For me its the account page from my tahome on the somfy site
After an update from somfy the component donât work anymore
Logger: homeassistant.config_entries
Source: config_entries.py:1247
First occurred: 16:10:54 (2 occurrences)
Last logged: 16:11:05
Config entry âgateway-xxxx-xxxx-xxxx.local:8443â for overkiz integration not ready yet: Failed to connect; Retrying in background
What did you update? Your hub?
Tahoma v2 hub had an update last night
What is your firmware version? I just tried it on firmware: 2023.1.4-12 (TaHoma v2) and it still works like a charm.
Same as yours, but still canât connect. Worked fine till update.
C:\Users\hendr\Downloads\home-assistant_overkiz_2023-06-22T14-30-39.651Z.log (87 overeenkomsten)
Regel 20: 2023-06-22 16:04:11.256 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration overkiz which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
Regel 678: 2023-06-22 16:04:32.035 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {âhueâ, âsceneâ, âonboardingâ, âpersonâ, âdlna_dmsâ, âesphomeâ, âibeaconâ, âhomeassistant_hardwareâ, âpersistent_notificationâ, âenergyzeroâ, âlovelaceâ, âsynology_dsmâ, âandroidtv_remoteâ, âtraceâ, âsunâ, âshopping_listâ, âmin_maxâ, âdevice_automationâ, âhomeassistant_sky_connectâ, âpanel_customâ, âassist_pipelineâ, âscriptâ, âsensorâ, âutility_meterâ, ârest_commandâ, âhardwareâ, âmapâ, âsttâ, âshellyâ, âdsmr_readerâ, âinfluxdbâ, âble_monitorâ, âhacsâ, âblueprintâ, âhistoryâ, âzhaâ, âdlna_dmrâ, âtagâ, âtimerâ, ârestâ, âspotcastâ, âhardkernelâ, âffmpegâ, âtplink_decoâ, ânordpoolâ, âgoogle_fitâ, âtapo_controlâ, ârtsp_to_webrtcâ, âmyâ, âswitch_as_xâ, âinput_selectâ, âmobile_appâ, âwatchmanâ, âdenonavrâ, âcameraâ, âonvifâ, âsearchâ, âzoneâ, âinput_datetimeâ, âinput_buttonâ, âinput_textâ, âlocaltuyaâ, âupnpâ, âco2signalâ, âinput_booleanâ, âdevice_trackerâ, âcastâ, âlightâ, âdiagnosticsâ, âclimateâ, âconversationâ, âxiaomi_miotâ, âspeedtestdotnetâ, âscheduleâ, âwyomingâ, âroombaâ, âselectâ, âbraviatvâ, âapplication_credentialsâ, âpowercalcâ, âfritzâ, âwebrtcâ, âoverkizâ, âtuyaâ, ânfandroidtvâ, âsystem_healthâ, âmedia_sourceâ, âgroupâ, âotbrâ, âinput_numberâ, âhass_agentâ, âcounterâ, âalarmoâ, âenergyâ, âautomationâ, âstreamâ, âfile_uploadâ, âmotion_blindsâ, âhomeassistant_alertsâ, âconfigâ, âmqttâ, âgoogle_assistantâ, âpr_custom_componentâ, âshell_commandâ, âbodymiscaleâ, âbluetooth_adaptersâ, âgoogleâ, âauthâ, âthresholdâ, âcoverâ, ârepairsâ, âbuienradarâ, âbthomeâ, âanalyticsâ, âdefault_configâ, âlogbookâ, âmatterâ, âmidea_ac_lanâ, âttsâ, âthreadâ, âspotifyâ, âgoogle_assistant_sdkâ, âimage_uploadâ, âtemplateâ, âproximityâ, âradio_browserâ}
Regel 1756: 2023-06-22 16:04:41.894 INFO (MainThread) [homeassistant.setup] Setting up overkiz
Regel 1757: 2023-06-22 16:04:41.895 INFO (MainThread) [homeassistant.setup] Setup of domain overkiz took 0.0 seconds
Regel 1794: 2023-06-22 16:04:42.091 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 2390: 2023-06-22 16:04:55.569 WARNING (MainThread) [homeassistant.config_entries] Config entry âgateway-1232-5085-7745.local:8443â for overkiz integration not ready yet: Failed to connect; Retrying in background
Regel 2412: 2023-06-22 16:04:55.838 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=overkiz>
Regel 5289: 2023-06-22 16:05:18.448 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=binary_sensor.overkiz_pr_71644_update_available, old_state=None, new_state=<state binary_sensor.overkiz_pr_71644_update_available=on; device_class=power, friendly_name=Overkiz PR#71644 update available @ 2023-06-22T16:05:18.448280+02:00>>
Regel 5291: 2023-06-22 16:05:18.451 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.overkiz_pr_71644_last_update, old_state=None, new_state=<state sensor.overkiz_pr_71644_last_update=2023-06-10T14:38:58Z; device_class=timestamp, icon=mdi:update, friendly_name=Overkiz PR#71644 last update @ 2023-06-22T16:05:18.451317+02:00>>
Regel 5293: 2023-06-22 16:05:18.457 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.overkiz_pr_71644_auto_update, old_state=None, new_state=<state switch.overkiz_pr_71644_auto_update=off; icon=mdi:update, friendly_name=Overkiz PR#71644 auto update @ 2023-06-22T16:05:18.456966+02:00>>
Regel 43037: 2023-06-22 16:06:10.157 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 44170: 2023-06-22 16:06:23.270 DEBUG (MainThread) [custom_components.overkiz] ZeroConf discovery detected gateway --7745 on gateway-1232-5085-7745.local. (kizbox.tcp.local.)
Regel 44176: 2023-06-22 16:06:23.286 DEBUG (MainThread) [custom_components.overkiz] ZeroConf discovery detected gateway --7745 on gateway-1232-5085-7745.local. (kizboxdev.tcp.local.)
Regel 44221: 2023-06-22 16:06:24.012 DEBUG (MainThread) [custom_components.overkiz] DHCP discovery detected gateway --7745
Regel 46558: 2023-06-22 16:06:37.336 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 51313: 2023-06-22 16:07:12.532 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 53085: 2023-06-22 16:07:58.820 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 56125: 2023-06-22 16:09:25.428 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 59067: 2023-06-22 16:10:48.246 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 59330: 2023-06-22 16:10:54.382 WARNING (MainThread) [homeassistant.config_entries] Config entry âgateway-1232-5085-7745.local:8443â for overkiz integration not ready yet: Failed to connect; Retrying in background
Regel 59488: 2023-06-22 16:10:59.486 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 59798: 2023-06-22 16:11:05.650 WARNING (MainThread) [homeassistant.config_entries] Config entry âgateway-1232-5085-7745.local:8443â for overkiz integration not ready yet: Failed to connect; Retrying in background
Regel 59917: 2023-06-22 16:11:10.776 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 60512: 2023-06-22 16:11:27.099 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 60594: 2023-06-22 16:11:29.844 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=switch, service=turn_on, service_data=entity_id=switch.overkiz_pr_71644_auto_update>
Regel 60846: 2023-06-22 16:11:36.782 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=switch, service=turn_on, service_data=entity_id=switch.overkiz_pr_71644_auto_update>
Regel 61536: 2023-06-22 16:11:53.344 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 62570: 2023-06-22 16:12:21.212 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=switch, service=turn_on, service_data=entity_id=switch.overkiz_pr_71644_auto_update>
Regel 63155: 2023-06-22 16:12:39.853 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 64760: 2023-06-22 16:13:21.682 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=binary_sensor.overkiz_pr_71644_update_available, old_state=<state binary_sensor.overkiz_pr_71644_update_available=on; device_class=power, friendly_name=Overkiz PR#71644 update available @ 2023-06-22T16:05:18.448280+02:00>, new_state=<state binary_sensor.overkiz_pr_71644_update_available=unavailable; restored=True, device_class=power, friendly_name=Overkiz PR#71644 update available, supported_features=0 @ 2023-06-22T16:13:21.682033+02:00>>
Regel 64761: 2023-06-22 16:13:21.683 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.overkiz_pr_71644_last_update, old_state=<state sensor.overkiz_pr_71644_last_update=2023-06-10T14:38:58Z; device_class=timestamp, icon=mdi:update, friendly_name=Overkiz PR#71644 last update @ 2023-06-22T16:05:18.451317+02:00>, new_state=<state sensor.overkiz_pr_71644_last_update=unavailable; restored=True, device_class=timestamp, icon=mdi:update, friendly_name=Overkiz PR#71644 last update, supported_features=0 @ 2023-06-22T16:13:21.683407+02:00>>
Regel 64762: 2023-06-22 16:13:21.684 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.overkiz_pr_71644_auto_update, old_state=<state switch.overkiz_pr_71644_auto_update=off; icon=mdi:update, friendly_name=Overkiz PR#71644 auto update @ 2023-06-22T16:05:18.456966+02:00>, new_state=<state switch.overkiz_pr_71644_auto_update=unavailable; restored=True, icon=mdi:update, friendly_name=Overkiz PR#71644 auto update, supported_features=0 @ 2023-06-22T16:13:21.684680+02:00>>
Regel 64812: 2023-06-22 16:13:22.958 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=binary_sensor.overkiz_pr_71644_update_available, old_state=<state binary_sensor.overkiz_pr_71644_update_available=unavailable; restored=True, device_class=power, friendly_name=Overkiz PR#71644 update available, supported_features=0 @ 2023-06-22T16:13:21.682033+02:00>, new_state=<state binary_sensor.overkiz_pr_71644_update_available=off; device_class=power, friendly_name=Overkiz PR#71644 update available @ 2023-06-22T16:13:22.958366+02:00>>
Regel 64813: 2023-06-22 16:13:22.959 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.overkiz_pr_71644_last_update, old_state=<state sensor.overkiz_pr_71644_last_update=unavailable; restored=True, device_class=timestamp, icon=mdi:update, friendly_name=Overkiz PR#71644 last update, supported_features=0 @ 2023-06-22T16:13:21.683407+02:00>, new_state=<state sensor.overkiz_pr_71644_last_update=2023-06-10T14:38:58Z; device_class=timestamp, icon=mdi:update, friendly_name=Overkiz PR#71644 last update @ 2023-06-22T16:13:22.959654+02:00>>
Regel 64814: 2023-06-22 16:13:22.960 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.overkiz_pr_71644_auto_update, old_state=<state switch.overkiz_pr_71644_auto_update=unavailable; restored=True, icon=mdi:update, friendly_name=Overkiz PR#71644 auto update, supported_features=0 @ 2023-06-22T16:13:21.684680+02:00>, new_state=<state switch.overkiz_pr_71644_auto_update=off; icon=mdi:update, friendly_name=Overkiz PR#71644 auto update @ 2023-06-22T16:13:22.960663+02:00>>
Regel 65262: 2023-06-22 16:13:35.332 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=switch, service=turn_on, service_data=entity_id=switch.overkiz_pr_71644_auto_update>
Regel 66073: 2023-06-22 16:13:54.530 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=switch, service=turn_on, service_data=entity_id=switch.overkiz_pr_71644_auto_update>
Regel 66529: 2023-06-22 16:14:06.222 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 69478: 2023-06-22 16:15:32.428 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 72759: 2023-06-22 16:16:58.967 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 75936: 2023-06-22 16:18:25.236 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 78915: 2023-06-22 16:19:51.684 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 81953: 2023-06-22 16:21:10.596 INFO (MainThread) [homeassistant.components.analytics] Submitted analytics to Home Assistant servers. Information submitted includes {âuuidâ: âe09aebaae02e4872bd2db187a864644fâ, âversionâ: â2023.6.2â, âinstallation_typeâ: âHome Assistant OSâ, âsupervisorâ: {âhealthyâ: True, âsupportedâ: True, âarchâ: âaarch64â}, âoperating_systemâ: {âboardâ: âodroid-n2â, âversionâ: â10.3â}, âcertificateâ: True, âintegrationsâ: [âhueâ, âsceneâ, âwater_heaterâ, âhttpâ, âmedia_playerâ, âonboardingâ, âzeroconfâ, âupdateâ, âfanâ, âpersonâ, âesphomeâ, âdlna_dmsâ, âibeaconâ, âhomeassistant_hardwareâ, âpersistent_notificationâ, âenergyzeroâ, âweatherâ, âlovelaceâ, âsynology_dsmâ, âhomeassistantâ, âwebsocket_apiâ, âssdpâ, âwebhookâ, âandroidtv_remoteâ, âtraceâ, âusbâ, âsunâ, âremoteâ, âshopping_listâ, âmin_maxâ, âdevice_automationâ, âhomeassistant_sky_connectâ, âalarm_control_panelâ, âpanel_customâ, âassist_pipelineâ, âgoogle_translateâ, âscriptâ, âsensorâ, âutility_meterâ, ârest_commandâ, âhardwareâ, âmapâ, âsttâ, âtextâ, âshellyâ, âdsmr_readerâ, âvacuumâ, âinfluxdbâ, âblueprintâ, âhistoryâ, âzhaâ, âdlna_dmrâ, âtimerâ, âtagâ, ârestâ, âbluetooth_le_trackerâ, âcalendarâ, âhassioâ, âffmpegâ, âhardkernelâ, ârtsp_to_webrtcâ, âmyâ, âswitch_as_xâ, âinput_selectâ, ânumberâ, âmobile_appâ, âdenonavrâ, âcameraâ, âonvifâ, âsearchâ, âzoneâ, âinput_datetimeâ, âbluetoothâ, âinput_textâ, âinput_buttonâ, âupnpâ, âco2signalâ, âsirenâ, âinput_booleanâ, âdevice_trackerâ, âcastâ, âdiagnosticsâ, âlightâ, âclimateâ, âconversationâ, âapiâ, ânotifyâ, âspeedtestdotnetâ, âscheduleâ, âwyomingâ, âroombaâ, âselectâ, âbraviatvâ, âapplication_credentialsâ, âfritzâ, ânetworkâ, âlockâ, âtuyaâ, ânfandroidtvâ, âsystem_healthâ, âmedia_sourceâ, âgroupâ, âotbrâ, âinput_numberâ, âbuttonâ, âcounterâ, âenergyâ, âautomationâ, âhumidifierâ, âstreamâ, âfile_uploadâ, âmotion_blindsâ, âhomeassistant_alertsâ, âconfigâ, âmqttâ, âgoogle_assistantâ, âfrontendâ, âshell_commandâ, âcloudâ, âbluetooth_adaptersâ, âgoogleâ, âauthâ, âthresholdâ, 'log âŚ
Regel 82226: 2023-06-22 16:21:18.147 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 85571: 2023-06-22 16:22:44.717 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 88598: 2023-06-22 16:24:04.923 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 88746: 2023-06-22 16:24:11.054 WARNING (MainThread) [homeassistant.config_entries] Config entry âgateway-1232-5085-7745.local:8443â for overkiz integration not ready yet: Failed to connect; Retrying in background
Regel 88935: 2023-06-22 16:24:16.206 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 89596: 2023-06-22 16:24:34.337 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 90428: 2023-06-22 16:25:00.823 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 92125: 2023-06-22 16:25:47.056 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 94799: 2023-06-22 16:27:01.316 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.telefoon_marc_active_notification_count, old_state=<state sensor.telefoon_marc_active_notification_count=1; android.appInfo_nl.flitsmeister_1337=ApplicationInfo{784f094 nl.flitsmeister}, android.infoText_nl.flitsmeister_1337=null, android.largeIcon_nl.flitsmeister_1337=null, android.progressIndeterminate_nl.flitsmeister_1337=False, android.progressMax_nl.flitsmeister_1337=0, android.progress_nl.flitsmeister_1337=0, android.reduced.images_nl.flitsmeister_1337=True, android.remoteInputHistory_nl.flitsmeister_1337=null, android.showChronometer_nl.flitsmeister_1337=False, android.showWhen_nl.flitsmeister_1337=True, android.subText_nl.flitsmeister_1337=null, android.text_nl.flitsmeister_1337=Automatisch starten is actief, android.title_nl.flitsmeister_1337=null, nl.flitsmeister_1337_category=null, nl.flitsmeister_1337_channel_id=Flitsmeister-Autostart, nl.flitsmeister_1337_group_id=null, nl.flitsmeister_1337_is_clearable=False, nl.flitsmeister_1337_is_ongoing=True, nl.flitsmeister_1337_post_time=1687440646970, unit_of_measurement=notifications, icon=mdi:bell-ring, friendly_name=SM-G981B Active Notification Count @ 2023-06-22T16:07:00.727235+02:00>, new_state=<state sensor.telefoon_marc_active_notification_count=2; android.appInfo_nl.flitsmeister_1337=ApplicationInfo{14b1482 nl.flitsmeister}, android.appInfo_org.chromium.webapk.aefa89e30382a67d5_v2-1=ApplicationInfo{8dc13cd org.chromium.webapk.aefa89e30382a67d5_v2}, android.bigText_org.chromium.webapk.aefa89e30382a67d5_v2-1=What did you update? Your hub?, android.infoText_nl.flitsmeister_1337=null, android.infoText_org.chromium.webapk.aefa89e30382a67d5_v2-1=null, android.largeIcon_nl.flitsmeister_1337=null, android.largeIcon_org.chromium.webapk.aefa89e30382a67d5_v2-1=Icon(typ=BITMAP size=96x96), android.progressIndeterminate_nl.flitsmeister_1337=False, android.progressIndeterminate_org.chromium.webapk.aefa89e30382a67d5_v2_-1=Fa âŚ
Regel 95294: 2023-06-22 16:27:13.386 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 98507: 2023-06-22 16:28:39.633 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 101778: 2023-06-22 16:30:06.002 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 102531: 2023-06-22 16:30:26.074 DEBUG (MainThread) [custom_components.overkiz] CONFIGURING LOCAL INTEGRATION
Regel 102643: 2023-06-22 16:30:32.207 WARNING (MainThread) [homeassistant.config_entries] Config entry âgateway-1232-5085-7745.local:8443â for overkiz integration not ready yet: Failed to connect; Retrying in background
any progress on this, I would like to try local ?
This is not related to the integration probably⌠Did you configure the local integration via the direct IP address or the hostname (gateway-xxxx-xxxx-xxxx.local)? Are you sure you can access https://gateway-xxxx-xxxx-xxxx.local:8443/
from your browser? For my TaHoma Switch (which I use for development) I had so many issues where it would just go offline and not show up anymore, until a manual reboot (power cycle) of the hub.
Not really. This PR custom component is not provided by me, I already donât have enough time to focus on the development, so I definitely donât have time to provide alternative options. Currently is it in early development, thus more suited for technical users / developers.
Hopefully someone else in the community can figure out how to run the PR branch the easiest, and share that back here .
By the way, in the past people did share that they werenât sure if it would really run locally and that it didnât work when they disabled internet connectivity.
I just disabled the connectivity of my TaHoma v2 hub (via parental control), in the local installation I get a state event that my connectivity is offline and I can still control my devices! Cloud installation does not work anymore (as expected).
We are still far from a first release, but at least the functionality seems to be working.
got it working, found a GitHub issue here "Unable to process Pull Request Link." ¡ Issue #13 ¡ alandtse/pr_custom_component ¡ GitHub that covers it. Anyway got it all working locally, Thanks!!!.
I also have managed to get Open
/ Closed
status working in HA with RTS motors, with some helpers and Automations. If anyone would like I be happy to share.
got it working, found a GitHub issue here âUnable to process Pull Request Link.â ¡ Issue #13 ¡ alandtse/pr_custom_component ¡ GitHub that covers it. Anyway got it all working locally, Thanks!!!.
Would be good to do a PR to help others whom use this integration :).
For the testers of the local installation, I have made some (breaking!) changes to the local integration. Anyone that would help testing? It should fix (almost all) issues that have been reported before.
You will need to re add the entry for your hub in HA, since some things did change.
I have replaced my 10 year old Tahoma Box with a Somfy switch and can support testing?
Developer Mode is already active.
Please guide me a little bit how to setup the local integration. Is there something special which should be tested?
how does one update ?, do i have to repull using the PR integration ?
I donât know to be honest, have never used that PR component myself. I will try to update the startpost with some more info for testing, but we are at least closer to a release.
how do you do it, just replace files from your integration folder in github?
@imick I have just update the PR but, when \i sent to resetup as you said, I no longer see the local option ???
EDIT:
Ok, It seems you now have to select a server first, then you get the option of local or server.
@andyblac indeed, that is the biggest change . I see that the translations/strings in the config flow are not present via the custom PR integration, however that will be present in core.
Does everything function as expected?
