This is only for Equitherm and PID. Temporarily increases the temperature of the heat carrier until it reaches the target temperature - 1 degree temperature. This mode can be useful if you need to quickly increase the temperature in the house
Hello, I am not able to see the modulation level in mqtt, in the sensors it shows me the modulation level, but in home assistant it appears as unavailable even though I have it enabled.
I set my target temperature to 19°C indoor, with equiterm active N 1.2 indoor temperature mantain 18,5°. How can translate the curve up. Because if I set k value the heating temperature drop and the indoor temperature go down.
Why?
Ok, I can use templates and/or automation.
The question was: how can I switch on and off the heater by code through OpenThermGW and Open Therm heater interface ?
SOLVED !! I managed to use MQTT messages to switch on and off the heater.
Thank you anyway for your help.
I read the documentation, and I see the formula in the excel file for equiterm. It’s based on a standard indoor temperature of 20°.
N: paramenter is for pendence of curve for mantein an indoor temperature costant at different outdoor temperature.
K: is for translate the curve, but only for temperature target above 20°
Is not very clear…
For example if I set 19° for target, and I have 18°. With all value of K the target heating temperature is always lower. I don’t know.
Because the K result formula is =(J2 - 20) * H2
Is not possible to set negative value of K
For correction of the target temperature I think is better to set a new parameter offset for K:
@lucapretti in automations you can turn on and off the heating via climate.turn_on and climate.turn_off @edugarmu pls upload a screenshot from the Opentherm Gateway device page in HA.
p.s. you can upload several screenshots in one message to avoid flooding
