Ping 8.8.8.8 connectivity check
Yes, see my answer above.
Alright, I’ve added the code into the configuration.yaml. Thank you.
But it still doesn’t show on the dashboard.
I’ve added the following into a manual card. As said above.
color_thresholds:
  - color: '#e45e65'
    value: 40
  - color: '#e0b400'
    value: 30
  - color: '#0da035'
    value: 20
  - color: '#039BE5'
    value: -1
color_thresholds_transition: hard
entities:
  - entity: binary_sensor.ping
group: false
height: 300
hour24: true
line_width: 4
points_per_hour: 10
show:
  extrema: true
  average: true
  fill: fade
  icon: true
  labels: false
  state: true
type: custom:mini-graph-card
This is not the name of your sensor (in the card):
entities:
Your sensors will be called:
color_thresholds:
  - color: '#e45e65'
    value: 40
  - color: '#e0b400'
    value: 30
  - color: '#0da035'
    value: 20
  - color: '#039BE5'
    value: -1
entities:
  - entity: sensor.wan_ping
  - entity: sensor.lan_ping
group: false
height: 300
hour24: true
line_width: 4
points_per_hour: 10
show:
  extrema: true
  average: true
  fill: fade
  icon: true
  labels: false
  state: true
Also your second template sensor seems to be using the wrong binary sensor. Should be:
  - sensor:
      - name: "LAN Ping"
        icon: "mdi:speedometer"
        unit_of_measurement: "ms"
        state: "{{ state_attr('binary_sensor.default_gateway_ping', 'round_trip_time_avg')|round(2) }}"
Hi Tom,
sorry for posting off tpoic.
Can’t figure out whats wrong with my code …
  - sensor:
      - name: "LAN Ping"
        state: "{{ state_attr('binary_sensor.router_ping', 'round_trip_time_avg')|round(2) }}"
    color_thresholds:
      - color: '#e45e65'
        value: 40
      - color: '#e0b400'
        value: 30
      - color: '#0da035'
        value: 20
      - color: '#039BE5'
        value: -1
    entities:
        group: false
        height: 300
        hour24: true
        line_width: 4
        points_per_hour: 10
        show:
            extrema: true
            average: true
            fill: fade
            icon: true
            labels: false
            state: true
getting the error:
Invalid config for [template]: [color_thresholds] is an invalid option for [template]. Check: template->color_thresholds.
All of this belongs in the card config, not the sensor config.
    color_thresholds:
      - color: '#e45e65'
        value: 40
      - color: '#e0b400'
        value: 30
      - color: '#0da035'
        value: 20
      - color: '#039BE5'
        value: -1
    entities:
        group: false
        height: 300
        hour24: true
        line_width: 4
        points_per_hour: 10
        show:
            extrema: true
            average: true
            fill: fade
            icon: true
            labels: false
            state: true
It all stored in configuration.yaml at the very bottom…
Which is wrong. As I said, this bit goes in a Lovelace card:
    color_thresholds:
      - color: '#e45e65'
        value: 40
      - color: '#e0b400'
        value: 30
      - color: '#0da035'
        value: 20
      - color: '#039BE5'
        value: -1
    entities:
        group: false
        height: 300
        hour24: true
        line_width: 4
        points_per_hour: 10
        show:
            extrema: true
            average: true
            fill: fade
            icon: true
            labels: false
            state: true
Remove it from your ping sensor config.
thanks for information.
i opened the “Raw-Configurationeditor” and paste it at the very bottom, restartet it but still the same style
wan ping
The ping sensor goes in your sensor.yaml file.
The card config goes in a Lovelace card, not the raw view. And not indented that far either.
hey @tom_l
with Lovelacecard you mean the card config itself?
Visual editor is not supported for this configuration:
  • Key ‘color_thresholds’ is not expected or not supported by the visual editor.
  • Key ‘color_thresholds_transition’ is not expected or not supported by the visual editor.
  • Key ‘entities’ is not expected or not supported by the visual editor.
You can still edit your config in YAML.
Do i need something like lovelace.yaml?
No. That is correct. The mini graph card does not have a gui editor. You can edit it in that card YAML window (if you ever need to).
thanks for the answeres :slight_smile :slight_smile:
i think i need to learn more about configuration of cards etc… i stick to the standard view without color tresholds…
edit: was missing the mini-graph-card :slight_smile:
@aruffell
Any chance you can send me over your mini-graph template. Im trying to replicate here and for the life of me, I cant get it changed away from the single line graph.
@Rattlehead
These are my template sensors:
  - sensor:
      - name: "WAN Ping"
        state: "{{ state_attr('binary_sensor.google_dns_ping', 'round_trip_time_avg')|float(0)|round(2)|default(0) }}"
  - sensor:
      - name: "LAN Ping"
        state: "{{ state_attr('binary_sensor.router_ping', 'round_trip_time_avg')|float(0)|round(2)|default(0) }}"
And these are the mini-graphs:
entities:
group: false
height: 320
hour24: true
line_width: 4
points_per_hour: 12
show:
  extrema: true
  average: true
  fill: fade
  icon: true
  labels: false
  state: true
color_thresholds:
  - color: '#e45e65'
    value: 40
  - color: '#e0b400'
    value: 30
  - color: '#0da035'
    value: 20
  - color: '#039BE5'
    value: -1
and
entities:
group: false
height: 320
hour24: true
line_width: 4
points_per_hour: 12
show:
  extrema: true
  average: true
  fill: fade
  icon: true
  labels: false
  state: true
color_thresholds:
  - color: '#e45e65'
    value: 40
  - color: '#e0b400'
    value: 30
  - color: '#0da035'
    value: 20
  - color: '#039BE5'
    value: -1
Is this what you were asking for?
That’s exactly it, thank you very much @aruffell .
I was wracking my brain as the colouring wasn’t working, I couldn’t see the error. Just c&p yours there and boom job done. Appreciate it.
Just to add that as of now, mini-graph-card supports attributes so there is no longer need to create a template sensor to extract the values from the binary sensor - GitHub - kalkih/mini-graph-card: Minimalistic graph card for Home Assistant Lovelace UI
@ariel I experimented with removing the Template Sensors and it seemed to prevent the ping card from updating at all.
Could some provide an update code for Home assistant 2024 how to implement this in a mini-graph-card? The only entity I can find is binary_sensor.8_8_8_8 but this just displays NaN. I am having dropped packets and I am trying to log the data to try and diagnose what is going on.
EDIT: Found the issue. Hadn’t restarted Yaml since I added the sensor.
Is there anyway to track and plot drop packets?
