Dropping back from version 5 to 4 appears to bring back the thunderstorm asthma forecast.
I’ll update the main solution in a sec.
If poeple could keep an eye on it vs the webpage and let me know if they spot any issues that would be tops.
I’ve dropped in a fresh copy of my working lovelace config and added an update note to that solution post about whats going on (in summary, no clue, quite possibly my bad version management when i do slap-dash fixes.).
Thanks for letting me know. Hopefully it’s ok now for other users…
Just found this topic - what a great idea - have been struggling with pollen and storm asthma for a couple of weeks now, so will be interesting to see if I can correlate the forecasting with how I’m feeling - awesome bit of coding!
Yep definitely an annoying few days of extreme pollen conditions. Running my purifiers all day along with the split system with plasma filter. Helping to a degree. Maybe I should automate it based on the forecasts
that’s a little bit un-wife friendly in my house - we don’t have anything IOT in the bedroom aside from phones charging…
I’ve noticed that the REST call doesn’t always work reliably - aside from restarting HA, any other suggestions? Or is it that the service is exceeding number of polls maybe?
Are you able to share how you did the automations? I’m not sure how I trigger something from the API data as it’s not stored in discrete sensors. Unfortunately beyond my knowledge but keen to learn.
I ran out of characters in the main solution post so I’ll maintain these here.
These are excerpts from my more complex config so let me know if they don’t work)
Make some binary sensors in your config. You can use these as triggers in your automations.
binary_sensor:
#Create some binary sensors from the forecasts
sensors:
climate_alert_pollen_hayfever:
friendly_name: Pollen Alert Today
device_class: "problem"
icon_template: mdi:flower-pollen
#Adjust to set your own tolerances/thresholds
value_template: >-
states['sensor.melbourne_pollen_forecast_api'].attributes.melbourne_6day_pollen_forecast.days[0].pollen_level == 'Moderate'
or
states['sensor.melbourne_pollen_forecast_api'].attributes.melbourne_6day_pollen_forecast.days[0].pollen_level == 'High'
or
states['sensor.melbourne_pollen_forecast_api'].attributes.melbourne_6day_pollen_forecast.days[0].pollen_level == 'Extreme'
climate_alert_pollen_hayfever_tommorrow:
friendly_name: Pollen Alert Tomorrow
value_template: >-
states['sensor.melbourne_pollen_forecast_api'].attributes.melbourne_6day_pollen_forecast.days[1].pollen_level == 'Moderate'
or
states['sensor.melbourne_pollen_forecast_api'].attributes.melbourne_6day_pollen_forecast.days[1].pollen_level == 'High'
or
states['sensor.melbourne_pollen_forecast_api'].attributes.melbourne_6day_pollen_forecast.days[1].pollen_level == 'Extreme'
A script which triggers an announcment on my Google homes and posts to my homes Telegram thread. You can use something simlar with TTS etc.
pollen_report:
sequence:
#Announce Pollen today
- service: rest_command.assistant_broadcast
command: "The pollen forecast today is {{states.sensor.melbourne_pollen_forecast_api.attributes.melbourne_6day_pollen_forecast.days[0].pollen_level}}"
#Pollen 6 day outlook
command: >-
{{states.sensor.melbourne_pollen_forecast_api_6day_summary_stats.attributes.six_day_outlook_description}}
- service: notify.mothershiptelegramannouncements
title: "*Pollen Outlook*"
message: {{states.sensor.melbourne_pollen_forecast_api_6day_summary_stats.attributes.six_day_outlook_description}}
In my bedtime/arrive home scripts, turn on purifiers if pollen is alerting.
sleepmode_routines:
alias: Sleep Mode Routines
sequence:
##Pollen: Turn on Bedroom air purifier if pollen is alerting
- if:
or:
- "{{states.binary_sensor.climate_alert_pollen_hayfever.state == 'on'}}"
- "{{states.binary_sensor.climate_alert_pollen_hayfever_tommorrow.state == 'on'}}"
then:
- service: switch.turn_on
entity_id: switch.kogan_air_purifier_sleep_mode_2
command: "Turning on the bedroom air purifier for pollen"
day_time_routines:
alias: Activate Daytime Routines
sequence:
#Pollen
- if:
then:
- service: fan.set_percentage
entity_id: fan.mi_air_purifier_3_3h
percentage: 33
command: "Turning on the air purifier for pollen"
In an automation, set purifier fan speed depending on pollen level
I tried setting this up today but noticed the values returned from the API were inconsistent with those on the direct webpage (melbournepollen.com.au). That’s a little troubling, maybe their API is unreliable? I assume the main webpage data is correct and their undocumented API is acting weird.
Using Home Assistant’s native scrape integration, I was able to fetch the default grass pollen value for “VIC: Melbourne” from the top of the main webpage, and also the first thunderstorm asthma entry (which corresponds with “Central”).
I’m sure this will break if they change their website design, and it doesn’t provide the 6-day forecast or support different regions in Victoria. But for anyone in Melbourne looking for some simple sensors to perform automations from (eg. turn on air purifiers, open/close windows and so on), this might do the trick as an interim solution until they sort out their API.
- platform: scrape
name: "Pollen Forecast"
resource: https://www.melbournepollen.com.au/
scan_interval: 3600
select: "#inseason .pollen-level" # Primary grass pollen value, assumes "VIC: Melbourne" is the default selection
#select: "#district-pollen-div .forecast-value:first-child" # First regional pollen value, assumes "Central" is first entry
- platform: scrape
name: "Thunderstorm Asthma Forecast"
scan_interval: 3600
select: "#tae-div .forecast-value:first-child" # First regional thunderstorm asthma value, assumes "Central" is first entry
(The above is in the old config yaml format as I’m running an older HA install.)
