Henkonoly:
device diagnostic file
This is the complete device diagnostic file because i ran in max post carracters
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.12.0",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.11.6",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Amsterdam",
"os_name": "Linux",
"os_version": "6.1.63-haos",
"supervisor": "2023.11.6",
"host_os": "Home Assistant OS 11.2",
"docker_version": "24.0.7",
"chassis": "vm",
"run_as_root": true
"custom_components": {
"localtuya": {
"version": "5.2.1",
"requirements": []
"zonneplan_one": {
"version": "0.0.22",
"requirements": []
"hacs": {
"version": "1.33.0",
"requirements": [
"aiogithubapi>=22.10.1"
"better_thermostat": {
"version": "1.4.0",
"requirements": []
"integration_manifest": {
"domain": "zwave_js",
"name": "Z-Wave",
"codeowners": [
"@home-assistant/z-wave"
"config_flow": true,
"dependencies": [
"http",
"repairs",
"usb",
"websocket_api"
"documentation": "https://www.home-assistant.io/integrations/zwave_js",
"integration_type": "hub",
"iot_class": "local_push",
"loggers": [
"zwave_js_server"
"quality_scale": "platinum",
"requirements": [
"pyserial==3.5",
"zwave-js-server-python==0.54.0"
"usb": [
"vid": "0658",
"pid": "0200",
"known_devices": [
"Aeotec Z-Stick Gen5+",
"Z-WaveMe UZB"
"vid": "10C4",
"pid": "8A2A",
"description": "*z-wave*",
"known_devices": [
"Nortek HUSBZB-1"
"zeroconf": [
"_zwave-js-server._tcp.local."
"is_built_in": true
"data": {
"versionInfo": {
"driverVersion": "12.4.0",
"serverVersion": "1.33.0",
"minSchemaVersion": 0,
"maxSchemaVersion": 33
"entities": [
"domain": "light",
"entity_id": "light.eco_dim_z_wave_led_dimmer_2",
"original_name": "",
"original_device_class": null,
"disabled": false,
"disabled_by": null,
"hidden_by": null,
"original_icon": null,
"entity_category": null,
"supported_features": 32,
"unit_of_measurement": null,
"value_id": "6-38-0-currentValue",
"primary_value": {
"command_class": 38,
"command_class_name": "Multilevel Switch",
"endpoint": 0,
"property": "currentValue",
"property_name": "currentValue",
"property_key": null,
"property_key_name": null
"domain": "sensor",
"entity_id": "sensor.eco_dim_z_wave_led_dimmer_electric_consumption_kwh_2",
"original_name": "Electric Consumption [kWh]",
"original_device_class": "energy",
"disabled": false,
"hidden_by": null,
"supported_features": 0,
"unit_of_measurement": "kWh",
"value_id": "6-50-0-value-65537",
"primary_value": {
"command_class": 50,
"command_class_name": "Meter",
"endpoint": 0,
"property": "value",
"property_name": "value",
"property_key": 65537,
"property_key_name": "Electric_kWh_Consumed"
"domain": "sensor",
"entity_id": "sensor.eco_dim_z_wave_led_dimmer_electric_consumption_w_2",
"original_name": "Electric Consumption [W]",
"original_device_class": "power",
"disabled": false,
"hidden_by": null,
"unit_of_measurement": "W",
"value_id": "6-50-0-value-66049",
"primary_value": {
"endpoint": 0,
"property_key": 66049,
"property_key_name": "Electric_W_Consumed"
"domain": "select",
"entity_id": "select.eco_dim_z_wave_led_dimmer_state_after_power_failure_2",
"original_name": "State After Power Failure",
"disabled": true,
"disabled_by": "integration",
"hidden_by": null,
"entity_category": "config",
"value_id": "6-112-0-1",
"primary_value": {
"command_class": 112,
"command_class_name": "Configuration",
"endpoint": 0,
"property": 1,
"property_name": "State After Power Failure",
"domain": "select",
"entity_id": "select.eco_dim_z_wave_led_dimmer_notification_when_load_status_change_2",
"original_name": "Notification When Load Status Change",
"disabled": true,
"hidden_by": null,
"value_id": "6-112-0-2",
"primary_value": {
"endpoint": 0,
"property": 2,
"property_name": "Notification When Load Status Change",
"domain": "number",
"entity_id": "number.eco_dim_z_wave_led_dimmer_default_dimming_speed_2",
"original_name": "Default Dimming Speed",
"disabled": true,
"hidden_by": null,
"unit_of_measurement": "seconds",
"value_id": "6-112-0-3",
"primary_value": {
"endpoint": 0,
"property": 3,
"property_name": "Default Dimming Speed",
"domain": "select",
"entity_id": "select.eco_dim_z_wave_led_dimmer_enable_or_disable_external_switch_to_pair_network_2",
"original_name": "Enable or Disable External Switch to Pair Network",
"disabled": true,
"hidden_by": null,
"value_id": "6-112-0-5",
"primary_value": {
"endpoint": 0,
"property": 5,
"property_name": "Enable or Disable External Switch to Pair Network",
"domain": "select",
"entity_id": "select.eco_dim_z_wave_led_dimmer_dimming_algorithm_2",
"original_name": "Dimming Algorithm",
"disabled": true,
"hidden_by": null,
"value_id": "6-112-0-6",
"primary_value": {
"endpoint": 0,
"property": 6,
"property_name": "Dimming Algorithm",
"domain": "number",
"entity_id": "number.eco_dim_z_wave_led_dimmer_default_brightness_2",
"original_name": "Default Brightness",
"disabled": true,
"hidden_by": null,
"value_id": "6-112-0-7",
"primary_value": {
"endpoint": 0,
"property": 7,
"property_name": "Default Brightness",
"domain": "number",
"entity_id": "number.eco_dim_z_wave_led_dimmer_turn_off_delay_2",
"original_name": "Turn Off Delay",
"disabled": true,
"hidden_by": null,
"value_id": "6-112-0-8",
"primary_value": {
"endpoint": 0,
"property": 8,
"property_name": "Turn Off Delay",
"state": {
"nodeId": 6,
"index": 0,
"installerIcon": 1536,
"userIcon": 1536,
"status": 4,
"ready": true,
"isListening": true,
"isRouting": true,
"isSecure": false,
"manufacturerId": 1073,
"productId": 2,
"productType": 514,
"firmwareVersion": "1.12",
"zwavePlusVersion": 1,
"deviceConfig": {
"filename": "/data/db/devices/0x0431/ecodim.json",
"isEmbedded": true,
"manufacturer": "EcoDim",
"label": "ECO-DIM",
"description": "ECO-DIM Z-Wave LED Dimmer",
"devices": [
"productType": 514,
"productId": 1
"productType": 514,
"productId": 2
"firmwareVersion": {
"min": "0.0",
"max": "255.255"
"preferred": false,
"associations": {},
"paramInformation": {
"_map": {}
"label": "ECO-DIM",
"interviewAttempts": 0,
"isFrequentListening": false,
"maxDataRate": 100000,
"supportedDataRates": [
40000,
100000
"protocolVersion": 3,
"supportsBeaming": true,
"supportsSecurity": false,
"nodeType": 1,
"zwavePlusNodeType": 0,
"zwavePlusRoleType": 5,
"deviceClass": {
"basic": {
"key": 4,
"label": "Routing Slave"
"generic": {
"key": 17,
"label": "Multilevel Switch"
"specific": {
"key": 1,
"label": "Multilevel Power Switch"
"mandatorySupportedCCs": [
32,
38,
39
"mandatoryControlledCCs": []
"interviewStage": "Complete",
"deviceDatabaseUrl": "https://devices.zwave-js.io/?jumpTo=0x0431:0x0202:0x0002:1.12",
"statistics": {
"commandsTX": 13,
"commandsRX": 13,
"commandsDroppedRX": 0,
"commandsDroppedTX": 0,
"timeoutResponse": 2,
"rtt": 32.9,
"lastSeen": "2023-12-08T06:10:30.208Z",
"rssi": -77,
"lwr": {
"protocolDataRate": 3,
"repeaters": [],
"rssi": -78,
"repeaterRSSI": []
"highestSecurityClass": -1,
"isControllerNode": false,
"keepAwake": false,
"values": {
"6-38-0-currentValue": {
"endpoint": 0,
"commandClass": 38,
"commandClassName": "Multilevel Switch",
"propertyName": "currentValue",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Current value",
"min": 0,
"max": 99,
"stateful": true,
"secret": false
"value": 0
"6-38-0-targetValue": {
"endpoint": 0,
"commandClass": 38,
"property": "targetValue",
"propertyName": "targetValue",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"label": "Target value",
"valueChangeOptions": [
"transitionDuration"
"min": 0,
"max": 99,
"stateful": true,
"secret": false
"value": 255
"6-38-0-Up": {
"endpoint": 0,
"commandClass": 38,
"property": "Up",
"propertyName": "Up",
"ccVersion": 2,
"metadata": {
"type": "boolean",
"readable": false,
"writeable": true,
"label": "Perform a level change (Up)",
"ccSpecific": {
"switchType": 2
"states": {
"true": "Start",
"false": "Stop"
"stateful": true,
"secret": false
"6-38-0-Down": {
"endpoint": 0,
"commandClass": 38,
"property": "Down",
"propertyName": "Down",
"ccVersion": 2,
"metadata": {
"type": "boolean",
"readable": false,
"writeable": true,
"label": "Perform a level change (Down)",
"ccSpecific": {
"switchType": 2
"states": {
"true": "Start",
"false": "Stop"
"stateful": true,
"secret": false
"6-38-0-duration": {
"endpoint": 0,
"commandClass": 38,
"property": "duration",
"propertyName": "duration",
"ccVersion": 2,
"metadata": {
"type": "duration",
"readable": true,
"writeable": false,
"label": "Remaining duration",
"stateful": true,
"secret": false
"6-38-0-restorePrevious": {
"endpoint": 0,
"commandClass": 38,
"property": "restorePrevious",
"propertyName": "restorePrevious",
"ccVersion": 2,
"metadata": {
"type": "boolean",
"readable": false,
"writeable": true,
"label": "Restore previous value",
"states": {
"true": "Restore"
"stateful": true,
"secret": false
"6-50-0-value-65537": {
"endpoint": 0,
"commandClass": 50,
"commandClassName": "Meter",
"propertyKey": 65537,
"propertyName": "value",
"propertyKeyName": "Electric_kWh_Consumed",
"ccVersion": 3,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Electric Consumption [kWh]",
"ccSpecific": {
"meterType": 1,
"scale": 0,
"rateType": 1
"unit": "kWh",
"stateful": true,
"secret": false
"value": 0.06
"6-50-0-value-66049": {
"endpoint": 0,
"commandClass": 50,
"propertyKey": 66049,
"propertyKeyName": "Electric_W_Consumed",
"ccVersion": 3,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Electric Consumption [W]",
"ccSpecific": {
"meterType": 1,
"scale": 2,
"rateType": 1
"unit": "W",
"stateful": true,
"secret": false
"value": 0
"6-50-0-reset": {
"endpoint": 0,
"commandClass": 50,
"property": "reset",
"propertyName": "reset",
"ccVersion": 3,
"metadata": {
"type": "boolean",
"readable": false,
"writeable": true,
"label": "Reset accumulated values",
"states": {
"true": "Reset"
"stateful": true,
"secret": false
"6-112-0-1": {
"endpoint": 0,
"commandClass": 112,
"commandClassName": "Configuration",
"property": 1,
"propertyName": "State After Power Failure",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"label": "State After Power Failure",
"default": 0,
"min": 0,
"max": 2,
"states": {
"0": "Always off",
"1": "Always on",
"2": "Previous state"
"valueSize": 1,
"format": 0,
"allowManualEntry": false,
"isFromConfig": true
"value": 2
"6-112-0-2": {
"endpoint": 0,
"property": 2,
"propertyName": "Notification When Load Status Change",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"description": "The Dimmer will send notification to associated device (Group Lifeline) when the status of Dimmer load is changed.",
"label": "Notification When Load Status Change",
"default": 1,
"min": 0,
"max": 2,
"states": {
"0": "The function is disabled",
"1": "Send Multilevel Switch Report",
"2": "Send Multilevel Switch Report only when load status is not changed by Z-Wave command"
"valueSize": 1,
"format": 0,
"value": 0
"6-112-0-3": {
"endpoint": 0,
"property": 3,
"propertyName": "Default Dimming Speed",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"description": "Configure the default dimming speed: 0 = Instantly, 1 = Fast, 100 = Slow",
"label": "Default Dimming Speed",
"default": 5,
"min": 0,
"max": 100,
"unit": "seconds",
"valueSize": 1,
"format": 0,
"allowManualEntry": true,
"value": 20
"6-112-0-5": {
"endpoint": 0,
"property": 5,
"propertyName": "Enable or Disable External Switch to Pair Network",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"label": "Enable or Disable External Switch to Pair Network",
"default": 0,
"min": 0,
"max": 1,
"states": {
"0": "Disable",
"1": "Enable"
"valueSize": 1,
"format": 0,
"value": 1
"6-112-0-6": {
"endpoint": 0,
"property": 6,
"propertyName": "Dimming Algorithm",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"description": "Setting dimming way.",
"label": "Dimming Algorithm",
"default": 0,
"min": 0,
"max": 1,
"states": {
"0": "Linear dimming",
"1": "Logarithmic dimming"
"valueSize": 1,
"format": 0,
"value": 0
"6-112-0-7": {
"endpoint": 0,
"property": 7,
"propertyName": "Default Brightness",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"description": "Setting default brightness when turn on the dimmer from off status. 0 means that the dimmer will use parameter 1.",
"label": "Default Brightness",
"default": 0,
"min": 0,
"max": 99,
"valueSize": 1,
"format": 0,
"value": 0
"6-112-0-8": {
"endpoint": 0,
"property": 8,
"propertyName": "Turn Off Delay",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"description": "Setting delay time when turn off",
"label": "Turn Off Delay",
"default": 0,
"min": 0,
"max": 60,
"unit": "seconds",
"valueSize": 1,
"format": 0,
"value": 0
"6-114-0-manufacturerId": {
"endpoint": 0,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"property": "manufacturerId",
"propertyName": "manufacturerId",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"min": 0,
"max": 65535,
"stateful": true,
"secret": false
"value": 1073
"6-114-0-productType": {
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"min": 0,
"max": 65535,
"stateful": true,
"secret": false
"value": 514
"6-114-0-productId": {
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"min": 0,
"max": 65535,
"stateful": true,
"secret": false
"value": 2
"6-134-0-libraryType": {
"endpoint": 0,
"commandClass": 134,
"commandClassName": "Version",
"property": "libraryType",
"propertyName": "libraryType",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Library type",
"states": {
"0": "Unknown",
"1": "Static Controller",
"2": "Controller",
"3": "Enhanced Slave",
"4": "Slave",
"5": "Installer",
"6": "Routing Slave",
"7": "Bridge Controller",
"8": "Device under Test",
"9": "N/A",
"10": "AV Remote",
"11": "AV Device"
"stateful": true,
"secret": false
"value": 3
"6-134-0-protocolVersion": {
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"ccVersion": 2,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version",
"stateful": true,
"secret": false
"value": "6.4"
"6-134-0-firmwareVersions": {
"endpoint": 0,
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"ccVersion": 2,
"metadata": {
"type": "string[]",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions",
"stateful": true,
"secret": false
"value": [
"1.12"
"6-134-0-hardwareVersion": {
"endpoint": 0,
"property": "hardwareVersion",
"propertyName": "hardwareVersion",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Z-Wave chip hardware version",
"stateful": true,
"secret": false
"value": 1
"endpoints": {
"0": {
"nodeId": 6,
"index": 0,
"userIcon": 1536,
"deviceClass": {
"basic": {
"key": 4,
"generic": {
"key": 17,
"specific": {
"key": 1,
32,
38,
39
"commandClasses": [
"id": 38,
"name": "Multilevel Switch",
"version": 2,
"isSecure": false
"id": 94,
"name": "Z-Wave Plus Info",
"version": 2,
"isSecure": false
"id": 50,
"name": "Meter",
"version": 3,
"isSecure": false
"id": 112,
"name": "Configuration",
"version": 1,
"isSecure": false
"id": 133,
"name": "Association",
"version": 2,
"isSecure": false
"id": 89,
"name": "Association Group Information",
"version": 1,
"isSecure": false
"id": 85,
"name": "Transport Service",
"version": 2,
"isSecure": false
"id": 134,
"name": "Version",
"version": 2,
"isSecure": false
"id": 114,
"name": "Manufacturer Specific",
"version": 2,
"isSecure": false
"id": 90,
"name": "Device Reset Locally",
"version": 1,
"isSecure": false
"id": 115,
"name": "Powerlevel",
"version": 1,
"isSecure": false
"id": 152,
"name": "Security",
"version": 1,
"isSecure": true
"id": 159,
"name": "Security 2",
"version": 1,
"isSecure": true
"id": 108,
"name": "Supervision",
"version": 1,
"isSecure": false
"id": 122,
"name": "Firmware Update Meta Data",
"version": 4,
"isSecure": false
