Hi
HA 0.100.2
I’ve created an Automation to periodically call the opentherm_gw.set_outside_temperature service. I can successfully set the outside temperature at the boiler with something like this:
temperature: 3.3
Good so far, but I’d like to set the value depending on a sensor value. Like this:
temperature: "{{ states('sensor.clientraw_temperature')|float }}"
However, I get the following error
2019-12-02 21:52:00 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.set_outside_temp. Invalid data for call_service at pos 1: expected float for dictionary value @ data[‘temperature’]
I can create a history graph of sensor.clientraw_temperature so I’m pretty sure that’s OK.
Also tried
temperature: "{{ (float(states.sensor.clientraw_temperature.state)) }}"
Same error. And various other syntax combinations.
Please could you suggest how/if I can get a variable substitution working in this service?
Many thanks. Pete
