Openweathermap daily forecast
Home Assistant already has Openweathermap support. There is a sensor component and there is a weather component. The weather component is a three-hour forecast for five days. Also, Openweathermap provides the API for a daily forecast for sixteen days. The daily forecast provides the minimum and maximum temperature for each day. This is needed for use in a custom weather state card. Perhaps someone will be able to remake the existing component from the hourly to the daily?
I was able to change the weather component myself. Forecast for 16 days. Here the code:
openweathermap_daily.py
Support for the OpenWeatherMap (OWM) service.
For more details about this platform, please refer to the documentation at
https://home-assistant.io/components/weather.openweathermap/
from datetime import timedelta
import logging
import voluptuous as vol
from homeassistant.components.weather import (
    ATTR_FORECAST_TEMP, ATTR_FORECAST_TIME, PLATFORM_SCHEMA, WeatherEntity)
from homeassistant.const import (
    CONF_API_KEY, CONF_LATITUDE, CONF_LONGITUDE, CONF_NAME, STATE_UNKNOWN,
    TEMP_CELSIUS)
import homeassistant.helpers.config_validation as cv
from homeassistant.util import Throttle
REQUIREMENTS = ['pyowm==2.8.0']
_LOGGER = logging.getLogger(__name__)
ATTR_FORECAST_CONDITION = 'condition'
ATTRIBUTION = 'Data provided by OpenWeatherMap'
ATTR_FORECAST_TEMP_LOW = 'templow'
DEFAULT_NAME = 'OpenWeatherMap daily'
MIN_TIME_BETWEEN_FORECAST_UPDATES = timedelta(minutes=30)
MIN_TIME_BETWEEN_UPDATES = timedelta(minutes=10)
MIN_OFFSET_BETWEEN_FORECAST_CONDITIONS = 1
CONDITION_CLASSES = {
    'cloudy': [804],
    'fog': [701, 741],
    'hail': [906],
    'lightning': [210, 211, 212, 221],
    'lightning-rainy': [200, 201, 202, 230, 231, 232],
    'partlycloudy': [801, 802, 803],
    'pouring': [504, 314, 502, 503, 522],
    'rainy': [300, 301, 302, 310, 311, 312, 313, 500, 501, 520, 521],
    'snowy': [600, 601, 602, 611, 612, 620, 621, 622],
    'snowy-rainy': [511, 615, 616],
    'sunny': [800],
    'windy': [905, 951, 952, 953, 954, 955, 956, 957],
    'windy-variant': [958, 959, 960, 961],
    'exceptional': [711, 721, 731, 751, 761, 762, 771, 900, 901, 962, 903,
                    904],
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
    vol.Required(CONF_API_KEY): cv.string,
    vol.Optional(CONF_LATITUDE): cv.latitude,
    vol.Optional(CONF_LONGITUDE): cv.longitude,
    vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
def setup_platform(hass, config, add_devices, discovery_info=None):
    """Set up the OpenWeatherMap weather platform."""
    import pyowm
    longitude = config.get(CONF_LONGITUDE, round(hass.config.longitude, 5))
    latitude = config.get(CONF_LATITUDE, round(hass.config.latitude, 5))
    name = config.get(CONF_NAME)
    try:
        owm = pyowm.OWM(config.get(CONF_API_KEY))
    except pyowm.exceptions.api_call_error.APICallError:
        _LOGGER.error("Error while connecting to OpenWeatherMap")
        return False
    data = WeatherData(owm, latitude, longitude)
    add_devices([OpenWeatherMapWeather(
        name, data, hass.config.units.temperature_unit)], True)
class OpenWeatherMapWeather(WeatherEntity):
    """Implementation of an OpenWeatherMap sensor."""
    def __init__(self, name, owm, temperature_unit):
        """Initialize the sensor."""
        self._name = name
        self._owm = owm
        self._temperature_unit = temperature_unit
        self.data = None
        self.forecast_data = None
    @property
    def name(self):
        """Return the name of the sensor."""
        return self._name
    @property
    def condition(self):
        """Return the current condition."""
        try:
            return [k for k, v in CONDITION_CLASSES.items() if
                    self.data.get_weather_code() in v][0]
        except IndexError:
            return STATE_UNKNOWN
    @property
    def temperature(self):
        """Return the day temperature."""
        return self.data.get_temperature('celsius').get('temp')
    @property
    def temperature_unit(self):
        """Return the unit of measurement."""
        return TEMP_CELSIUS
    @property
    def pressure(self):
        """Return the pressure."""
        return round(self.data.get_pressure().get('press'))
    @property
    def humidity(self):
        """Return the humidity."""
        return self.data.get_humidity()
    @property
    def wind_speed(self):
        """Return the wind speed."""
        return self.data.get_wind().get('speed')
    @property
    def wind_bearing(self):
        """Return the wind bearing."""
        return self.data.get_wind().get('deg')
    @property
    def attribution(self):
        """Return the attribution."""
        return ATTRIBUTION
    @property
    def forecast(self):
        """Return the forecast array."""
        data = []
        for entry in self.forecast_data.get_weathers():
            data.append({
                ATTR_FORECAST_TIME: entry.get_reference_time('unix') * 1000,
                ATTR_FORECAST_TEMP: round(entry.get_temperature('celsius').get('day')),
				ATTR_FORECAST_TEMP_LOW: round(entry.get_temperature('celsius').get('night'))
            if (len(data) - 1) % MIN_OFFSET_BETWEEN_FORECAST_CONDITIONS == 0:
                data[len(data) - 1][ATTR_FORECAST_CONDITION] = \
                     if entry.get_weather_code() in v][0]
        return data
    def update(self):
        """Get the latest data from OWM and updates the states."""
        from pyowm.exceptions.api_call_error import APICallError
        try:
            self._owm.update()
            self._owm.update_forecast()
        except APICallError:
            _LOGGER.error("Exception when calling OWM web API to update data")
            return
        self.data = self._owm.data
        self.forecast_data = self._owm.forecast_data
class WeatherData(object):
    """Get the latest data from OpenWeatherMap."""
    def __init__(self, owm, latitude, longitude):
        """Initialize the data object."""
        self.owm = owm
        self.latitude = latitude
        self.longitude = longitude
        self.data = None
        self.limit = 16
    @Throttle(MIN_TIME_BETWEEN_UPDATES)
    def update(self):
        obs = self.owm.weather_at_coords(self.latitude, self.longitude)
        if obs is None:
            _LOGGER.warning("Failed to fetch data from OWM")
            return
        self.data = obs.get_weather()
    @Throttle(MIN_TIME_BETWEEN_FORECAST_UPDATES)
    def update_forecast(self):
        """Get the latest forecast from OpenWeatherMap."""
        try:
            fcd = self.owm.daily_forecast_at_coords(
                self.latitude, self.longitude, self.limit)
            _LOGGER.error("Exception when calling OWM web API "
                          "to update forecast")
            return
        if fcd is None:
            _LOGGER.warning("Failed to fetch forecast data from OWM")
            return
        self.forecast_data = fcd.get_forecast()
2
Hello @Yevgeniy,
I tried your customer component but am getting an error saying that:
Your API subscription level does not allow to perform this operation
Reason: Invalid API key
Doesn’t your component support the free subscription model?
I thought it converted the 5 -day 3 hourly forecast into 5-day min-max forecasts?
My bad if I misunderstood :slight_smile:
Hello. If you have Home Assistant version 0.74 installed, you do not need to use the custom component to get the daily forecast. Just add it in the configuration.yaml:
weather:
  - platform: openweathermap
    api_key: YOUR_API_KEY
    mode: daily
I use Openweathermap with a free subscription and everything works fine. Please double-check your API key
daily mode (16 days weather forecast) NOT working with free accounts now. Only payed account.
https://openweathermap.org/price#weather
I think they cancelled the free subscription for the daily forecasts.
Only free one left is the 5-day 3-hourly forecast. Is there a way to convert that to 5-day min and max?
