You wrote
"For everybody who urgently wants to use the newest release with the pilight hotfix do the following within the homeassistant checkout folder:
Oh really? Didn’t know that.
So will you help me troubleshoot? Can also be on gitter.
I didn’t change anything but since the last (I did skip a few versions) version nothing RF works.
The pilight log file (in var/log) doesn’t show anything useful.
Is there a log elsewhere?
When I start pilight in the normal pi environment and try to run a command I do get an error:
pi@raspberrypi:~ $ sudo service pilight start
pi@raspberrypi:~ $ pilight-send -p kaku_switch -i 1052693 -a -t
[ Jan 08 11:09:27:74633] pilight-send: NOTICE: no pilight ssdp connections found
pi@raspberrypi:~ $
But I’m not sure if I’m testing properly.
Can there be 2 pilight installations on a AIO Hass installation? Like in the normal environment and in the virtual environment?
What you see has nothing to do with any home-assistant pilight related code, but with the pilight c-library installation on your RPI. I would recommend to search the pilight forum. For example this discussion might help.
I have the feeling there are 2 pilight installations. 1 in the normal pi environment and 1 in the virtual home assistant environment.
Do you know how I can access the virtual environment and test pilight from there?
I tried:
Change to homeassistant user: sudo su -s /bin/bash homeassistant
Change to virtual environment: source /srv/homeassistant/homeassistant_venv/bin/activate
But then when I try to restart pilight it asks for a password for hass user. Which doesn’t have a password.
(hass_venv) hass@raspberrypi:/home/pi$ sudo service pilight restart
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for hass:
When I stop pilight in the normal environment with :
pi@raspberrypi:~ $ sudo service pilight stop
then the webgui is still accessible. So I think it normally uses the pilight in the virtual environment…
So how do I access on a command line the virtual environment so that I can restart pilight and run commands?
[EDIT]
Now that I think of it, I don’t think I even use pilight to Send codes.
In my config I have
You mix something up. The virtual environments affects python packages. Pilight is a c-library running as a deamon/service and cannot be effected by virtual environments. Do whereis pilight and you will see where you c-library is.
