OK. If it’s still stuck, it may be due to something different than the original issue brought up here. In my case it used to print a lot of messages non-stop on the log file.
What browser are you using?
I’ve found sometimes the page doesn’t refresh and just needs a quick poke from a empty cache and reload.
Chrome. After empty and reload cache, no change.
fyi, it’s same on my mobile.
This happens everytime you restart HA?
Yes after each reboot
Have you tried running the following command: sudo systemctl disable ModemManager
root@homeassistant:/usr/share/hassio/homeassistant# sudo systemctl disable ModemManager
Failed to disable unit: Unit file ModemManager.service does not exist.
From your host machine not inside the docker.
Yes with ssh on my host
fyi, as indicated in the documentation I purge it with : sudo apt-get purge modemmanager
cf. “Platform specific instructions” in https://www.home-assistant.io/docs/z-wave/installation/
Does this happen to be running on a NAS like synology?
No, it’s Debian 10 VM on Proxmox
fyi, I reinstall modemmanager to test and OZW_Log.txt is more verbose …
But, my z-wave network work fine
You could try the zwave.stop_network
service from the Developer Tools -> Services menu and see if it stops the zwave stack. Your log will say it’s stopped and give you some network stats if it worked correctly.
OK, I purge again modemmanager for respect documentation …
I don’t have this service, just zwave.start_network. Nomal?
Normal if zwave hasn’t started fully. I suspect something is going wonky between your VM and the hardware.
why do you say that zwave hasn’t started fully?
Due to the fact that you’re missing the services stop_network
, heal_network
, etc.
OK, I restore old snapshot in HA 0.101.3, and I find all zwave services. Good steep
I try :
zwave.stop_network
2019-11-26 21:34:21.506 Info, mgr, Manager::WriteConfig completed for driver with home ID of 0xea97a9d0
2019-11-26 21:34:22.508 Info, mgr, Driver for controller /dev/ttyACM0 pending removal
2019-11-26 21:34:22.508 Detail, Notification: DriverRemoved
2019-11-26 21:34:22.508 Always, ***************************************************************************
2019-11-26 21:34:22.508 Always, ********************* Cumulative Network Statistics *********************
2019-11-26 21:34:22.508 Always, *** General
2019-11-26 21:34:22.508 Always, Driver run time: . . . 0 days, 0 hours, 10 minutes
2019-11-26 21:34:22.508 Always, Frames processed: . . . . . . . . . . . . . . . . . . . . 806
2019-11-26 21:34:22.508 Always, Total messages successfully received: . . . . . . . . . . 806
2019-11-26 21:34:22.508 Always, Total Messages successfully sent: . . . . . . . . . . . . 301
2019-11-26 21:34:22.508 Always, ACKs received from controller: . . . . . . . . . . . . . 301
2019-11-26 21:34:22.508 Always, *** Errors
2019-11-26 21:34:22.508 Always, Unsolicited messages received while waiting for ACK: . . 0
2019-11-26 21:34:22.508 Always, Reads aborted due to timeouts: . . . . . . . . . . . . . 0
2019-11-26 21:34:22.508 Always, Bad checksum errors: . . . . . . . . . . . . . . . . . . 0
2019-11-26 21:34:22.508 Always, CANs received from controller: . . . . . . . . . . . . . 0
2019-11-26 21:34:22.508 Always, NAKs received from controller: . . . . . . . . . . . . . 0
2019-11-26 21:34:22.508 Always, Out of frame data flow errors: . . . . . . . . . . . . . 0
2019-11-26 21:34:22.508 Always, Messages retransmitted: . . . . . . . . . . . . . . . . . 0
2019-11-26 21:34:22.508 Always, Messages dropped and not delivered: . . . . . . . . . . . 5
2019-11-26 21:34:22.509 Always, ***************************************************************************
2019-11-26 21:34:24.573 Info, mgr, Driver for controller /dev/ttyACM0 removed
2019-11-26 21:34:25.575 Error, mgr, Manager::GetDriver failed - Home ID 0xea97a9d0 is unknown
2019-11-26 21:34:25.577 Warning, Exception: Manager.cpp:373 - 100 - Invalid HomeId passed to GetDriver
2019-11-26 21:34:25.577 Info, mgr, GetSendQueueCount() failed - _homeId -359159344 not found
zwave.start_network
2019-11-26 21:37:13.535 Info, Setting Up Provided Network Key for Secure Communications
2019-11-26 21:37:13.535 Warning, Failed - Network Key Not Set
2019-11-26 21:37:13.535 Info, mgr, Added driver for controller /dev/ttyACM0
2019-11-26 21:37:13.536 Info, Opening controller /dev/ttyACM0
2019-11-26 21:37:13.536 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2019-11-26 21:37:13.540 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2019-11-26 21:37:13.540 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-11-26 21:37:13.540 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-11-26 21:37:13.540 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-11-26 21:37:13.540 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-11-26 21:37:13.540 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-11-26 21:37:13.541 Detail,
2019-11-26 21:37:13.541 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-11-26 21:37:13.544 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x35, 0x34, 0x00, 0x01, 0x93
2019-11-26 21:37:13.544 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2019-11-26 21:37:13.544 Info, contrlr, Static Controller library, version Z-Wave 4.54
2019-11-26 21:37:13.544 Detail, Node045, Expected reply was received
2019-11-26 21:37:13.544 Detail, Node045, Message transaction complete
2019-11-26 21:37:13.544 Detail, contrlr, Removing current message
2019-11-26 21:37:13.544 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-11-26 21:37:13.548 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xea, 0x97, 0xa9, 0xd0, 0x01, 0xd3
2019-11-26 21:37:13.548 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xea97a9d0. Our node ID = 1
2019-11-26 21:37:13.548 Detail, Node151, Expected reply was received
2019-11-26 21:37:13.548 Detail, Node151, Message transaction complete
And same
I’m in the process of converting from Smartthings to HA. I just installed Hass.io on a brand new Raspberry Pi 3b+ and am using a Nortek USB combo that has both Zwave and Zigbee. I’m using the web UI and was able to get the zwave portion of the USB stick added to HA. However that zwave network did not start and when I go to the network config, I see a message that the zwave network is stopped and a button to start it. When I click the start is just spins forever and never starts the zwave network. I rebooted the RP and after reboot the HA log shows:
EDIT: I was able to SSH to the server. The zwave and zigbee devices were not part of tbe dialout group and I made that change. However, the “homeassistant” user was not part of that group and does not appear to exist.
2019-12-01 21:53:23 WARNING (zeroconf-ServiceBrowser__esphomelib._tcp.local.) [zeroconf] Exception occurred:
File "/usr/local/lib/python3.7/site-packages/zeroconf.py", line 2245, in send
bytes_sent = s.sendto(packet, 0, (addr, port))
PermissionError: [Errno 1] Operation not permitted
2019-12-01 21:57:27 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave not ready after 300 seconds, continuing anyway
Any update on this issue? Seems to happen randomly after I restart
You’d need to post your OZW_Log.txt file, the first 10-20 lines would suffice.
