Paradox Alarm MQTT Hassio addon
In my experience, if there’s no log than the addon is working correctly. A couple things to try:
  1. Can you correctly see all your zones and alarm state when you log directly into your IP150S?
  2. Using this addon, use the webUI to subscribe to the topics you have defined and see if there’s any activity. If there is, then you defined your sensors wrong… If there’s not then you have a problem with the addon.
