Recently I realized I may have broken my own rule to never make anything in my home depended on a smart device by installing the Philips Hue Wall-modules behind most of my light-switches. These are of course depended on the Hub. And while the Hub itself is not depended on the Internet to work if the Hub ever breaks…
I was curious what would be a good course of action here. What others would recommend doing here:
Getting a second ‘backup hub’ you can just plugin when the other one dies late at night?
Can you however in someway ‘copy’ or export the settings to this? -
Any way to depended on the Bluetooth functionality as a backup
Remove the Wall-modules but somehow keep their functionality as is.
I will say we are quite used to the physical switches working and controlling the lights. Mostly in combination with motion sensors. Walk into a room the lights go on, but using a physical switch to turn it off when you leave, not having lights burn for another 5 to 10 minutes. And the advantage of the Hue module is that it actually controls the bulb. Not like some solutions the power to and from the light. -
another other good ideas? (aside from getting a good flashlight? )
