Peugeot Citroen DS cars - Connected Car
ok I noticed you changed it already and i had a brain fart moment, fixed now
do you know if all sensors from the api are exposed to the addon, doors, service etc?
have you found any other exposes via the addon, just curious as I noticed the switch in the addon to stop charge etc and wondered if anyone has made use of that, also doors, locked and unlocked etc… my previous car (vw) I had automation setup that would tell me if goodnight routine was activated if any windows were open or if doors were not locked.
Hi, thanks again for this addon!
I have the following problem: After a successful first test, nearly all the PSACC related entities have just disappeared. They are just not there anymore. Yes, i checked for hidden or deactivated entities - nothing. Only available are: Version, Running, Update Available, CPU Percent, Memory Percent, Newest Version. They are obviously related to the app directly but not to the car.
Any ideas what else i could check?
Thank you, Cro
Hi all.
So trying to get this to work on my Corsa-e. I can see from the log files that I am getting the data. I have my IP but it is saying when I try to run Curl, that connection is refused.
I have read that I need to set the ports up but I cannot see anywhere in the UI/config where I can do this. I am getting the data as the Add-on is collecting it properly but I clearly am not running the REST action properly.
I suspect that I am close but any help would be appreciated.
Any ideas?
Cheers
Hi, i still have similar issues: The PSACC is working, i get responses when calling the getinfo-url using the IP of my HA and the VIN of my car. But there is no entity showing up expect the three you mentioned before. All the entities configured in sensors.yaml are not showing up. Do you have any idea what i could do?
Took me weeks to figure it out:
I forgot to add the sensor.yaml to config.yaml so i was trying to find the issue in a sensor.yaml that has never been included in HA.
Yes, I rolled my eyes so hard, they hurt now…
sensor: !include sensor.yaml
how did you get last position working, because mine dont shows nothing
Hello…
All is here. Maybe check to open resource_template: in a browser and check if the value is empty or not.
hello, would this work with a citroen c4 picasso 2018 diesel with the NAC head unit, I have data to the my citroen app?
coordinates:
  - null
  - null
  - null
friendly_name: 308_hybrid_mapdata
thats all i get
So, it can not work
Maybe … try with the url of ressource
cough
cough
Checked the resource befor posting still shows null null null
If you did read it, then you know that this is a PSA problem. No fix from addin side possible.
I presumed that and it wont help the app rolled out another update a few weeks ago, also new api is being released when they launch the manage my peugeot on the web.
I can’t get it to work on a ds 7, diesel gives me unknown sensors, except for the diesel tank and I don’t know how to do it. Is there a new tutorial?
Hi, my app is working, but I do not find config.ini file anywhere.
Also i do not know why comsumption is so low. I have e spevatourer and it shoud be about 22-27kW/100km.
Thank you for advance
-Veli
Of course you won’t find it. It’s inside the Docker container. Editing it is not that easy. All your settings should be done with the Web UI. One error in the ini and the container will not start anymore.
Web UI? so i have to be honest that i do not know where do you mean? Have to say that I am beginer in this kind things, but very happy about you app and work. Thank you.
BR
Veli
