Can you explain to me how to modify the default thermostat of home assistant?
I would like to modify the icons, the colors and add information
There are a number of climate cards in HACS, for example
Merci
Je regarde cela
Thank you
I watch this
English only, please.
If you use pilot wire electric heating (which I believe is common in Fance) then the following HACS Integration works well with the Simple Thermostat card mentioned by @nickrout :
Obviously you would need to buy the Qubino pilot wire dimmer modules to work with this.
Bonjour, Hello
It is for the use of my Toshiba air conditioning thanks to the great plugin
