 10°.
=> automatic temperature is the normal way until the “vacation” scenario is activated.
What I understand for this, the trigger would be time, “07:30:00”; if condition [I have created a sensor “vacances” which is “on” or “off”`] entity “sensor.vacances” = “off”.
but then, what would be the action?
Also, the other point I need to know is creating an automation will trigger the action only at the time defined. if at 9h00, I change the temperature to 20°, this temperature will stay until 22h30 and afterwards it’s the second automation starting and will change the temperature to 15°
So in otherwords, the automation will still be active. I’m pretty sure the answer is yes.
thanks for your time
The firmware has been successfully burned, but after ESP8266 is powered on again, it cannot search for Opentnerm’s WIFI signal. May I ask what is the situation
@pyromana firmware does not really have built-in schedules and modes (vacation/not at home/etc), because it is easier and more correct to do this using automation.
I think you could use the Schedule integration to set the temperature based on time and the Input boolean integration for vacation mode. These integrations can be created via a graphical interface. In this case, only one automation can be created. Example of automation (not tested):
alias: Set heating temp
description: ""
- platform: state
entity_id:
- schedule.work_time
to: "off"
- platform: state
entity_id:
to: "on"
- platform: state
entity_id:
- input_boolean.vacation
to: "off"
- platform: state
entity_id:
to: "on"
condition: []
- if:
- condition: trigger
id:
- work_time_off
- condition: state
entity_id: input_boolean.vacation
state: "off"
then:
- service: climate.set_temperature
entity_id: climate.opentherm_heating
temperature: 22
- if:
id:
- work_time_on
- condition: state
state: "off"
then:
temperature: 20
- if:
id:
- vacation_off
then:
temperature: 22
- if:
id:
- vacation_on
then:
temperature: 10
mode: single
@qiuliunian look at the logs via the serial port. Probably you flashed the wrong image or to the wrong address.
After burning the firmware, I couldn’t find Opentherm’s WiFi signal. This is my log. Could you please help me check where the error is
*************************** START ****************************
START TIME: 202408120902
CONNECT BAUD: 115200
set state: ESP_DL_SYNC
serial port opened
baud:115200
root baud:115200
===============BAUD : 115200===============CALL DEVICE SYNC
connecting…
0x3ff00050: 41720000
0x3ff00054: 02007e9f
0x3ff00058: c900b000
0x3ff0005c: 00500291
check_err_0: 0bcheck_err_1: 00check_err_2: 00check_err_3: 02check_err_4: 0b====================
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
EFUSE CHECK PASS…48bit mac
50 02 91 7e 9f 41CUSTOM_ID: 0C 90 00 00 00 07 20 00
MAC AP : 52-02-91-7E-9F-41
MAC STA: 50-02-91-7E-9F-41
get mac res: 1
get flash id : 0x001660c4
manufacturer_id: 0xc4
device_id: 0x6016
com closed
Use time: 0 s
Download result: PASS
*************************** END ****************************
serial port opened
baud:115200
root baud:115200
connecting…
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
get mac res: 1
device_id: 0x6016
Wrote 1024000 bytes at 0x00300000 in 6.6 seconds (effective 1250.3 kbit/s)…
Hash of data verified.
Leaving…
com closed
Use time: 8 s
START TIME: 202408120940
serial port opened
baud:115200
root baud:115200
connecting…
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
get mac res: 1
device_id: 0x6016
com closed
Use time: 1 s
serial port opened
baud:115200
root baud:115200
connecting…
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
get mac res: 1
device_id: 0x6016
Wrote 1024000 bytes at 0x00300000 in 6.5 seconds (effective 1250.9 kbit/s)…
Leaving…
com closed
Use time: 8 s
START TIME: 202408120955
serial port opened
baud:115200
root baud:115200
connecting…
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
get mac res: 1
device_id: 0x6016
com closed
Use time: 2 s
serial port opened
baud:115200
root baud:115200
connecting…
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
get mac res: 1
device_id: 0x6016
Wrote 1024000 bytes at 0x00300000 in 6.6 seconds (effective 1250.1 kbit/s)…
Leaving…
com closed
Use time: 8 s
@qiuliunian do you flash according to these instructions? I don’t see any information in your logs about writing to address 0x0 (firmware).
I am using ESP8266 and the input is 0x300000
The filesystem must be written to address 0x300000
, the firmware must be written to address 0x0
. Please read the instructions.
Do I need to burn both the file system and firmware into it
Yes, it is necessary
thanks !
so the service that need to be called is “climate.set_temperature”. I’ll see what I can do with an autoation using time as trigger.
I will mess up with HA and turn back once .
Boss, I have successfully burned it. Thank you very much. Can you add Chinese language
so i think i’ve managed, I’ve done it 5 automations but should work, I guess
automatic to 19°c during the day:
alias: on-auto-19°c
description: ""
- platform: time
at: "07:00:00"
condition:
- condition: state
entity_id: sensor.vacances
state: "off"
- action: climate.set_temperature
temperature: 19
mode: single
automatic to 15°c during the night:
alias: off-auto-15°c
description: ""
- platform: time
at: "22:30:00"
condition:
- condition: state
state: "off"
temperature: 15
mode: single
vacantion mode:
description: ""
- platform: time
at: "22:30:00"
condition:
- condition: state
state: "off"
temperature: 15
mode: single
when returning from vacation if during the day:
alias: retour-auto-19
description: ""
- platform: state
entity_id:
- sensor.vacances
to: "on"
condition:
- condition: time
after: "07:00:00"
before: "22:30:00"
temperature: 19
mode: single
when returning from vacation if during the night:
alias: retour-auto-15
description: ""
- platform: state
entity_id:
- sensor.vacances
to: "on"
condition:
- condition: time
after: "22:30:00"
before: "07:00:00"
temperature: 15
mode: single
I don’t speak Chinese, you can create a Chinese locale based on English and create a PR in the project repository on GitHub.
Boss, I failed to add a gateway using HA’s built-in OPENTHERM integration. The name I filled in was opentherm. Address filled in 192.168.0.5
After saving the wifi and mqtt settings on the device, the opentherm device will appear automatically in your home assistant. No need to use other integrations.
so, the different automation seems to work great. that’s a good news for me
I have a question. When the thermostatis is turned off, in the middle, above thetemperature, there is the word “idle” and when we turn it on, it changes to “heating”.
As I don’t have an AC and only the possibility to heat the house, I was wondering how to change this info depending on the flame status.
I would like to have the thermostat turned red when the status of thhe flame (I guess binary_sensor.opentherm_flame) is “true” and turn (blue or grey) when the status of the flame is “false”.
Would it be possile to let me know whether it’s feasible? thanks
edit: i have another question. in the thermostat, you have the big numbers, this is the temperature asked. but what’s the other temperature below? I think it’s “opentherm gateway heating temprature”. so i guess it’s the temperature of the water in the heating système. am i right?
thanks
If PID and/or Equitherm mode is enabled and hysteresis is enabled, the status changes:
- to idle if the firmware decides that there is no need heating home and the burner must be turned off;
- to heating otherwise.
Not all boilers report the flame status, so this is not a good solution for all.
This also depends on whether PID and/or Equitherm mode is enabled. If enabled, then these are the indoor temperatures: setpoint and current. If not enabled, then the coolant setpoint and current.
May I ask if these automation codes should be placed in automations.yaml or configuration.yaml
The code in GitHub is as follows
Before creating automation you need to go to Settings page, in the Indoor sensor settings sections change the parameters:
Source type: Manual
And save the settings. After that, you can create automation. The automation code can be copied from here. Before saving, you need to change the entity IDs:
The source sensor from which we take the temperature
source_entity: “sensor.livingroom_temperature”
Target entity number where we set the temperature
To report indoor temperature: number.opentherm_indoor_temp
To report outdoor temperature: number.opentherm_outdoor_temp
target_entity: “number.opentherm_indoor_temp”
The automation code can be pasted when creating automation via the graphical interface (three dots on the top right → edit in yaml)
