After trying a home waterproofed Miflora, then some Zigbee moisture sensors given the same treatment, I now use one of these: Soil Moisture Sensor - VH400
Good topic on reliable ESP32 boards:
ESPHome sensor calibration:
- platform: adc
pin: GPIO36
name: "Lawn Moisture Raw Voltage"
unit_of_measurement: "V"
device_class: voltage
attenuation: 11db
update_interval: 10s
name: "Lawn Moisture"
unit_of_measurement: "%"
device_class: humidity
state_class: measurement
lambda: |-
return (id(raw_v).state);
filters:
- calibrate_polynomial:
degree: 5
datapoints:
# Map from sensor -> true value
- 0.1 -> 0
- 0.2 -> 1
- 0.3 -> 2
- 0.4 -> 3
- 0.5 -> 4
- 0.6 -> 5
- 0.7 -> 6
- 0.8 -> 7
- 0.9 -> 8
- 1 -> 9
- 1.1 -> 10
- 1.2 -> 12.5
- 1.3 -> 15.004
- 1.4 -> 19.812
- 1.5 -> 24.62
- 1.6 -> 29.428
- 1.7 -> 34.236
- 1.8 -> 39.044
- 1.9 -> 42.118
- 2 -> 44.75
- 2.1 -> 47.382
- 2.2 -> 50.014
- 2.3 -> 52.646
- 2.4 -> 55.278
- 2.5 -> 57.91
- 2.6 -> 60.542
- 2.7 -> 63.174
- 2.8 -> 65.806
- 2.9 -> 68.438
- 3 -> 71.07
- sliding_window_moving_average:
window_size: 12
send_every: 12
send_first_at: 12
The raw voltage was just a sanity check I used to confirm my % moisture readings. You can omit it if you wish and just use:
- platform: adc
pin: GPIO36
attenuation: 11db
filters:
degree: 5
datapoints:
- 0.1 -> 0
- 0.2 -> 1
- 0.3 -> 2
- 0.4 -> 3
- 0.5 -> 4
- 0.6 -> 5
- 0.7 -> 6
- 0.8 -> 7
- 0.9 -> 8
- 1 -> 9
- 1.1 -> 10
- 1.2 -> 12.5
- 1.3 -> 15.004
- 1.4 -> 19.812
- 1.5 -> 24.62
- 1.6 -> 29.428
- 1.7 -> 34.236
- 1.8 -> 39.044
- 1.9 -> 42.118
- 2 -> 44.75
- 2.1 -> 47.382
- 2.2 -> 50.014
- 2.3 -> 52.646
- 2.4 -> 55.278
- 2.5 -> 57.91
- 2.6 -> 60.542
- 2.7 -> 63.174
- 2.8 -> 65.806
- 2.9 -> 68.438
- 3 -> 71.07
window_size: 12
send_every: 12
send_first_at: 12
