Philips Wiz (not Hue) Bulbs: how can we advocate for an API
Actually, if I wasn’t allergic to Java and looked at the openhab binding more I would have noticed the author apparently did reverse engineer all the local commands:
He posted in Ability to control Philips/Wiz Connected WIFI Smart LED lights? a few days ago.
Anyway, I modified [wilvancleve]'s nodeRed flow a bit to just ignore the command passed in the topic so I can send the full params object and use the MQTT template schema to configure the light. For now I think I’ll just do template lights using the smartthings entities I already have setup for these bulbs for state, I mostly wanted the faster response time on the commands. (light.template apparently doesn’t support RGB :()
        "id": "3bfa4c0a.55a6e4",
        "type": "tab",
        "label": "MQTT to Wiz",
        "disabled": false,
        "info": ""
        "id": "f8e03d02.b904a",
        "type": "json",
        "z": "3bfa4c0a.55a6e4",
        "name": "",
        "property": "payload",
        "action": "",
        "pretty": false,
        "x": 310,
        "y": 340,
        "wires": [
                "5b5538a.6f768c8"
        "id": "39ef9bf6.b126f4",
        "type": "comment",
        "name": "Relay MQTT to UDP",
        "info": "",
        "x": 170,
        "y": 260,
        "wires": []
        "id": "5b5538a.6f768c8",
        "type": "function",
        "name": "relay to udp",
        "func": "// expects the mqtt topic to be wizlight/ip/command\n\nvar command = msg.topic.split(\"/\")[2];\n\nmsg.ip = msg.topic.split(\"/\")[1];\n\nvar obj = {}; \nobj = msg.payload;\n            \nvar p = {};\n\nvar pl = {method:\"setPilot\", \n          id:527, \n          env:\"pro\", \n          params : obj};\n\nmsg.payload =  pl\n\nmsg.port = 38899\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 490,
        "y": 340,
        "wires": [
                "eb39d4e7.006d18"
        "id": "62afb6be.881218",
        "type": "mqtt in",
        "name": "Wizlight In",
        "topic": "wizlight/#",
        "qos": "0",
        "datatype": "auto",
        "broker": "",
        "x": 160,
        "y": 340,
        "wires": [
                "f8e03d02.b904a"
        "id": "fae3fd3b.f7733",
        "type": "udp out",
        "name": "UDP auto port/ip",
        "addr": "",
        "iface": "",
        "port": "",
        "ipv": "udp4",
        "outport": "38899",
        "base64": false,
        "multicast": "false",
        "x": 1070,
        "y": 200,
        "wires": []
        "id": "eb39d4e7.006d18",
        "type": "json",
        "name": "",
        "action": "",
        "pretty": false,
        "x": 690,
        "y": 340,
        "wires": [
                "6840d6e1.111ea8"
        "id": "f345a1c5.4bbbf",
        "type": "repeat",
        "name": "Triple It Up",
        "repetitions": "3",
        "elseOutput": false,
        "outputs": 1,
        "x": 810,
        "y": 200,
        "wires": [
                "fae3fd3b.f7733",
                "eb39d4e7.006d18"
        "id": "6840d6e1.111ea8",
        "type": "delay",
        "name": "",
        "pauseType": "delay",
        "timeout": "25",
        "timeoutUnits": "milliseconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "x": 870,
        "y": 340,
        "wires": [
                "f345a1c5.4bbbf"
light:
  - platform: mqtt
    schema: template
    command_topic: "wizlight/ip_address/set"
    command_on_template: >
      {"state": true
      {%- if brightness is defined -%}
      ,"dimming": {{ (brightness/254*100)| int }}
      {%- endif -%}
      {%- if red is defined and green is defined and blue is defined -%}
      ,"r":{{ red }},"g":{{ green }},"b":{{ blue }}
      {%- endif -%}
      {%- if color_temp is defined -%}
      ,"temp":{{ (1000000/color_temp)| int}}
      {%- endif -%}
      {%- if white_value is defined -%}
      ,"w":{{ white_value }}
      {%- endif -%}
    command_off_template: '{"state":false}'
#note these are just populated to get the MQTT platform to enable the relevant supported_features, not currently reading state from the bulb
    brightness_template: '{{ value_json.dimming }}'
    red_template: '{{ value_json.r }}'
    green_template: '{{ value_json.g }}'
    blue_template: '{{ value_json.b }}'
    color_temp_template: '{{ value_json.temp }}'
    white_value_template: '{{ value_json.w }}'
