Has anyone with the PVS6 update noticed that the telemetry websocket no longer publishes? I was taking advantage of its update rate to handle some battery charging automations I had for a separate battery system and a few days after I got the upgrade I stopped getting any data over it.
? for what in the engergy dashboard
Oh, I didn’t describe it well enough. You don’t need to create a template sensor to add up all the panel’s lifetime energy productions to get the total solar lifetime production. It is already available in the meter_pvs6…p_net_lifetime_energy sensor.
But you do if you want solar today and the other sensors like utility and solar combined now use and other things like that
But if you don’t make sensor what do you put in the enger dashboard for the solar settings? All the inverter yes that would work …
I made my own combined sensor for all the inverters and then a solar today sensor using other methods from that combined senso6
I just used the one net lifetime energy production sensor from the production meter for the solar production in the energy dashboard configuration. Then I created a template sensor for grid consumption and another template sensor for grid delivery to be used in the energy dashboard configuration.
Is the p Net Lifetime Energy just solar if so that is a terrible description because my thinking it’s both utility and solar and would not work in the solar section of the energy dashboard
And yes I had to make the grid consumption today and export to grid sensors for use in energy dashboard settings. Would have been nice if the intergration already had them
Yes. The p Net Lifetime Energy is just solar. I confirmed that it matches the solar lifetime energy from the previous legacy dl_cgi integration.
Yes after you mentioned i I tested and re configured some of my sensors to use it and removed my created. Custom sensors that did that gave the same results.
I just could not find any info at first on what entity to use for the solar in energy dashboard settings and was assuming that was a total of grid and solar because the name energy net.
