So first things first, you need to use the CODE tags </>
to format your code when posting it.
Secondly, how are you testing this? From INSIDE your own network?
Sorry I’m new in the forum. I’ve edited the script. And thanks for your help, pls don’t be mad with me.
No, I’ve tested from my inside own network and from my cellphone network.
I can’t enter from both network
Your code still doesn’t look right.
Are you sure you have port 8123 forwarded in your router to your home assistant machine?
You restarted after adding in the SSL settings in the configuration yaml?
When you try to browse using your internal ip address do you get a certificate warning?
Yes I’ve forwarded correctly
My ubuntu machine is static
Yes i get a warning the first time i’ve opened HA after this
And now it’s like this
and when i try to open from my duckdns domain I get this
also i tryed after rebooting ubuntu to be sure, but still nothing
If you wanna see something in particular just tell me
You need to use port 8123 to access from external…
Are you behind some Carrier Grade NAT?
On your router, is the EXTERNAL IP getting an IP address in the 10.x or 192.168.x or 172.x range?
Does it match up with your IP address if you go to http://ipchicken.com?
You are behind a Carrier Grade NAT. You cannot forward any ports, because your ISP is giving you a nonroutable private IP as your “WAN”.
Uff. So there is no way to avoid this? or another way to set Google assiatant? Because i want to use my google home to controll HA and have all in the google home app.
What kind of WAN ip i need to make this work?
You can try contacting your ISP, and see if you can get a public IP on the WAN
Okay, I will call it soon. I’ll tell you what they say to me.
Thanks really much for your patience and help
So, I just called my ISP and i can’t have a public IP on the WAN. I can have it only if i get a business contract.
I only need the Google Assistant integratoin, there is no other way to set GA with HA? Belong to the cloud of HA?
Maybe another cloud like Nabu but free or maybe trough IFTT
Nabu Casa is Home Assistant’s cloud option.
If you don’t have access to forward a port, that is your best option. You are HIGHLY unlikely to find that service for free, since it costs money to run the services that are required for that to work.
Just support the devs and pay for it.
Yeah i know it’s the best option and the easiest. So if I get Nabu casa I can use Google assistant even if I have a nat IP?
Yes, it creates an OUTBOUND connection to the cloud service and will tie it in with Google
Thanks, I will use Nabu Casa
Hello, I need help.
In my case Duckdns worked ok with HTTP.
From outside my network I access the normal application by cell phone, but when I try with HTTPS it doesn’t work.
On my router I have the directions below:
TKS!
