Overkiz integration - Local API [Development / Testers topic]
For the tahoma V2 you can click on the button … but no action is followed :upside_down_face:
All working fine over here :slight_smile:
I do seem to be getting lots of these errors in the log.
This error originated from a custom integration.
Logger: custom_components.overkiz
Source: helpers/update_coordinator.py:229
Integration: Custom Overkiz PR#71644
First occurred: 29 July 2023 at 14:17:58 (74 occurrences)
Last logged: 10:41:40
Error requesting device events data: Cannot connect to host gateway-2024-6137-2105.local:8443 ssl:default [Try again]
any ideas whats causing them ?, I also have an automation fail last night due to not beenable to close my bedrrom shade.
Logger: homeassistant.helpers.script.andys_bedroom_window_shade
Source: custom_components/overkiz/executor.py:91
First occurred: 2 August 2023 at 21:06:09 (1 occurrences)
Last logged: 2 August 2023 at 21:06:09
Andys Bedroom Window Shade: Error executing script. Unexpected error for call_service at pos 2: Cannot connect to host gateway-2024-6137-2105.local:8443 ssl:default [Try again]
  File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 1155, in _create_direct_connection
    hosts = await asyncio.shield(host_resolved)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 874, in _resolve_host
    addrs = await self._resolver.resolve(host, port, family=self._family)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/resolver.py", line 33, in resolve
    infos = await self._loop.getaddrinfo(
  File "/usr/local/lib/python3.11/asyncio/base_events.py", line 867, in getaddrinfo
    return await self.run_in_executor(
  File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/local/lib/python3.11/socket.py", line 962, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 468, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 703, in _async_call_service_step
    response_data = await self._async_run_long_action(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 665, in _async_run_long_action
    return long_task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1965, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2005, in _execute_service
    return await cast(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 235, in handle_service
    return await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 848, in entity_service_call
    response_data = task.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1192, in async_request_call
    return await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 892, in _handle_entity_call
    result = await task
  File "/config/custom_components/overkiz/cover_entities/vertical_cover.py", line 106, in async_close_cover
    await self.executor.async_execute_command(command)
  File "/config/custom_components/overkiz/executor.py", line 91, in async_execute_command
    exec_id = await self.coordinator.client.execute_command(
  File "/usr/local/lib/python3.11/site-packages/backoff/_async.py", line 151, in retry
    ret = await target(*args, **kwargs)
  File "/usr/local/lib/python3.11/site-packages/pyoverkiz/client.py", line 622, in execute_command
    response: str = await self.execute_commands(device_url, [command], label)
  File "/usr/local/lib/python3.11/site-packages/pyoverkiz/client.py", line 650, in execute_commands
    response: dict = await self.__post("exec/apply", payload)
  File "/usr/local/lib/python3.11/site-packages/pyoverkiz/client.py", line 846, in __post
    async with self.session.post(
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 1141, in __aenter__
    self._resp = await self._coro
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 536, in _request
    conn = await self._connector.connect(
  File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 540, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 901, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 1169, in _create_direct_connection
    raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host gateway-2024-6137-2105.local:8443 ssl:default [Try again]
Logger: homeassistant.components.automation.evening_sunset
Integration: Automation (documentation, issues)
First occurred: 2 August 2023 at 21:06:09 (2 occurrences)
Evening: Error executing script. Unexpected error for call_service at pos 1: Cannot connect to host gateway-2024-6137-2105.local:8443 ssl:default [Try again]
While executing automation automation.evening_sunset
    return await cast(
    return await coro
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/scene/__init__.py", line 114, in _async_activate
    await self.async_activate(**kwargs)
  File "/usr/src/homeassistant/homeassistant/components/homeassistant/scene.py", line 334, in async_activate
    await async_reproduce_state(
  File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 115, in async_reproduce_state
    await asyncio.gather(
  File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 109, in worker
    await platform.async_reproduce_states(
  File "/usr/src/homeassistant/homeassistant/components/cover/reproduce_state.py", line 125, in async_reproduce_states
  File "/usr/src/homeassistant/homeassistant/components/cover/reproduce_state.py", line 86, in _async_reproduce_state
    await hass.services.async_call(
    return await cast(
    return await coro
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/template/cover.py", line 358, in async_close_cover
    await self.async_run_script(self._close_script, context=self._context)
  File "/usr/src/homeassistant/homeassistant/helpers/template_entity.py", line 444, in async_run_script
    await script.async_run(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1569, in async_run
    return await asyncio.shield(run.async_run())
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 420, in async_run
    await self._async_step(log_exceptions=False)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 470, in _async_step
    self._handle_exception(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 493, in _handle_exception
    raise exception
    return await cast(
    return await coro
    result = await task
This means that your Home Assistant instance cannot connect to the gateway. Not sure where the connectivity issue is, but this is not something that I can fix…
However, I should try to see if we at least can retry on this error.
@andyblac, just pushed a new version that should at least better handle/retry these errors. You will still see these errors though if it cannot connect multiple times.
I just finished the last parts I had on my todo and also achieved 100% code coverage for Config Flow. This means that it is now ready for review by core members. If there is not a lot of feedback, it might ship next version already.
Please test the latest version, and let me know if it is still working stable.
Is there also something changed to prevent the unavailable state of the box?
Not sure. I haven’t faced this issues myself, thus it is hard to debug. However, if it is just a temporary connectivity issue, it could be fixed now. It will retry all commands a few times at least, and not directly raise an error.
It occurs at random times. Today till now it happens 4 times that all devices are unavailable.
But how does it work? Is it that when the integration is not answering every x seconds, HA gives unavailable? Or is it the local API controller that doesn’t give an answer or gives unavailable back?
Every update the entitie sensors change there name’s :slight_smile: now we are back to the original name’s.
Biggest problem is i have to update al my automations, and there are a lot, because i use the lightsensors not only for my sunscreens but also for my lights.
I hope this is the last time because we are close to the big release :slight_smile:
Do you also have entries in your history of covers that they are unavailable at certain times?
Please all try the latest version.
Is this with the latest version?
Nope all stabil and available the last 24h. only during the update of the software what is logical. Is it posibell to see if they are losing connection with the hub or if it’s a software isseu between your bridge and HA.
@imick I have just updated the local test version.So I will keep you informed about the issue if it is solved.
@marcje1968 what I mean is the history of a cover in Home Assistant:
Here you see the messages that the cover is unavailable at some times.
Ofcourse it could be my network, but on the same switch there is connected the Hue bridge and I don’t see unavailable messages of my hue lights.(My Tahoma Switch is connected with ethernet)
I know what you mean :slight_smile: that’s in HA. The screenshot i sent was from the somfy hub. The connection from my hub to ha is stable so i have no unavilibel messages :slight_smile: ( leuk allebei nederlands en maar engels lopen typen)
@imick i have just got the first unavailable message of my somfy devices since the latest version of the local api test version is installed.
Can you turn on debug mode? I wonder if there is anything in your log when it is unavailable.
Maybe it is my network if there is nobody else that has this messages?
Maybe i have to place it temporally on the same switch as Home Assistant.
What do you run Home Assistant on? The “Failed to connect.” error you see is caused by a ClientConnectorError in the underlying aiohttp library.
Home Assistant is running on a raspberry pi 4 8 gb
i’m seeing these too, since updating to latest PR.
First occurred: 7 August 2023 at 14:26:33 (20 occurrences)
Last logged: 06:18:22
Error fetching device events data: Failed to connect.
I have enabled debug loggin, so next time it happens, i’ll post the info.
