cool! i am not using hass.io, just have to detirmine how to use it in HA
Hello Pantomax, very new to this Hassio system but im begining to like it, but as a noob Iâm having problems with testing json service call in developer module. Basically I would like to trigger a sound when temperature of sensor reaches a certain level but being a noob and an old git canât get this to work. Is it possible to use the call service and test json format. If itâs possible could you give us an example please?
Hey @OldGitHub,
actually I donât really know how to answer to your question, Iâm not even a coder, so my knowledge level is very low. Maybe⌠something like:
"addon" : "de3cd379_audio_player",
"input" : "http://192.168.1.100:8123/local/sound_when_temperature_of_sensor_reaches_a_certain_level.mp3"
Hello again @PantomaxâŚyou sir are a legend, brilliant, I made the error of missing âinputâ, which was why I kept getting errors in the logâŚDoh! this is great, after pulling out what hair I had left, I can now wire the house up with sensors and speakers, the only down-fall is Iâm probably gonna get an ear bashing from TheOldGirl when a trigger sounds an alert. This home automation stuff is brillâŚthanks again for your quick reply
Glad that I could help.
Happy automating over there, let your home sound like the USS Enterprise computer
@Pantomax ciao, volevo chiedereti di aggiungerti al mio gruppo facebook per creare una comunitĂ di supporto italiana di HA, visto il poco materiale reperibile nella nostra lingua, ciao e grazie
Ciao @Domo, in realtà non ho nessun profilo Facebook, magari piÚ avanti me ne faccio uno. Se ti può interessare sto scrivendo un piccolo tutorial su Linkedin:
magari a qualcuno può servire
Max
perfetto, grazie, se non dispiace condivido sul gruppo.
Inoltre ti volevo chiedere maggiori informazioni riguardo lâaudio dal jack, ho seguito le tue istruzioni e dal log risulta che la musica e in esecuzione ma dalla cassa non esce alcun suono,
questo e il log che ricevo: riesci ad aiutarmi a capire come mai non funziona?grazie
Certo, condividi pure. Prova con lâindirizzo di Radio Rai ( http://icestreaming.rai.it/1.mp3 ) che sono sicuro sia compatibile con il player utilizzato. Sei sicuro che il jack funzioni? Hai mai sentito altri suoni uscire da lĂŹ? Se nemmeno quello funziona ne riparliamo
Funzionaaa, il problema era che prima di provare la tua guida,avevo fatto delle prove e avevo collegato l HDMI di raspberry alla TV, cosi ho letto un antro post dove un utente aveva il mio stesso problema e staccando HDMI e riavviando il PI e partito lâaudio dal jack alla cassa. funziona sia con mopidy che con audio_player, pero vedo che non funziona il TTS, conosci qualche soluzione?
(Per quanto riguarda il tts lo scrivo in inglese, magari può far comodo anche ad altri.)
So, if you guys want to use the TTS on this player, I made a little workaround. I hope it will work correctly also on your system.
First of all you need to make a directory called tts inside the /config/www/ directory and set this dir as the google tts cache, like this:
tts:
- platform: google
cache: true
cache_dir: /config/www/tts
Now, you have to set these three elements:
- a fake media player
media_player:
- platform: universal
- a command used to clean the directory after every usage
shell_command:
remove_old_mp3_files: rm /config/www/tts/*.mp3
- a sensor used to sense when Google TTS writes the TTS mp3 in my directory
- platform: command_line
command: "ls /config/www/tts/ -1t | head -1"
scan_interval: 5
I will call this script to generate the mp3 file:
script:
hassio_talk:
alias: Hassio talk script
sequence:
- alias: Hassio Talk
service: tts.google_say
entity_id: media_player.hassio
data_template:
message: >
'{{ message }}'
language: en
cache: True
and this automation will play the file as soon as the mp3 file will be transferred on the hassio (donât forget to replace the IP address of your RPi):
automation:
- alias: "Read TTS"
- platform: state
entity_id: sensor.last_tts
- service: hassio.addon_stdin
data_template:
addon: de3cd379_audio_player
input: "http://192.168.1.100:8123/local/tts/{{ states('sensor.last_tts') }}"
- delay: '00:00:05'
- service: tts.clear_cache
so, if you want to call the script, just use this service:
- service: script.hassio_talk
message: "Hello world!"
for example when the hassio starts:
- alias: "TTS message at start"
- platform: homeassistant
event: start
- service: shell_command.remove_old_mp3_files
message: "Server on line"
If you are not using hass.io, just install VLC media player component. It can play local MP3 and TTS.
Before that, you need to run thisâŚ
sudo apt-get install vlc-nox
Hey there @masterkenobi, thank you for the hint.
Do you have any idea on how to set the volume level on Hassio?
@Pantomax volevo chiederti se hai idea di come poter installare un microfono per usare i comandi vocali sul RPi con Hass.io, sul web non ho trovato risposte.
Is there a way to choose between the audio jack or have the raspi transmit the signal via Bluetooth, allowing cable free connection to my Bluetooth speaker.
I had a question, if you wouldnât mind answering
I tried to install the addon locally but Iâm getting this error.
starting version 3.2.4
/usr/bin/entry.sh: /run.sh: /bin/bash^M: bad interpreter: No such file or directory
/usr/bin/entry.sh: line 9: /run.sh: No error information
do you know what is causing it?
ARG BUILD_FROM
FROM $BUILD_FROM
# Add env
ENV LANG C.UTF-8
# Setup base, install sox package
RUN apk add --no-cache jq sox
# Copy data
COPY run.sh /
RUN chmod a+x /run.sh
CMD [ "/run.sh" ]
"name": "Audio Player",
"version": "1.55",
"slug": "audio_player",
"description": "Play audio files",
"startup": "before",
"boot": "auto",
"stdin": true,
"audio": true,
"hassio_api": true,
"options": {},
"schema": {},
"host_network": true
#!/bin/bash
set -e
echo "starting!"
# Read from STDIN aliases to play file
while read -r input; do
# removing JSON stuff
input="$(echo "$input" | jq --raw-output '.')"
echo "[Info] Read alias: $input"
if ! msg="$(play $input)"; then
echo "[Error] Playing failed -> $msg"
fi
done
Iâm still trying to learn all this stuff.
Thanks very much!
After i test this in the developer tools > services in the log i get this message, any idea why?
[Info] Read alias: http://192.168.1.13:8123/local/alarm.mp3
ALSA lib conf.c:1876:(snd_config_load1) toplevel:1:2:Unexpected char
ALSA lib conf.c:5017:(snd_config_expand) Parse arguments error: Invalid argument
ALSA lib pcm.c:2501:(snd_pcm_open_noupdate) Unknown PCM hw:{0,0}
Great Addon-on, thank you.
Is there a way to set the volume?
