This is a bit off topic, but I figured a few of you might be interested in this. Here is how to setup a bandwidth SNMP polling for your pfSence WAN interface. This will give you the following entities for your viewing pleasure:
You will need to enable SNMP read access on your firewall, I used the community string of “public”. Be sure to change the host IP below to your pfSense internal interface.
- platform: snmp
name: 'pfsense WAN in'
host: 10.1.1.1
baseoid: 1.3.6.1.2.1.31.1.1.1.6.2
community: 'public'
version: '2c'
scan_interval: 60
- platform: snmp
name: 'pfsense WAN out'
host: 10.1.1.1
baseoid: 1.3.6.1.2.1.31.1.1.1.10.2
community: 'public'
version: '2c'
scan_interval: 60
- platform: statistics
name: 'pfsense WAN in Stats'
entity_id: sensor.pfsense_wan_in
sampling_size: 4
max_age:
hours: 24
name: 'pfsense WAN out Stats'
entity_id: sensor.pfsense_wan_out
sampling_size: 4
max_age:
hours: 24
sensors:
internet_in_mbps:
icon_template: mdi:cloud-download-outline
value_template: "{{ (state_attr('sensor.pfsense_wan_in_stats','change_rate')|float*8*(state_attr('sensor.pfsense_wan_in_stats', 'sampling_size')-1)/1000000)|round(2) }}"
unit_of_measurement: 'Mbps'
entity_id: sensor.pfsense_wan_in_stats
internet_out_mbps:
icon_template: mdi:cloud-upload-outline
value_template: "{{ (state_attr('sensor.pfsense_wan_out_stats','change_rate')|float*8*(state_attr('sensor.pfsense_wan_out_stats', 'sampling_size')-1)/1000000)|round(2) }}"
entity_id: sensor.pfsense_wan_out_stats
