Pi4b fell down and does not work anymore, restore config from SD
I have only one Pi4b and need to copy the config (hassio) to a Pi3b
How can I copy the config from the SD-Card? from Windows? Linux?
Edit:
Solution:
I used: https://www.diskinternals.com/linux-reader/
and found my configs in: /mnt/data 1/supervisor/homeassistant/
Linux can read the card.
Windows may require software. e.g. https://www.diskinternals.com/linux-reader/
If you have Hassio snapshots they should be able to be used on the replacement pi.
where do i have to serach:
The last 4 are not accessible
/mnt/data 1 I think.
Edit; yes it is. See: Config file on SD card
Thank you so much, I used: Access to Ext 2/3/4, HFS and ReiserFS from Windows | DiskInternals
