I use Hikvision, works like very well.
Hikvision here also, On-board Storage and WiFi.
Does anyone one has issues with insects? I got ctronics 720, they are not that bad, though the night vision attract all the flying stuffs around, and of course triggers the motion detectors. My wd cloud does not stop spinning to record… It s quite useless as an alarm.
Yep, my hikvision too. Wish for a solution
I sent back the ctronics. I am going to buy an ir projector (16$), but I have to find camera where I can turn off the ir. Do you usually use the motion detector?
How did your cameras work? It’s been hit and miss with stuff from BabgGood for me.
Hikvision can be turned off
Do you have Foscam in vlan?
Can Foscam access Internet?
What are you using for video storage/NVR?
Great cams but big network security hole(true for webcams in general). Not a problem if they are walled off from outside world (web accessible from HA or NVR only).
They are blocked from the internet using my Circle Device (they can’t get to internet) and then blocked on the firewall from the way in. They are also only external cameras.
I have a Synology NVR that I record to 24/7/30.
