Try the solution I outlined above, it will provide you with temperature and humidity as well. Do make sure you change weather.home in the code if needed. I believe you might be using weather.forecast_casa.
Should you need more than five hours, increase the number 5 for the home_hourly sensor
forecast: "{{ hourly_forecast.forecast[:5] }}"
as explained on GitHub.
