I still have trouble setting this up.
Deleted ver.0.5, started from scratch, copy-pasted config from readme and replaced passwords/addresses.
No errors in log (which I assume means add-on connects both to mosquitto brocker and to the IP150s).
I can see the updates in the respective topics via MQTTLens.
alarm entity is in unknown state and pirs are constantly off
try typing them not copy and past. They format stuff up all my config.
My problems are definitely connected with the Mosquitto add-on Iām using.
I reinstalled the add-on from scratch last night, messing up the config with my sleepy fingers.
Today I found an error message per every IP150 PIR event.
I managed to fix the Mosquitto logging following instructions in this discussion, however Iām back to all PIR sensors being off.
Can you share which MQTT broker you guys are using?
Iām using this one:
MQTT Server & Web client
Mosquitto MQTT Server bundled with Hivemqās web client
Works good. Iām having a problem with the MQTT alarm panel not sending the appropriate messages, but the sensors work fine and Iāve verified I can arm/disarm by sending the requisite MQTT message manually to the MQTT server, so the MQTT server itself appears to be working perfectlyā¦
mosquitto addon as well
āloginsā: [
āusernameā: āXXXXXā,
āpasswordā: āXXXXXā
āanonymousā: false,
āquiet_logsā: true,
ācustomizeā: {
āactiveā: false,
āfolderā: āmosquittoā
ācertfileā: āfullchain.pemā,
ākeyfileā: āprivkey.pemā
I replaced my broker with āMQTT Server & Web clientā, re-configured from scratch.
I can currently subscribe to the paradox/zone/state/# topic from HiveMQ web client or mosquitto_sub and I can see the updates happening ā¦ off status for all (32) PIRs, on when something is triggered, etc.
None of this is reflected in the UI - Iām using the Lovelace GUI interface to seup my sensors.
I can manually flip one of the sensors publishing the āonā msg to the broker and only then is the status change visible in the GUIā¦
What else can I try?
Are you willing to try the Mosquito Broker HASSIO addon again, and put this in your config file?
āMQTT_ADDRESSā: āmqtt://core-mosquittoā,
My one didnāt work with an IP address, it had to be core-mosquitto in the URL
Failing this, depending on what timezone you are, I can try to assist you remotely if you like.
Iām going to look at doing this integration, has any more work / development been done this Jan 2018 posting.
do you maybe have some screen shots of a implementation,
MY system is split into 2 partitions, would like to group the sensors/zone into partitions and show door and window icons next to the zones.
ignore, some how i missed the 168 posts sinceā¦ hope my answer is in there some where
ā¦ so completed the reading, looks like i might have a issue, my system is running: 4.40.04
Please advise.
I did quickly check, was logged in via web page and could log in via the app, and then tested the reverse, logged in via app then did not allow me to log in via the webā¦
We actively use the app too arm/disarm, make that, that 95% of our interface with the system, so if using the app is going to block the web and the web interface is used by the add-on then i might not be able to do this.
please advise
G
Hi all,
Iām having a problem with zoningā¦ My system has 3 zones, 2 of them are for windows and one is for motion detectorsā¦ In order to do a āARM_HOMEā, what it looks like would need to happen is that I would need to send an āARM_AWAYā to 2 of the zones (for the windows), whereas for an āARM_AWAYā I would have to send it to the 3rd zone (for motion detectors), and possibly the other 2 as well if all the windows are closedā¦ Is there any way to configure at least using separate zones for āARM_HOMEā and āARM_AWAYā?
Thanks.
any chance to make it work with docker for Synology?
Right. I tired core-mosquitto which couldnāt be resloved. But with the ip address I can see the events pushed to the broker by subscribing to the topic, so the add-on-to mosquitto integration works.
I created a virtualbox vm and basically started from scratch, keeping it to bare minimum - mqtt and paradox alarm add-on. Ended up with the same result.
I would gladly appreciate your generous offer for remote assistance. Iām in EEST (gmt+2).
Hi @Leon_Li,
Iāve looked hard into this, and I came to the conclusion there are no ways of triggering the alarm from the web interface, be it panic (no siren) or regular alarm (with bells).
One way to go would be to add a remotely controlled relay to the alarm GPIO, and use that for the trigger. This requires some wiring in the alarm module, and the purchase of a remotely controlled relay (say controlled via MQTT over WiFi, or Zigbee). Once you have that, you would need to add the switch in Home Assistant.
Hi @scstraus,
My take here would be to define an alarm panel for each zone, then set up an automation or a script for arming/disarming. That is, one instance of the addon is running, providing info for all zones (under different MQTT paths). Each alarm panel is configured to operate on different zones (i.e. different MQTT paths, each corresponding to a different zone).
Would that work in your case?
I"m looking at the followingā¦
G
soā¦ that was itā¦ a case of ā vs ". Problem solved!
Well, yes, right now I have 3 alarm panels, so I can go in and manually arm and disarm all 3 zones, but thatās pretty cumbersomeā¦ Iād like to have one alarm panel for all of themā¦
Iām thinking of trying to build something using the Manual Alarm Panel, which then sends the necessary requests to the 3 other panelsā¦ But then I have to build all the state handling and everything tooā¦ Kind of a hassleā¦ But maybe someday I will get motivated to do itā¦
It would still be awfully nice if we could just have some config option to arm/disarm multiple zones with a single panel in this MQTT addon though.
that mean need to trigger a zone by wifi relay. It will be good to program any kind of sensors to the system via home assistant to create a better alarm system on top of the exisiting.
does anybody have issues using SSL communication to the broker? Iāve switched from self signed certs to Letās Encrypt in order to eliminate certificate related issues but canāt get the add-on to talk to the broker. More specifically
mqtt://broker.fqdn:1883
works fine, while
mqtts://broker.fqdn:4883
does not.
No errors in this add-onās log, the only error on the mqtt broker is:
OpenSSL Error: error:1408F10B:SSL routines:ssl3_get_record:wrong version number
On the mqtt broker support thread I got a suggestion to try to specify the ask version of the cert, though Iām not sure how to do that.
I re-read the discussion from scratch so now let me change my question a bit:
Is anybody using this add-on with
1)SSL-encrypted communication to their MQTT broker
2)SSL-encrypted communication to their IP150x
Currently I canāt setup either and I really feel awkward having HA sitting with that big āDISARMā button and all that plain text talk going on back and forward.
OK I found a temporary fix. Like in surviving till the next restart of the add-on. If interested, please read on. If anybody feels Iām spamming this thread please let me know.
This addon is using paho mqtt python client. After some research I found out that in order to do a successful pub/sub via mqtts paho (and most mqtt clients) require the CA cert files that should be treated as trusted. For my particular case this represents a bit of a problem as
- Iām using Letās Encrypt (actually switched from self-signed because of this issue)
- Apparently the LetsEncrypt CA files are not included in the base image used to build this add-on (at least I couldnāt recognize the file name in /etc/ssl/certs)
As a PoC I logged into the running addon container, created a file and pasted the letsencrypt CA certificates in it, then entered the following line of code just before the call to mqc.connect() in ip150_mqtt.py:
mqc.tls_set(ca_certs='path/to/letsencrypt_ca.pem')
Just like that, I have the Paradox Alarm talking to my MQTT broker via mqtts!
Now obviously this isnāt sustainable, so Iām looking for a way to
a) access the homeassistant container filesystem where I can store the CA cert files from the Paradox Alarm MQTT container, or
b) add code that pulls (curl, wget?) the cert files from letsencrypt.org and adds them to the live container
obviously the latter is much dirtier and less reliable so Iād rather avoid it. Plus if I setup the former I can add a config option so that others might change their CA cert file names.
Can anybody help me with this approach?
