I must work on a box to range them.
I used a 4 channel really as describe here : 4 channel Relay ESP8266 Wifi board WORKING with esphome. I got inspired by you project where i replace sonnoff by this est relay.
I made integration with Esphome.
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: "yours"
password: "yours"
ap:
ssid: "4Ch Reef Pompes Doseuse"
password: "yours"
captive_portal:
# Enable Home Assistant API
api:
ota:
logger:
baud_rate: 0 #need this to free up UART pins
uart:
baud_rate: 115200 # speed to STC15L101EW
tx_pin: GPIO1
rx_pin: GPIO3
switch:
name: 'Pompe doseuse Kh'
turn_on_action:
- uart.write: [0xA0, 0x01, 0x01, 0xA2]
turn_off_action:
- uart.write: [0xA0, 0x01, 0x00, 0xA1]
optimistic: true
name: 'Pompe doseuse Ca'
turn_on_action:
- uart.write: [0xA0, 0x02, 0x01, 0xA3]
turn_off_action:
- uart.write: [0xA0, 0x02, 0x00, 0xA2]
optimistic: true
name: 'Pompe doseuse Min'
turn_on_action:
- uart.write: [0xA0, 0x03, 0x01, 0xA4]
turn_off_action:
- uart.write: [0xA0, 0x03, 0x00, 0xA3]
optimistic: true
name: 'Pompe doseuse Mg'
turn_on_action:
- uart.write: [0xA0, 0x04, 0x01, 0xA5]
turn_off_action:
- uart.write: [0xA0, 0x04, 0x00, 0xA4]
optimistic: true
- platform: restart
As relay can be activated by wifi as independent switch. So, one card = 4 switch.
1 switch on pump and all in 12V.
I simply use your code for Boolean, sensors, input-select, automatisation… without the MQTT part and replace your switch item in automation action by mine.
Sorry if my english is bad. I her not partake a lot.
