Thanks, I will post in that issue!
I have just 1 week ago migrated from Domoticz to hass.io and I’m super happy, there are differences but the setup was super easy (running on VMware ESX) and it has been fairly easy to adjust.
I do have the problem that my Z-Wave (AEOTEC Z-Stick gen 5) is not working after reboot. So day 2 of me using HA I created a new virtual machine with the provided vmdk-file and everything was working great, I didn’t dare to reboot but just restarting HA-service works fine.
Yesterday I was fiddling around and I remember that there was an upgrade to downgrade some modules? I thought it might have been related to the issue with ZWave so I rebooted just to test. Unfortunately the problem occurred again… I get some different error messages but they are basically the same as already mentioned.
I tried the suggestion to remove the mosquitto.db (mine was at /mnt/data/supervisor/addons/data/core_zwave/mosquitto.db as mentioned by kmpm in the bug report comments).
at the same time, I also removed all the messages with MQTT Explorer.
after that I rebooted the system completely and then I got the familiar error messages in the logs:
[20200719 13:58:24.968 CEST] [ozw.library] [debug]: Debug - Node: 0 Value Deleted
[20200719 13:58:24.969 CEST] [ozw.library] [debug]: Debug - Node: 0 Value Deleted
[20200719 13:58:24.969 CEST] [ozw.library] [info]: Info - Node: 0 mgr, Driver for controller /dev/serial/by-id/usb-0658_0200-if00 removed
[20200719 13:58:24.969 CEST] [ozw.manager] [debug]: Driver Removed for "/dev/serial/by-id/usb-0658_0200-if00"
[20200719 13:58:24.969 CEST] [ozw.manager] [debug]: OZW Serial Port Closed
[20200719 13:58:24.969 CEST] [ozw.daemon] [info]: Shutting Down "ozwdaemon" Version: "0.1.0"
[20200719 13:58:24.969 CEST] [ozw.daemon] [info]: OpenZWave Version: "1.6.1198"
[20200719 13:58:24.969 CEST] [ozw.daemon] [info]: QT-OpenZWave Version: "1.2.0"
[20200719 13:58:24.969 CEST] [ozw.daemon] [info]: QT Version: 5.12.5
[20200719 13:58:24.980 CEST] [ozw.manager] [info]: New Client WebSocket Connection QHostAddress("::ffff:127.0.0.1")
[20200719 13:58:24.980 CEST] [ozw.notifications] [debug]: Notification pvt_ozwNotification NotificationTypes::Notification_Code_NoOperation Thread: 0x7f18ca6cdd48
[20200719 13:58:24.980 CEST] [ozw.notifications] [debug]: Notification pvt_nodeProtocolInfo 21 Thread: 0x7f18ca6cdd48
[20200719 13:58:24.980 CEST] [ozw.library] [critical]: Error - Node: 0 mgr, Manager::GetDriver failed - Home ID 0x00000000 is unknown
[20200719 13:58:24.980 CEST] [ozw.library] [warning]: Warning - Node: 0 Exception: Manager.cpp:410 - 100 - Invalid HomeId passed to GetDriver
[20200719 13:58:24.981 CEST] [ozw.notifications] [warning]: OZW Exception: Invalid HomeId passed to GetDriver at /usr/src/ozw/cpp/src/Manager.cpp : 410
[20200719 13:58:24.983 CEST] [ozw.manager] [warning]: WebSocket Client Error QAbstractSocket::RemoteHostClosedError
[20200719 13:58:24.983 CEST] [ozwadmin] [debug]: Remote Connection Status: QTOZWManager::ConnectionErrorState QAbstractSocket::RemoteHostClosedError
In exit
Terminating child 497
1595159905: mosquitto version 1.6.8 terminating
1595159905: Saving in-memory database to /data/mosquitto.db.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
Process Process-1:
File "/usr/lib/python3.8/multiprocessing/process.py", line 315, in _bootstrap
self.run()
File "/usr/lib/python3.8/multiprocessing/process.py", line 108, in run
self._target(*self._args, **self._kwargs)
File "/usr/lib/python3.8/site-packages/websockify/websockifyserver.py", line 691, in top_new_client
client = self.do_handshake(startsock, address)
File "/usr/lib/python3.8/site-packages/websockify/websockifyserver.py", line 619, in do_handshake
self.RequestHandlerClass(retsock, address, self)
File "/usr/lib/python3.8/site-packages/websockify/websockifyserver.py", line 99, in __init__
SimpleHTTPRequestHandler.__init__(self, req, addr, server)
File "/usr/lib/python3.8/http/server.py", line 647, in __init__
super().__init__(*args, **kwargs)
File "/usr/lib/python3.8/socketserver.py", line 720, in __init__
self.handle()
File "/usr/lib/python3.8/site-packages/websockify/websockifyserver.py", line 315, in handle
SimpleHTTPRequestHandler.handle(self)
File "/usr/lib/python3.8/http/server.py", line 429, in handle
self.handle_one_request()
File "/usr/lib/python3.8/site-packages/websockify/websocketserver.py", line 47, in handle_one_request
super(WebSocketRequestHandlerMixIn, self).handle_one_request()
File "/usr/lib/python3.8/http/server.py", line 415, in handle_one_request
method()
File "/usr/lib/python3.8/site-packages/websockify/websocketserver.py", line 60, in _websocket_do_GET
self.handle_upgrade()
File "/usr/lib/python3.8/site-packages/websockify/websockifyserver.py", line 221, in handle_upgrade
WebSocketRequestHandlerMixIn.handle_upgrade(self)
File "/usr/lib/python3.8/site-packages/websockify/websocketserver.py", line 87, in handle_upgrade
self.handle_websocket()
File "/usr/lib/python3.8/site-packages/websockify/websockifyserver.py", line 259, in handle_websocket
self.new_websocket_client()
File "/usr/lib/python3.8/site-packages/websockify/websocketproxy.py", line 134, in new_websocket_client
self.do_proxy(tsock)
File "/usr/lib/python3.8/site-packages/websockify/websocketproxy.py", line 209, in do_proxy
ins, outs, excepts = select.select(rlist, wlist, [], 1)
File "/usr/lib/python3.8/site-packages/websockify/websockifyserver.py", line 683, in do_SIGTERM
self.terminate()
File "/usr/lib/python3.8/site-packages/websockify/websockifyserver.py", line 656, in terminate
raise self.Terminate()
websockify.websockifyserver.WebSockifyServer.Terminate
s6-svwait: fatal: supervisor died
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
so, unfortunately, it didn’t work. I have also tried the same procedure and just start the openszwave service.
any comments or suggestions are more than welcome! I really do like HA, as long as it works!
Installed the Mosquitto broker thru Supervisor, bridged to my local Mosquitto server, and updated OpenZwave to 0.5.2, and now all my devices are showing up
Changelog:
0.5.2
* Fix startup failure due to stray OZW Daemon status retained in MQTT
* Propagate shutdown OZW Daemon status to upstream MQTT on shutdown
* Update OpenZWave to 6cf3729
I’ve been noticing a lot of lag since updating to 0.5.2. For example, I set a light to 50%, it’ll take 5-10 minutes to dim up to that level and vice versa when turning off. Has anyone else been experiencing the same?
that’s not lag, the default transition time was changed.
Thanks for that clarification, I was driving myself crazy. Hopefully an update is released soon!
Does anyone know when this update will be released? I’m having the issue with all of my NZW30T and NZW31T Inovelli switches.
Slated for 0.114 from what I understand but in the meantime check my post here to use that piping fresh code.
Hi all, I have an issue after the last update and I am not able to start the add-on anymore. Maybe some one can turn on a light at the end of the tunnel for me.
This is the output of the add-on. But it is beyond my knowledge and I don’t know where to start the troubleshooting. Can you please take a look?
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] auth.sh: executing...
[14:35:51] INFO: Auth database exists
[cont-init.d] auth.sh: exited 0.
[cont-init.d] mqtt.sh: executing...
[14:35:54] INFO: Connected to internal MQTT service
[cont-init.d] mqtt.sh: exited 0.
[cont-init.d] network_key.sh: executing...
[cont-init.d] network_key.sh: exited 0.
[cont-init.d] novnc.sh: executing...
sed: /usr/share/novnc/vnc_lite.html: No such file or directory
[cont-init.d] novnc.sh: exited 1.
[cont-finish.d] mqtt.sh: executing...
[14:35:55] INFO: Ensure upstream MQTT server has the correct OZW status
[cont-finish.d] mqtt.sh: exited 0.
Thank you
see here…
10x sender
My supervisor is reporting this after I tried updating:
20-09-17 13:39:42 INFO (SyncWorker_2) [supervisor.docker.interface] Clean addon_core_zwave application
20-09-17 13:39:45 INFO (SyncWorker_2) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-zwave with version 0.6.0
20-09-17 13:40:15 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with core_zwave!
And OZW reports:
[15:42:01] INFO: Ensure upstream MQTT server has the correct OZW status
Then trying again
I believe a fix was just pushed for the VNC issue as 0.60, I tried to update, but then failed and 0.60 no longer showing up. However looks like fix is inbound.
after all the tries to get OZW 0.6.0 to work, i gave up and reloaded OZW 0.5.2 from the add-on store and all my devices started working again except the VNC OZW-admin GUI. Starting it opens the background screen with the word “loading” at the top. tried restarting many different ways and times to no avail. Then i hoped the upgrade of HA to 115 would work a miricle. No such luck. Still says “loading”. The web version of OZW-admin works fine just not the embedded GUI . any ideas?
