I just released v0.6 which fixes this
Thanks a lot!
Iâm trying to use sighthound to implement face detection in HA.
Iâve registered with Sighthound to get the api key as developer (free).
Iâve added to my configuration.yaml the following:
image_processing:
- platform: sighthound
api_key: api_key
save_file_folder: /config/sighthound/
save_timestamped_file: True
source:- entity_id: camera.xxx
These are the errors I got when HA checks the configuration:
Invalid config for [image_processing.sighthound]: [save_file_folder] is an invalid option for [image_processing.sighthound]. Check: image_processing.sighthound->save_file_folder. (See ?, line ?).
not a directory @ data[âwhitelist_external_dirsâ][2]
Any idea ?
Thank you for helping me.
You are using the component on github right? The official integration doesnât have all the features yet
Hello, Iâm using the official integration at the moment. How can I use the custom component ?
Thank you for your help.
Hey! This looks awesome
Just to double check before I start playing, would this would with a ring doorbell camera and ring spotlight cameras ?
i cant figure out what i m doing wrong as i couldnt get it working, can somebody point out what i ve missed?
these are things i ve done so far;
- installed âsighthound custom componentâ using integrations in HACS
- wrote this in configuration.yaml
image_processing:
api_key: (i put in my API key from sighthound)
save_file_folder: /config/tmp/
# scan_interval: 30 # optional, in seconds
source:
- entity_id: camera.porch
- entity_id: camera.pc
these created 2 entities; sighthound_pc & sighthound_porch
- wrote this in automation.yaml for automation to send me notification on person detection
- alias: scan tell
platform: event
event_type: image_processing.detect_persons
- service: notify.tellme
data_template:
message: âPerson Detectedâ
- wrote this in automation.yaml to trigger the image scan/processing
- id: scan
alias: Camera Picture Notification Road
- platform: state
entity_id: input_boolean.transit
to: 'on'
- service: image_processing.scan
entity_id: image_processing.sighthound_pc
When i toggle the input_boolean.transit, nothing happen. What am i doing wrong?
I can see from sighthound website that usage is 0/5000âŚso no attempt was made.
Everything looks fine, anything in the logs? Also you can directly trigger the scan from the developer tools
Error that i m getting;
Error on receive image from entity: Unable to get image
components/image_processing/init.py (error)
i guess sighthound component is not able to get the image from my camera. btw i m using Vstarcam camera, using onvif platform. not sure if that does matter.
After using it for some time I have to say that sigthoundâs algorith to detect people is very very weak. Everyday I keep getting notifications from HA that my camera detected people and on the screen I see flowers, shades etc. Then I send exactly the same picture to googleâs vision and no mistake. Unfortunately it is hard to configure and payment details need to be filled.
@robmarkcole you are definitely busy and contributing a lot in this area. Iâm picking back up the Coral person detection again - I say picking back up but itâs been working nicely for the past month or two sending me âDong Dingâ doorbell notifications whenever someoneâs at the door but hasnât rung the doorbell yet and itâs great! Iâve added detection for a couple other cameras around the perimeter but want to increase the update frequency and add other objects via a custom trained model.
Did anyone ever get good numbers on the number of images per second the coral could tag? Iâm also looking for the âofficialâ integration and repository but am having trouble as it seems there are at least two forks or different efforts working towards the same thing?
The more I type the more I realize this is off topic for this thread, apologies.
-Joni-
@rjchu yes please the coral thread to discuss coral.
@majkers I do not know which model sighthound is using but there are several âhigh accuracyâ models in the public domain so there must be more aspects to consider when selecting a model. I suggest you provide feedback on the sighthound forums
local_file camera gives me the same error. i guess it s not because of my camera then.
âError on receive image from entity: Unable to get imageâ
Is it possible to teach sighthound, that my grill is not a person?
Hello
image_processing:
api_key: âxxxxxxâ
save_file_folder: /config/www/
scan_interval: 1000
source:- entity_id: camera.cgaleria
i wrote this in automatizations.yaml
- id: camera_snapshot_galeria
alias: Camera Picture galeria
trigger:- entity_id: binary_sensor.camaragaleria
platform: state
to: âonâ
action: - data:
entity_id: image_processing.sighthound_cgaleria
The component gives me an error. I copy the log
Thu Feb 20 2020 23:17:29 GMT-0300 (hora estĂĄndar de Argentina)
Update for image_processing.sighthound_cgaleria fails
File â/usr/src/homeassistant/homeassistant/helpers/entity.pyâ, line 279, in async_update_ha_state
await self.async_device_update()
File â/usr/src/homeassistant/homeassistant/helpers/entity.pyâ, line 459, in async_device_update
await self.async_update()
File â/usr/src/homeassistant/homeassistant/components/image_processing/init.pyâ, line 132, in async_update
await self.async_process_image(image.content)
File â/usr/src/homeassistant/homeassistant/components/image_processing/init.pyâ, line 112, in async_process_image
return await self.hass.async_add_job(self.process_image, image)
File â/usr/local/lib/python3.7/concurrent/futures/thread.pyâ, line 57, in run
File â/config/custom_components/sighthound/image_processing.pyâ, line 112, in process_image
self.faces = hound.get_faces(detections)
File â/usr/local/lib/python3.7/site-packages/simplehound/core.pyâ, line 54, in get_faces
for obj in detections[âobjectsâ]:
TypeError: âNoneTypeâ object is not subscriptable
that could be happening?
Working my way through the install and have everything working except my logs say
Could not read camera sighthound image from file /config/www/sighthound_latest.jpg
Checking www the file isnât there.
I can call the image_processing.scan service and and also trigger the âimage_processing.sighthound_garage_cctvâ state from 0 to say 2 and HA front end shows 2 faces but I cannot seem to create the file.
Using a DVR which the camera identities are working but are RTSP streams. Is this where my issue is?
Config file
api_key: Added API Key
scan_interval: 1000 # optional, in seconds
source:
- entity_id: camera.garage_cctv
Any ideas/advice?
To confirm, you are using the custom integration and not the official one?
Could you send me the necessary modification?
