@raoul.teeuwen here is the right documentation https://home-assistant.io/components/switch.command_line/ for that switch
Thank you. I have the following section in my configuration.yaml:
switch:
switches:
pihole:
value_template: '{{ states.sensor.pihole_status.state }}'
turn_on:
service: script.turn_on
entity_id: script.pihole_on
turn_off:
entity_id: script.pihole_off
- platform: command-line
switches:
pihole_switch:
command_on: "curl -X GET 'http://192.168.1.134/admin/api.php?enable&auth=5f81246fe0ccfc7ec7c67c010fb4d28c9510590c0bb778551abbee56936e0948'"
command_off: "curl -X GET 'http://192.168.1.134/admin/api.php?disable=3600&auth=5f81246fe0ccfc7ec7c67c010fb4d28c9510590c0bb778551abbee56936e0948'"
command_state: "curl -X GET 'http://192.168.1.134/admin/api.php?status'"
value_template: "{{ value_json.status == 'enabled' }}"
On compile/check i get “ERROR (MainThread) [homeassistant.loader] Unable to find component switch.command-line”. I don’t know why.
Nice work @rob. Thanks for the idea which I’ve taken as inspiration and expanded upon.
I wanted a little more control over the amount of time that I could disable Pi-Hole for and ended up with the following solution utilising these HA components.
- Shell command
- Command line Sensor
- Scripts
- Input Select
- Group
- Pi-Hole Sensor
- Automation
Input Select
Adds a selection menu of configured options to the HA frontend so you can choose the amount of time to disable Pi-Hole for. Options can be added or removed to suit your requirements.
input_select:
pihole_time:
name: Disable Time (seconds)
options:
- Select Time
- 10
- 30
- 60
- 300
- 600
- 900
- 1800
- 3600
initial: Select Time
Shell Commands
In order to pass a number, in this case the amount of seconds we want to disable Pi-Hole, we’ll need to use the following shell commands.
shell_command:
pihole_enable: curl -X GET 'http://yourpiholeip/admin/api.php?enable&auth=yourauth'
pihole_disable: curl -X GET 'http://yourpiholeip/admin/api.php?disable={{ states.input_select.pihole_time.state }}&auth=yourauth'
Script
Allow the shell command to be triggered in HA via a script.
script:
enable_pihole:
alias: Enable PiHole
sequence:
service: shell_command.pihole_enable
Sensor
Store the current status of the Pi-Hole server in a sensor with a state of either enabled or disabled.
platform: command_line
command: curl -X GET 'http://yourpiholeip/admin/api.php?status'
value_template: >
{{ value_json.status }}
Automations
The below automation will use the selected value from input_select.pihole_time and send that to the Pi-Hole API via the shell command.
automation:
alias: Disable Pi-Hole
platform: state
entity_id: input_select.pihole_time
service: shell_command.pihole_disable
Optional: If you want to reset the value of input_select.pihole_time add the following automation which will reset input select to the initial value Select Time anytime script.enable_pihole is triggered or it detects sensor.pihole_status has changed from disabled to enabled.
alias: Reset PiHole Disable Time
- platform: state
entity_id: script.enable_pihole
- platform: state
entity_id: sensor.pihole_status
to: 'enabled'
service: input_select.select_option
option: Select Time
Group
Finally tie the whole thing together with a group along with the sensors from Pi-Hole.
group:
pihole:
name: Pi Hole Status
entities:
- sensor.pihole_status
- script.enable_pihole
- input_select.pihole_time
- sensor.pihole_ads_blocked_today
- sensor.pihole_ads_percentage_blocked_today
- sensor.pihole_dns_queries_cached
- sensor.pihole_dns_queries_forwarded
- sensor.pihole_dns_queries_today
- sensor.pihole_dns_unique_clients
- sensor.pihole_dns_unique_domains
- sensor.pihole_domains_blocked
End Result
anyone knows how to do this having pihole hassio addon?
yes it works:
pihole_enable: curl -X GET 'http://LOCALIP:PORT/admin/api.php?enable&auth=AUTH'
LOCALIP… Local Ip of your Hassio
PORT: can be set within pi hole addon at --> “admin_port”: XXXX,
AUTH: that was the “tricky” part.
- make a backup of your pihole addon (or complete Hassio Snapshot)
- Download this backup -> tar file
- open the file with 7zip (WINRAR doenst work for me)
- find the following file within “pihole”: setupVars.conf
- open it… here you will find the line WEBPASSWORD. This is your auth hash for the url
Ha! I would have never thought of it. Thanks!
Is your CURL command working from HASSIO?
If I put the below command in a browser it does work, but from within HASS (when I select a time of input_select, the curl is not executed … I guess because of HASSIO?
shell_command:
pihole_enable: curl -X GET 'http://192.168.1.14:4865/admin/api.php?enable&auth=e37142f6ccc319a42f1cf1c5'
pihole_disable: curl -X GET 'http://192.168.1.14:4865/admin/api.php?disable={{ states.input_select.pihole_time.state }}&auth=e37142f6f0a890ecccb2f1d6b24cfc319a42f1cf1c5'
I do not use the input select (just fixed 10 minutes disable time).
Try it without the
and just use a number → 6000 = 10 minutes
pihole_disable: curl -X GET ‘http://192.168.1.14:4865/admin/api.php?disable=**6000**&auth=YOURAUTH’
if this works, something is wrong with your inputs / automations.
You can try the shell command via HASSIO → Services → select: shell_command.pihole_disable → call service
Well service is not working, when I put the URL in a browser is working. Not sure where the problem is
hm, this is my setup:
shell_command:
pihole_enable: curl -X GET 'http://192.168.2.3:4865/admin/api.php?enable&auth=AUTH'
pihole_disable: curl -X GET 'http://192.168.2.3:4865/admin/api.php?disable=600&auth=AUTH'
and then ->
result:
can you find anything in the logs?
You use Hassio?
yes:
what happens if you hit “call service” ?
Hi, nothing really
I can confirm curl works on hassio with HA 0.95.4
But beware of a space character after auth, it just wont work. I apparently copy-pasted it from the pihole webinterface, so beware.
I have the code bellow and i’m having an error i cant solve, can you help?
The error is in the automation:
bad indentation of a mapping entry at line 43, column 18:
entity_id: script.enable_pi_hole
## SCRIPTS
script:
enable_pihole:
sequence:
## SHELL COMMAND
shell_command:
pihole_enable: curl -X GET 'https://1xx.1xx.1.2xx:4865/admin/api.php?enable&auth='
pihole_disable: curl -X GET 'https://1xx.1xx.1.2xx:4865/admin/api.php?disable={{ states.input_select.pihole_time.state }}&auth='
#### AUTOMATIONS
automation:
platform: state
entity_id: input_select.pi_hole_time
- platform: state
- platform: state
entity_id: sensor.pi_hole_status
to: 'enabled'
option: Select Time
Hi @joaopequeno,
The indentation in my example is valid YAML syntax and is still working in my setup. In order to assist you better could you please provide more of your config file to see where the error is stemming from?
The error is when i save the yaml file and it refers to the first entity of the trigger.
Sorry, just read your post again. The error is due to the additional space you have at the start of entity_id. Please see the correct indentation below.
- platform: state
The state trigger for the pi_hole_status entity also needs to look like the below.
- platform: state
to: 'enabled'
Double check my code blocks above to check your config against, ensuring the indentation matches.
Please check bellow the print screen.
I cant get the error out.
Again, this time you need to intent lines 36, 37, 42, 43, 44, 45, 46, 47. Please review my code blocks and ensure the indentation matches to ensure you don’t keep getting these errors.
First thanks for you help, but i’m realy stuck in here.
I have copied your block again, and something is passing me by.
I have the code bellow, and on line 35 column 12 i get:
bad indentation of a mapping entry at line 35, column 12:
automation:
platform: state
- platform: state
- platform: state
to: 'enabled'
option: Select Time
