I can’t get the buttons to work. Pressing them raises an event in the trace of the automation, but ‘no action is taken’, and the input_text helper remains unchanged. How can I debug this?
The trace is the best way to debug. If you can’t figure it out you can export the trace and post here and I can take a look at it.
Thanks!
I’m trying to use the blueprint to dim and switch on and off lights. I’ve selected two lights (earlier I tried four, but that didn’t work, so I started over). I’m expecting the buttons to select the light, and the dial to dim them. Dimming only works on the first light, and the input_text
helper remains unknown
(I suppose that’s the default value).
I’ve installed it yesterday using your repository, so it should be using the latest version.
Edit: full trace below.
When looking at the trace, at the top right is a menu where you can download the full trace
I see.
"trace": {
"last_step": "action/1/choose/5/conditions/0",
"run_id": "4bb1d7d27dcd9d95bc2435b7750d6d55",
"state": "stopped",
"script_execution": "finished",
"timestamp": {
"start": "2023-09-20T03:53:15.063787+00:00",
"finish": "2023-09-20T03:53:15.081563+00:00"
"domain": "automation",
"item_id": "1695149249296",
"trigger": "event 'zha_event'",
"trace": {
"trigger/0": [
"path": "trigger/0",
"timestamp": "2023-09-20T03:53:15.063880+00:00",
"changed_variables": {
"first_light": {
"device_id": "97da4c3a46483b7baa486af45ba16255"
"second_light": {
"device_id": "b36b95fa649b56b817471d76a241268a"
"third_light": {},
"forth_light": {},
"current_light": "input_text.hue_tap_dial_selected_light",
"dim_scale": 1,
"lights": {
"first_light": {
"second_light": {
"third_light": {},
"forth_light": {}
"this": {
"entity_id": "automation.philips_tap_dial_switch",
"state": "on",
"attributes": {
"id": "1695149249296",
"last_triggered": "2023-09-19T18:50:50.231522+00:00",
"mode": "restart",
"current": 0,
"friendly_name": "Philips Tap Dial Switch"
"last_changed": "2023-09-19T18:48:34.643273+00:00",
"last_updated": "2023-09-19T18:50:50.238554+00:00",
"context": {
"id": "01HAQCFRZQP9E85CFX03B3S0X2",
"parent_id": "01HAQCFRZPAD96FMJZ90H8DS67",
"user_id": null
"trigger": {
"id": "0",
"idx": "0",
"alias": null,
"platform": "event",
"event": {
"event_type": "zha_event",
"data": {
"device_ieee": "00:17:88:01:0d:7c:b6:31",
"unique_id": "00:17:88:01:0d:7c:b6:31:1:0x0005",
"device_id": "f02c01cf31f0a64c01246ac64d25814b",
"endpoint_id": 1,
"cluster_id": 5,
"command": "recall",
"args": [
41098,
1
"params": {
"group_id": 41098,
"scene_id": 1,
"transition_time": null
"origin": "LOCAL",
"time_fired": "2023-09-20T03:53:15.063347+00:00",
"context": {
"id": "01HARBGZ1QH38WE4F143287RJZ",
"parent_id": null,
"user_id": null
"description": "event 'zha_event'"
"action/0": [
"path": "action/0",
"timestamp": "2023-09-20T03:53:15.069100+00:00",
"context": {
"id": "01HARBGZ1QXS55VXR0HMSMTTRK",
"parent_id": "01HARBGZ1QH38WE4F143287RJZ",
"user_id": null
"action/1": [
"path": "action/1",
"timestamp": "2023-09-20T03:53:15.075660+00:00",
"args": [
41098,
1
"params": {
"group_id": 41098,
"scene_id": 1,
"step_size": "",
"step_mode": "",
"scene": ""
"action/1/choose/0": [
"path": "action/1/choose/0",
"timestamp": "2023-09-20T03:53:15.075828+00:00",
"result": {
"result": false
"action/1/choose/0/conditions/0": [
"path": "action/1/choose/0/conditions/0",
"timestamp": "2023-09-20T03:53:15.075886+00:00",
"result": {
"result": true,
"entities": []
"action/1/choose/0/conditions/1": [
"path": "action/1/choose/0/conditions/1",
"timestamp": "2023-09-20T03:53:15.076094+00:00",
"result": {
"result": false,
"entities": []
"action/1/choose/1": [
"path": "action/1/choose/1",
"timestamp": "2023-09-20T03:53:15.076285+00:00",
"result": {
"result": false
"action/1/choose/1/conditions/0": [
"path": "action/1/choose/1/conditions/0",
"timestamp": "2023-09-20T03:53:15.076334+00:00",
"result": {
"result": true,
"entities": []
"action/1/choose/1/conditions/1": [
"path": "action/1/choose/1/conditions/1",
"timestamp": "2023-09-20T03:53:15.076476+00:00",
"result": {
"result": true,
"entities": []
"action/1/choose/1/conditions/2": [
"path": "action/1/choose/1/conditions/2",
"timestamp": "2023-09-20T03:53:15.076624+00:00",
"result": {
"result": false,
"entities": []
"action/1/choose/2": [
"path": "action/1/choose/2",
"timestamp": "2023-09-20T03:53:15.076795+00:00",
"result": {
"result": false
"action/1/choose/2/conditions/0": [
"path": "action/1/choose/2/conditions/0",
"timestamp": "2023-09-20T03:53:15.076844+00:00",
"result": {
"result": true,
"entities": []
"action/1/choose/2/conditions/1": [
"path": "action/1/choose/2/conditions/1",
"timestamp": "2023-09-20T03:53:15.076975+00:00",
"result": {
"result": true,
"entities": []
"action/1/choose/2/conditions/2": [
"path": "action/1/choose/2/conditions/2",
"timestamp": "2023-09-20T03:53:15.077123+00:00",
"result": {
"result": false,
"entities": []
"action/1/choose/3": [
"path": "action/1/choose/3",
"timestamp": "2023-09-20T03:53:15.077288+00:00",
"result": {
"result": false
"action/1/choose/3/conditions/0": [
"path": "action/1/choose/3/conditions/0",
"timestamp": "2023-09-20T03:53:15.077333+00:00",
"result": {
"result": true,
"entities": []
"action/1/choose/3/conditions/1": [
"path": "action/1/choose/3/conditions/1",
"timestamp": "2023-09-20T03:53:15.077461+00:00",
"result": {
"result": true,
"entities": []
"action/1/choose/3/conditions/2": [
"path": "action/1/choose/3/conditions/2",
"timestamp": "2023-09-20T03:53:15.077598+00:00",
"result": {
"result": false,
"entities": []
"action/1/choose/4": [
"path": "action/1/choose/4",
"timestamp": "2023-09-20T03:53:15.077763+00:00",
"result": {
"result": false
"action/1/choose/4/conditions/0": [
"path": "action/1/choose/4/conditions/0",
"timestamp": "2023-09-20T03:53:15.077809+00:00",
"result": {
"result": false,
"entities": []
"action/1/choose/5": [
"path": "action/1/choose/5",
"timestamp": "2023-09-20T03:53:15.077996+00:00",
"result": {
"result": false
"action/1/choose/5/conditions/0": [
"path": "action/1/choose/5/conditions/0",
"timestamp": "2023-09-20T03:53:15.078161+00:00",
"result": {
"result": false,
"entities": []
"config": {
"mode": "restart",
"max_exceeded": "silent",
"variables": {
"first_light": {
"second_light": {
"third_light": {},
"forth_light": {},
"dim_scale": 1,
"lights": {
"first_light": {
"second_light": {
"third_light": {},
"forth_light": {}
"trigger": [
"event_data": {
"action": [
"variables": {
"command": "{{ trigger.event.data.command }}",
"args": "{% if (trigger.event.data.args is defined) %}{{trigger.event.data.args}}{% endif %}",
"params": "{% if (trigger.event.data.params is defined) %}{{trigger.event.data.params}}{% endif %}",
"step_size": "{% if (trigger.event.data.params is defined) and (trigger.event.data.params.step_size is defined) %}{{trigger.event.data.params.step_size}}{% endif %}",
"step_mode": "{% if (trigger.event.data.params is defined) and (trigger.event.data.params.step_mode is defined) %}{{trigger.event.data.params.step_mode}}{% endif %}",
"scene": "{% if (trigger.event.data.params is defined) and (trigger.event.data.params.scene is defined) %}{{trigger.event.data.params.scene}}{% endif %}"
"choose": [
"conditions": [
"{{ command == 'recall' }}",
"{{ scene == 1 }}"
"sequence": [
"service": "homeassistant.toggle",
"target": {
"choose": [
"conditions": "{{ current_light != none }}",
"sequence": [
"service": "input_text.set_value",
"target": {
"entity_id": "input_text.hue_tap_dial_selected_light"
"data": {
"value": "first_light"
"conditions": [
"{{ second_light != none }}",
"{{ scene == 0 }}"
"sequence": [
"target": {
"choose": [
"sequence": [
"target": {
"data": {
"value": "second_light"
"conditions": [
"{{ third_light != none }}",
"{{ scene == 5 }}"
"sequence": [
"target": {}
"choose": [
"sequence": [
"target": {
"data": {
"value": "third_light"
"conditions": [
"{{ forth_light != none }}",
"{{ scene == 4 }}"
"sequence": [
"target": {}
"choose": [
"sequence": [
"target": {
"data": {
"value": "forth_light"
"conditions": [
"{{ command == 'step_with_on_off' }}",
"{{ step_mode == 'StepMode.Up' }}"
"sequence": [
"choose": [
"sequence": [
"service": "light.turn_on",
"target": "{{ lights[states(current_light)] }}",
"data": {
"brightness_step_pct": "{{ step_size * dim_scale }}",
"transition": 1
"default": [
"target": {
"data": {
"transition": 1
"conditions": [
"{{ step_mode == 'StepMode.Down' }}"
"sequence": [
"choose": [
"sequence": [
"data": {
"brightness_step_pct": "{{ -step_size * dim_scale }}",
"transition": 1
"default": [
"target": {
"data": {
"transition": 1
"alias": "Philips Tap Dial Switch",
"description": ""
"blueprint_inputs": {
"description": "",
"use_blueprint": {
"path": "apollo1220/philips_zigbee_dial.yaml",
"input": {
"remote": "f02c01cf31f0a64c01246ac64d25814b",
"first_light": {
"second_light": {
"context": {
"user_id": null
"logbookEntries": [
"name": "Philips Tap Dial Switch",
"message": "triggered by event 'zha_event'",
"source": "event 'zha_event'",
"context_id": "01HARBGZ1QXS55VXR0HMSMTTRK",
"when": 1695181995.064039,
"trace": {
"run_id": "6522cb3c438f655fdb239f66b7e0fc63",
"state": "stopped",
"timestamp": {
"start": "2023-09-20T03:53:25.748288+00:00",
"finish": "2023-09-20T03:53:25.761559+00:00"
"trace": {
"trigger/0": [
"timestamp": "2023-09-20T03:53:25.748385+00:00",
"first_light": {
"second_light": {
"third_light": {},
"forth_light": {},
"dim_scale": 1,
"lights": {
"first_light": {
"second_light": {
"third_light": {},
"forth_light": {}
"this": {
"state": "on",
"attributes": {
"last_triggered": "2023-09-20T03:53:15.064071+00:00",
"mode": "restart",
"current": 0,
"last_updated": "2023-09-20T03:53:15.078459+00:00",
"context": {
"user_id": null
"trigger": {
"id": "0",
"idx": "0",
"alias": null,
"event": {
"data": {
"endpoint_id": 1,
"cluster_id": 5,
"args": [
41098,
0
"params": {
"group_id": 41098,
"scene_id": 0,
"origin": "LOCAL",
"time_fired": "2023-09-20T03:53:25.747620+00:00",
"context": {
"id": "01HARBH9FK3E6NJH9SBQKZ65HT",
"parent_id": null,
"user_id": null
"action/0": [
"path": "action/0",
"timestamp": "2023-09-20T03:53:25.752028+00:00",
"context": {
"id": "01HARBH9FMZTVGGE51FSZ9MMY3",
"parent_id": "01HARBH9FK3E6NJH9SBQKZ65HT",
"user_id": null
"action/1": [
"path": "action/1",
"timestamp": "2023-09-20T03:53:25.753849+00:00",
"args": [
41098,
0
"params": {
"group_id": 41098,
"scene_id": 0,
"step_size": "",
"step_mode": "",
"scene": ""
"timestamp": "2023-09-20T03:53:25.754005+00:00",
"result": {
"result": false
"timestamp": "2023-09-20T03:53:25.754131+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-09-20T03:53:25.754359+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-09-20T03:53:25.754573+00:00",
"result": {
"result": false
"timestamp": "2023-09-20T03:53:25.754634+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-09-20T03:53:25.754797+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-09-20T03:53:25.754965+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-09-20T03:53:25.757091+00:00",
"result": {
"result": false
"timestamp": "2023-09-20T03:53:25.757207+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-09-20T03:53:25.757404+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-09-20T03:53:25.757587+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-09-20T03:53:25.757797+00:00",
"result": {
"result": false
"timestamp": "2023-09-20T03:53:25.757859+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-09-20T03:53:25.758030+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-09-20T03:53:25.758262+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-09-20T03:53:25.758472+00:00",
"result": {
"result": false
"timestamp": "2023-09-20T03:53:25.758533+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-09-20T03:53:25.758734+00:00",
"result": {
"result": false
"timestamp": "2023-09-20T03:53:25.758793+00:00",
"result": {
"result": false,
"entities": []
"config": {
"mode": "restart",
"variables": {
"first_light": {
"second_light": {
"third_light": {},
"forth_light": {},
"dim_scale": 1,
"lights": {
"first_light": {
"second_light": {
"third_light": {},
"forth_light": {}
"trigger": [
"event_data": {
"action": [
"variables": {
"choose": [
"conditions": [
"{{ scene == 1 }}"
"sequence": [
"target": {
"choose": [
"sequence": [
"target": {
"data": {
"conditions": [
"{{ scene == 0 }}"
"sequence": [
"target": {
"choose": [
"sequence": [
"target": {
"data": {
"conditions": [
"{{ scene == 5 }}"
"sequence": [
"target": {}
"choose": [
"sequence": [
"target": {
"data": {
"conditions": [
"{{ scene == 4 }}"
"sequence": [
"target": {}
"choose": [
"sequence": [
"target": {
"data": {
"conditions": [
"sequence": [
"choose": [
"sequence": [
"data": {
"transition": 1
"default": [
"target": {
"data": {
"transition": 1
"conditions": [
"sequence": [
"choose": [
"sequence": [
"data": {
"transition": 1
"default": [
"target": {
"data": {
"transition": 1
"description": ""
"description": "",
"use_blueprint": {
"input": {
"first_light": {
"second_light": {
"context": {
"user_id": null
"logbookEntries": [
"context_id": "01HARBH9FMZTVGGE51FSZ9MMY3",
"when": 1695182005.748556,
I believe to have exactly the same problem, I also get the message ‘no action taken’.
From what I can see from the trace all variables should be properly set but nevertheless the choose condition is not met.
Below trace is when pressing button 1, but same result is seen for buttons 2-4.
I also see that the helper variable is not being modified, so as expected turning the dial is also not working.
"trace": {
"run_id": "abe09787e8dd9e365aff458e976211ed",
"state": "stopped",
"timestamp": {
"start": "2023-10-01T09:19:20.295416+00:00",
"finish": "2023-10-01T09:19:20.301566+00:00"
"item_id": "1696148088968",
"trace": {
"trigger/0": [
"timestamp": "2023-10-01T09:19:20.295573+00:00",
"first_light": {
"device_id": [
"5f060a410832bf3af7562ccdcb26b5a7"
"second_light": {
"device_id": [
"74fd0951ffbd8e02c09f5be4e2f5292a",
"74a5cc07bec449d9fcfc5fb698a16808"
"third_light": {
"device_id": [
"9a98dcfb6cdd3f9995bda49a9c0ebf97",
"a47aefe3f13c2de9e5d61c724d909082",
"3ae8023c6febb4c1082271db7cd552a2",
"d3216819df162ff2fb92f6bee3c014b6"
"forth_light": {
"device_id": "9a9917ab64097cc85e3c5bb8ba2e5e1d"
"current_light": "input_text.philips_tap_dial_switch_last_device",
"dim_scale": 1,
"lights": {
"first_light": {
"device_id": [
"second_light": {
"device_id": [
"third_light": {
"device_id": [
"forth_light": {
"this": {
"state": "on",
"attributes": {
"id": "1696148088968",
"last_triggered": "2023-10-01T09:17:27.694501+00:00",
"mode": "restart",
"current": 0,
"last_changed": "2023-10-01T09:01:01.770508+00:00",
"last_updated": "2023-10-01T09:17:27.698722+00:00",
"context": {
"id": "01HBN8EGRED56PEA0ZY3M0YMFE",
"parent_id": "01HBN8EGRD4NDGB43EPFXX67E8",
"user_id": null
"trigger": {
"id": "0",
"idx": "0",
"alias": null,
"event": {
"data": {
"device_ieee": "00:17:88:01:0d:7d:e2:2b",
"unique_id": "00:17:88:01:0d:7d:e2:2b:1:0x0005",
"device_id": "8b65d910ca9dcfe43b06b1cf9c797815",
"endpoint_id": 1,
"cluster_id": 5,
"args": [
61427,
1
"params": {
"group_id": 61427,
"scene_id": 1,
"origin": "LOCAL",
"time_fired": "2023-10-01T09:19:20.295078+00:00",
"context": {
"id": "01HBN8HYQ7VEJ1YHF3XEGCMMP3",
"parent_id": null,
"user_id": null
"action/0": [
"path": "action/0",
"timestamp": "2023-10-01T09:19:20.297534+00:00",
"context": {
"id": "01HBN8HYQ7QVAQH6THRQJ6KJNM",
"parent_id": "01HBN8HYQ7VEJ1YHF3XEGCMMP3",
"user_id": null
"action/1": [
"path": "action/1",
"timestamp": "2023-10-01T09:19:20.298481+00:00",
"args": [
61427,
1
"params": {
"group_id": 61427,
"scene_id": 1,
"step_size": "",
"step_mode": "",
"scene": ""
"timestamp": "2023-10-01T09:19:20.298597+00:00",
"result": {
"result": false
"timestamp": "2023-10-01T09:19:20.298654+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-10-01T09:19:20.298786+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-10-01T09:19:20.298933+00:00",
"result": {
"result": false
"timestamp": "2023-10-01T09:19:20.298975+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-10-01T09:19:20.299083+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-10-01T09:19:20.299195+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-10-01T09:19:20.299333+00:00",
"result": {
"result": false
"timestamp": "2023-10-01T09:19:20.299390+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-10-01T09:19:20.299500+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-10-01T09:19:20.299608+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-10-01T09:19:20.299740+00:00",
"result": {
"result": false
"timestamp": "2023-10-01T09:19:20.299780+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-10-01T09:19:20.299882+00:00",
"result": {
"result": true,
"entities": []
"timestamp": "2023-10-01T09:19:20.299987+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-10-01T09:19:20.300119+00:00",
"result": {
"result": false
"timestamp": "2023-10-01T09:19:20.300159+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-10-01T09:19:20.300289+00:00",
"result": {
"result": false
"timestamp": "2023-10-01T09:19:20.300329+00:00",
"result": {
"result": false,
"entities": []
"config": {
"mode": "restart",
"variables": {
"first_light": {
"device_id": [
"second_light": {
"device_id": [
"third_light": {
"device_id": [
"forth_light": {
"dim_scale": 1,
"lights": {
"first_light": {
"device_id": [
"second_light": {
"device_id": [
"third_light": {
"device_id": [
"forth_light": {
"trigger": [
"event_data": {
"action": [
"variables": {
"choose": [
"conditions": [
"{{ scene == 1 }}"
"sequence": [
"target": {
"device_id": [
"choose": [
"sequence": [
"target": {
"entity_id": "input_text.philips_tap_dial_switch_last_device"
"data": {
"conditions": [
"{{ scene == 0 }}"
"sequence": [
"target": {
"device_id": [
"choose": [
"sequence": [
"target": {
"data": {
"conditions": [
"{{ scene == 5 }}"
"sequence": [
"target": {
"device_id": [
"choose": [
"sequence": [
"target": {
"data": {
"conditions": [
"{{ scene == 4 }}"
"sequence": [
"target": {
"choose": [
"sequence": [
"target": {
"data": {
"conditions": [
"sequence": [
"choose": [
"sequence": [
"data": {
"transition": 1
"default": [
"target": {
"device_id": [
"data": {
"transition": 1
"conditions": [
"sequence": [
"choose": [
"sequence": [
"data": {
"transition": 1
"default": [
"target": {
"device_id": [
"data": {
"transition": 1
"description": ""
"description": "",
"use_blueprint": {
"input": {
"remote": "8b65d910ca9dcfe43b06b1cf9c797815",
"first_light": {
"device_id": [
"second_light": {
"device_id": [
"third_light": {
"device_id": [
"forth_light": {
"context": {
"user_id": null
"logbookEntries": [
"context_id": "01HBN8HYQ7QVAQH6THRQJ6KJNM",
"when": 1696151960.295689,
Thanks Ray.
@apollo1220, if you have the opportunity to take a look, that would be much appreciated.
Did you manage to get this working? I switched from ZHA to Z2M but this one is really bugging me.
I already start looking at the blueprint code, but I am not yet on that level to make such blueprints unfortunately.
Nope. I hope Ray is able to take a look.
Ok, dug a bit deeper today.
Proved to be super duper simple to fix. The incoming parameter that defines which button is pressed is called scene_id
while in the blueprint it is presumed to be called scene
Not sure what is the root cause, maybe HA renamed this parameter?
Anyway, I have submitted a PR to the blueprint with this fix.
It was scene when I wrote the blueprint and scene does still work for me. Possibly a firmware update from Philips changed it (I haven’t ever updated the firmware on my dial).
Please help, doesn’t work anymore after new HA installation.
I moved to a new house and so installed a fresh new HA installation. I managed to reset and include the Hue tap dial again (took some time). And it is available in HA. I can press identify and the orange led starts blinking.
So I added this blueprint, choose the tap dial as device and configured a device to control. But nothing happens, I tried a device, an entity, but nothing.
Why o why?
UPDATE: I did a reconfigure, got some errors, but now the tap is working… weird.
For those interested in a Zigbee2MQTT version. I have made one, but I tweaked it to my specific preference I had when I was using this one in ZHA.
I only use three buttons and it controls 3 different lights. I have configured the 4th button just to turn off the last selected light. Yes, with Z2M we can use double press or long press but I am a simple person and I am happy with this :).
Also, Z2M doesn’t know the concept of ‘step_size’, but does now the actions step, slow and fast. I have covered this as separate conditions and applied a dimscale * 2 (slow) and * 5 (fast).
blueprint:
name: Zigbee2MQTT - Hue Tap Dail Dimmer
description: 'Control lights with a Philips Hue Tap Switch. Use the four buttons
to control up to four light(s) with an on/off toggle. The dial can be used to
dim the most recently used light.'
domain: automation
input:
button_sensor:
name: Philips Hue Tap dial switch sensor entity
description: Sensor for Philips Hue Tap dial switch to use (Use sensor with
entity_id ends with _action)
selector:
entity:
domain:
- sensor
multiple: false
remote_button_1_single_press:
name: Button 1 Single Press
description: The light(s) to control with first button
selector:
entity:
domain: light
remote_button_2_single_press:
name: Button 2 Single Press
description: The light(s) to control with second button
selector:
entity:
domain: light
remote_button_3_single_press:
name: Button 3 Single Press
description: The light(s) to control with third button
selector:
entity:
domain: light
current_button:
name: (OPTIONAL) Current Light
description: Text helper to track the current light to dim. Set for the dimmer
controls to change which light they are controlling according to the last
one turned on.
default:
selector:
entity:
domain:
- input_text
multiple: false
dim_scale:
description: Scale factor for the dimming. This value will be multiplied by
the value given from the dial. So lower number, more gradual dimming. Larger
number, faster dimming.
default: 1.0
selector:
number:
min: 0.0
max: 5.0
step: 0.01
mode: slider
mode: restart
max_exceeded: silent
variables:
remote_button_1_single_press: !input remote_button_1_single_press
remote_button_2_single_press: !input remote_button_2_single_press
remote_button_3_single_press: !input remote_button_3_single_press
current_button: !input current_button
dim_scale: !input dim_scale
lights:
- platform: state
entity_id: !input button_sensor
to: button_1_press
- platform: state
to: button_2_press
- platform: state
to: button_3_press
- platform: state
to: button_4_press
- platform: state
to: dial_rotate_left_step
- platform: state
to: dial_rotate_left_slow
- platform: state
to: dial_rotate_left_fast
- platform: state
to: dial_rotate_right_step
- platform: state
to: dial_rotate_right_slow
- platform: state
to: dial_rotate_right_fast
- variables:
action: '{{ trigger.to_state.state }}'
- choose:
- conditions: '{{ action == ''button_1_press'' }}'
sequence:
- service: light.turn_on
target: !input remote_button_1_single_press
brightness: 50
- choose:
- conditions: '{{ current_button != none }}'
sequence:
- service: input_text.set_value
entity_id: !input current_button
value: remote_button_1_single_press
- conditions: '{{ action == ''button_2_press'' }}'
sequence:
target: !input remote_button_2_single_press
brightness: 50
- choose:
sequence:
value: remote_button_2_single_press
- conditions: '{{ action == ''button_3_press'' }}'
sequence:
target: !input remote_button_3_single_press
brightness: 50
- choose:
sequence:
value: remote_button_3_single_press
- conditions: '{{ action == ''button_4_press'' }}'
sequence:
- service: homeassistant.turn_off
target: '{{ lights[states(current_button)] }}'
- conditions:
- '{{ action == ''dial_rotate_left_step'' }}'
sequence:
- choose:
sequence:
brightness_step_pct: '{{ -dim_scale }}'
transition: 1
default:
transition: 1
- conditions:
- '{{ action == ''dial_rotate_right_step'' }}'
sequence:
- choose:
sequence:
brightness_step_pct: '{{ dim_scale }}'
transition: 1
default:
transition: 1
- conditions:
- '{{ action == ''dial_rotate_left_slow'' }}'
sequence:
- choose:
sequence:
brightness_step_pct: '{{ -dim_scale * 2 }}'
transition: 1
default:
transition: 1
- conditions:
- '{{ action == ''dial_rotate_right_slow'' }}'
sequence:
- choose:
sequence:
brightness_step_pct: '{{ dim_scale * 2 }}'
transition: 1
default:
transition: 1
- conditions:
- '{{ action == ''dial_rotate_left_fast'' }}'
sequence:
- choose:
sequence:
brightness_step_pct: '{{ -dim_scale * 5 }}'
transition: 1
default:
transition: 1
- conditions:
- '{{ action == ''dial_rotate_right_fast'' }}'
sequence:
- choose:
sequence:
brightness_step_pct: '{{ dim_scale * 5 }}'
transition: 1
default:
transition: 1
For those who had hard time like me to pair/add the device:
https://www.zigbee2mqtt.io/devices/8719514440937_8719514440999.html
This website explains how to add a new or previously added Tap Dial Switch.
Hi everyone. Nice work apolllo1220, thanks.
I am new to HA and want to get rid of my hue bridge step by step. Is there a solution for the long press button id solution, at least at the horizon? Maybe via quirk. I am a lttle bit overwhelmed by all.
Obviously the data is there but simply not used by zha. Is’t there away to make it usable?
[0xF417:1:0xfc00] Unknown cluster command 0 b'\x01\x00\x000\x00!\x00\x00' -> press
[0xF417:1:0xfc00] Unknown cluster command 0 b'\x01\x00\x000\x02!\x02\x00' -> press_release
[0xF417:1:0xfc00] Unknown cluster command 0 b'\x01\x00\x000\x01!\x10\x00' -> hold
[0xF417:1:0xfc00] Unknown cluster command 0 b'\x01\x00\x000\x03!\x19\x00' -> hold_release
The pattern is \button***\command\miliseconds_hex*
It’s there, but I can’t get my hands on it.
No way that I know of without ZHA supporting it
thanks for this.
For me the following part is not working
- If the light is off, a click will turn it on at 50%.
I found that brightness should be between 0 and 255, but the light does not turn on, when its off, no matter which value is set for brightness.
seems like this part never gets triggered.
the light only turns on if I turn the dial.
Am I missing something?
- choose:
- conditions: '{{ states(first_light.entity_id) == ''off'' }}'
sequence:
target: '{{ first_light }}'
transition: 1
brightness: 50
I appear to be having the same problem with the helper not being set, but neither the current yaml nor the historic one are working. If I go into the helper object and manually change the text, I can get the dial to work. But the button presses aren’t changing it. I can’t figure out how to read the trace. Any help would be appreciated.
"trace": {
"last_step": "action/1/choose/4/sequence/0/choose/0/sequence/0",
"run_id": "9386dfac07d537d85177dc60d905dd4f",
"state": "stopped",
"script_execution": "error",
"timestamp": {
"start": "2023-12-06T03:05:25.992786+00:00",
"finish": "2023-12-06T03:05:25.995879+00:00"
"item_id": "1701831914819",
"error": "must contain at least one of entity_id, device_id, area_id.",
"trace": {
"trigger/0": [
"timestamp": "2023-12-06T03:05:25.992805+00:00",
"first_light": {
"area_id": "kitchen",
"device_id": "364c5a8cc06bb175f72f43d02c0e5af8"
"second_light": {
"area_id": "living_room",
"device_id": "04cc334202bb4cd4bcb50f480ea1057b"
"third_light": {},
"forth_light": {},
"current_light": "input_text.test_helper",
"dim_scale": 1,
"lights": {
"first_light": {
"second_light": {
"third_light": {},
"forth_light": {}
"this": {
"state": "on",
"attributes": {
"id": "1701831914819",
"last_triggered": "2023-12-06T03:05:25.491451+00:00",
"mode": "restart",
"current": 0,
"last_changed": "2023-12-06T03:05:17.182950+00:00",
"last_updated": "2023-12-06T03:05:25.493969+00:00",
"context": {
"id": "01HGYHCQQKP96WD4KTGEDY0V3D",
"parent_id": "01HGYHCQQKFN87WGVT5AB24QJA",
"user_id": null
"trigger": {
"id": "0",
"idx": "0",
"alias": null,
"event": {
"data": {
"device_ieee": "00:17:88:01:0d:7c:a3:1b",
"unique_id": "00:17:88:01:0d:7c:a3:1b:1:0x0008",
"device_id": "2f0bfdda30b9055cbfc5a08d9a9f69d1",
"endpoint_id": 1,
"cluster_id": 8,
"command": "step_with_on_off",
"args": [
0,
255,
6
"params": {
"step_mode": 0,
"step_size": 255,
"transition_time": 6
"origin": "LOCAL",
"time_fired": "2023-12-06T03:05:25.992690+00:00",
"context": {
"id": "01HGYHCR788RXYTZT68Q4WKFN0",
"parent_id": null,
"user_id": null
"action/0": [
"path": "action/0",
"timestamp": "2023-12-06T03:05:25.993527+00:00",
"context": {
"id": "01HGYHCR78D54ZFTZ388JS8D73",
"parent_id": "01HGYHCR788RXYTZT68Q4WKFN0",
"user_id": null
"action/1": [
"path": "action/1",
"timestamp": "2023-12-06T03:05:25.994063+00:00",
"args": "[<StepMode.Up: 0>, 255, 6]",
"params": "{'step_mode': <StepMode.Up: 0>, 'step_size': 255, 'transition_time': 6}",
"step_size": 255,
"step_mode": "StepMode.Up",
"scene": ""
"result": {
"choice": 4
"timestamp": "2023-12-06T03:05:25.994089+00:00",
"result": {
"result": false
"timestamp": "2023-12-06T03:05:25.994098+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-12-06T03:05:25.994136+00:00",
"result": {
"result": false
"timestamp": "2023-12-06T03:05:25.994145+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-12-06T03:05:25.994171+00:00",
"result": {
"result": false
"timestamp": "2023-12-06T03:05:25.994179+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-12-06T03:05:25.994205+00:00",
"result": {
"result": false
"timestamp": "2023-12-06T03:05:25.994211+00:00",
"result": {
"result": false,
"entities": []
"timestamp": "2023-12-06T03:05:25.994236+00:00",
"result": {
"result": true
"timestamp": "2023-12-06T03:05:25.994242+00:00",
"result": {
"result": true,
"entities": []
"action/1/choose/4/conditions/1": [
"path": "action/1/choose/4/conditions/1",
"timestamp": "2023-12-06T03:05:25.994264+00:00",
"result": {
"result": true,
"entities": []
"action/1/choose/4/sequence/0": [
"path": "action/1/choose/4/sequence/0",
"timestamp": "2023-12-06T03:05:25.994405+00:00",
"result": {
"choice": 0
"action/1/choose/4/sequence/0/choose/0": [
"path": "action/1/choose/4/sequence/0/choose/0",
"timestamp": "2023-12-06T03:05:25.994422+00:00",
"result": {
"result": true
"action/1/choose/4/sequence/0/choose/0/conditions/0": [
"path": "action/1/choose/4/sequence/0/choose/0/conditions/0",
"timestamp": "2023-12-06T03:05:25.994434+00:00",
"result": {
"result": true,
"entities": []
"action/1/choose/4/sequence/0/choose/0/sequence/0": [
"path": "action/1/choose/4/sequence/0/choose/0/sequence/0",
"timestamp": "2023-12-06T03:05:25.994526+00:00",
"result": {
"params": {
"domain": "light",
"service": "turn_on",
"service_data": {
"brightness_step_pct": 255,
"transition": 1
"target": {}
"running_script": false
"config": {
"mode": "restart",
"variables": {
"first_light": {
"second_light": {
"third_light": {},
"forth_light": {},
"dim_scale": 1,
"lights": {
"first_light": {
"second_light": {
"third_light": {},
"forth_light": {}
"trigger": [
"event_data": {
"action": [
"variables": {
"scene": "{% if (trigger.event.data.params is defined) and (trigger.event.data.params.scene_id is defined) %}{{trigger.event.data.params.scene_id}}{% endif %}"
"choose": [
"conditions": [
"{{ scene == 1 }}"
"sequence": [
"target": {
"choose": [
"sequence": [
"target": {
"entity_id": "input_text.test_helper"
"data": {
"conditions": [
"{{ scene == 0 }}"
"sequence": [
"target": {
"choose": [
"sequence": [
"target": {
"data": {
"conditions": [
"{{ scene == 5 }}"
"sequence": [
"target": {}
"choose": [
"sequence": [
"target": {
"data": {
"conditions": [
"{{ scene == 4 }}"
"sequence": [
"target": {}
"choose": [
"sequence": [
"target": {
"data": {
"conditions": [
"sequence": [
"choose": [
"sequence": [
"data": {
"transition": 1
"default": [
"target": {
"data": {
"transition": 1
"conditions": [
"sequence": [
"choose": [
"sequence": [
"data": {
"transition": 1
"default": [
"target": {
"data": {
"transition": 1
"description": ""
"description": "",
"use_blueprint": {
"input": {
"remote": "2f0bfdda30b9055cbfc5a08d9a9f69d1",
"first_light": {
"second_light": {
"context": {
"user_id": null
"logbookEntries": [
"context_id": "01HGYHCR78D54ZFTZ388JS8D73",
"when": 1701831925.992838,
You didn’t by any chance did create an automation with all 4 buttons used for lights? Besides this your automation is exactly what I’m looking for as I can’t use this one since I’m running Z2M
Thanks!
