Outdoor illuminance estimated from weather conditions
Yes, change:
    @property
    def should_poll(self):
        # For the system (i.e., EntityPlatform) to configure itself to
        # periodically call our async_update method any call to this method
        # during initializaton must return True. After that, for WU we'll
        # always poll, and for others we'll only need to poll during the ramp
        # up and down periods around sunrise and sunset, and then once more
        # when period is done to make sure ramping is completed.
        if not self._init_complete or self._using_wu:
            return True
        changing = 0 < self.sun_factor(dt_util.now()) < 1
        if changing:
            self._was_changing = True
            return True
        if self._was_changing:
            self._was_changing = False
            return True
        return False
to:
    @property
        return True
    @property
    def force_update(self):
        return True
Awesome, thanks! I just went ahead and changed the script, I’ll let you know if I see anything weird or not working properly.
As has been discussed, starting with HA 0.86, the folder layout in custom_components has changed. I’ve recently updated the installation instructions. custom_components.json (which is used by Custom Updater) has also been updated to be compatible with the new layout.
If you are installing this custom platform for the first time:
Then just follow the recently updated installation instructions
If you do not use Custom Updater, and are updating HA from before 0.86 to 0.86 or later:
Then you need to manually move/rename the file. The following Linux commands (or similar) should make the necessary changes:
# From config folder
cd custom_components
sudo -u homeassistant mkdir illuminance
sudo -u homeassistant mv sensor/illuminance.py illuminance/sensor.py
If you use Custom Updater, and are on a version of HA before 0.86:
Then you’ll need to update the following line in your configuration for custom_updater. Change:
  component_urls:
    - https://raw.githubusercontent.com/pnbruckner/homeassistant-config/master/custom_components.json
to:
  component_urls:
    - https://raw.githubusercontent.com/pnbruckner/homeassistant-config/master/custom_components_old.json
Once you update to HA 0.86 or later you should change it back.
If you use Custom Updater, and are on HA 0.86 or later:
Then you should be good to go. Just use the Custom Updater to install and/or update.
Note: You may need to clean up the old files after you install/update, if you care.
If anyone is wondering how to install this, the instructions are here . https://github.com/pnbruckner/homeassistant-config/blob/master/docs/custom_updater.md
Not sure if anyone else has upgraded to 0.89, but I did tonight and I’m getting this error:
Wed Mar 06 2019 20:41:44 GMT-0500 (Eastern Standard Time)
Error loading custom_components.illuminance.sensor. Make sure all dependencies are installed
  File "/usr/src/app/homeassistant/loader.py", line 166, in _load_file
    module = importlib.import_module(path)
  File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
  File "&lt;frozen importlib._bootstrap&gt;", line 1006, in _gcd_import
  File "&lt;frozen importlib._bootstrap&gt;", line 983, in _find_and_load
  File "&lt;frozen importlib._bootstrap&gt;", line 967, in _find_and_load_unlocked
  File "&lt;frozen importlib._bootstrap&gt;", line 677, in _load_unlocked
  File "&lt;frozen importlib._bootstrap_external&gt;", line 728, in exec_module
  File "&lt;frozen importlib._bootstrap&gt;", line 219, in _call_with_frames_removed
  File "/config/custom_components/illuminance/sensor.py", line 25, in &lt;module&gt;
    from homeassistant.components.sensor.yr import (
ImportError: cannot import name 'CONF_ATTRIBUTION' from 'homeassistant.components.sensor.yr' (/usr/src/app/homeassistant/components/sensor/yr.py)
I rolled back to 0.88.2 and everything was fine, so not sure what happened with YR.
You’re using a custom component. There’s a documented Breaking Change for custom components.
D’oh! I’ll try to fix that soon. Yet another ramification of the Great Migration.
EDIT: Hmm, this time it actually wasn’t the great migration. It was renaming CONF_ATTRIBUTION in sensor.yr to ATTRIBUTION, just like they did back in the 0.85 release with the Dark Sky Sensor.
Yeah, I’ve already changed the file structure, I have other custom components that are working fine, including @pnbruckner’s Life360 component. So I don’t think it’s that.
No worries man, was just hoping it wasn’t me. lol. Thanks for the great work you put into these components.
got the same error
ERROR (MainThread) [homeassistant.loader] Error loading custom_components.illuminance.sensor. Make sure all dependencies are installed Traceback (most recent call last): File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/loader.py", line 166, in _load_file module = importlib.import_module(path) File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module return _bootstrap._gcd_import(name[level:], package, level) File "&lt;frozen importlib._bootstrap&gt;", line 978, in _gcd_import File "&lt;frozen importlib._bootstrap&gt;", line 961, in _find_and_load File "&lt;frozen importlib._bootstrap&gt;", line 950, in _find_and_load_unlocked File "&lt;frozen importlib._bootstrap&gt;", line 655, in _load_unlocked File "&lt;frozen importlib._bootstrap_external&gt;", line 678, in exec_module File "&lt;frozen importlib._bootstrap&gt;", line 205, in _call_with_frames_removed File "/home/homeassistant/.homeassistant/custom_components/illuminance/sensor.py", line 25, in &lt;module&gt; from homeassistant.components.sensor.yr import ( ImportError: cannot import name 'CONF_ATTRIBUTION'
For latest release (just because I am not using it), it was required to disable the yr component integration
    CONF_ATTRIBUTION as YRS_ATTRIBUTION)
I was able to do that because I am using darksky.
This is the error in the logs I was facing:
2019-03-07 12:38:31 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.illuminance.sensor. Make sure all dependencies are installed
  File "/home/ha/homeassistant/lib/python3.6/site-packages/homeassistant/loader.py", line 166, in _load_file
  File "/usr/lib/python3.6/importlib/__init__.py", line 126, in import_module
  File "<frozen importlib._bootstrap>", line 994, in _gcd_import
  File "<frozen importlib._bootstrap>", line 971, in _find_and_load
  File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 678, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/home/ha/.homeassistant/custom_components/illuminance/sensor.py", line 25, in <module>
2019-03-07 12:38:31 ERROR (MainThread) [homeassistant.loader] Unable to find platform illuminance.
For some reason they decided to rename CONF_ATTRIBUTION to ATTRIBUTION in PR #21069. Working on a fix.
Released 2.0.2
Fixes problem caused by Yr Sensor change in HA 0.89 release.
Thank you very much! :slight_smile:
Just upgraded the component and then upgraded back to 0.89. No more errors. Thanks for the quick turnaround!
Can’t load the component due to problem with Dark Sky version 0.91
Yep. The Great Migration strikes again. :slight_smile: Luckily that’s now done.
See Issue #127, including a workaround until I can release a new version.
Released 2.0.5
Apparently HA 0.92 will require all custom components to have a manifest.json file. And the custom updater requires the component to have an __init__.py file to load other files. This release should work with 0.92 and the latest custom updater.
NOTE: Because of the reorganization, it’s possible the custom updater may not be able to simply update the component. You may need to install it again using the custom_updater.install service. You may want to get the latest version before updating to 0.92.
Released 2.1.0 in new HACS-compliant repo.
@pnbruckner you might want to edit your first post. Some of the links in it are broken since there have been changes.
