Hello @Cadish
please, where did you specify or modify to consider another iface in the code?
Just within your config:
- platform: ping_arp
count: 5
scan_interval: 60
iface: eno1
hosts:
host1: 192.168.1.1
host2: 192.168.1.2
Thanks @Cadish, but you are talking and tested it on the ping_arp component
of @JBelinchon, or the ha_ping_arp component of @balrog????
Dear @Cadish, when i try to use ping_arp component in the last version of home assistant, I got the error message:
DEFAULT_SCAN_INTERVAL does not exist!
So I commented on this parameter to not be imported.
The iface option was also not active, so I set
CONF_IFACE = "iface"
vol.Optional (CONF_IFACE, default = ''): cv.string,
and
self._iface = config [CONF_IFACE]
self._parp_cmd = ['arp', '-n', self.ip_address, '-i', self._iface ]
and instead of passing the scan_interval parameter you have
to pass the interval_seconds parameter:
This is the custom component Iām using (I believe itās the one of @rdehuyss)
Tracks devices by sending a ICMP echo request (ping) and query arp table.
For more details about this platform, please refer to the documentation at
https://home-assistant.io/components/device_tracker.ping/
import logging
import subprocess
import sys
import re
from datetime import timedelta
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
from homeassistant.components.device_tracker import (
PLATFORM_SCHEMA)
from homeassistant.components.device_tracker.const import (
CONF_SCAN_INTERVAL, SCAN_INTERVAL, SOURCE_TYPE_ROUTER)
from homeassistant import util
from homeassistant import const
_LOGGER = logging.getLogger(__name__)
CONF_PING_COUNT = 'count'
CONF_IFACE = 'iface'
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Required(const.CONF_HOSTS): {cv.string: cv.string},
vol.Optional(CONF_PING_COUNT, default=1): cv.positive_int,
vol.Optional(CONF_IFACE): cv.string,
class Host:
"""Host object with ping detection."""
def __init__(self, ip_address, dev_id, hass, config):
"""Initialize the Host pinger."""
self.hass = hass
self.ip_address = ip_address
self.dev_id = dev_id
self._count = config[CONF_PING_COUNT]
self._iface = config[CONF_IFACE]
if self._iface:
self._ping_cmd = ['ping', '-I', self._iface, '-n', '-q', '-c1', '-W1', self.ip_address]
self._parp_cmd = ['arp', '-i', self._iface, '-n', self.ip_address]
else:
self._ping_cmd = ['ping', '-n', '-q', '-c1', '-W1', self.ip_address]
self._parp_cmd = ['arp', '-n', self.ip_address]
def ping(self):
"""Send an ICMP echo request and return True if success."""
pinger = subprocess.Popen(self._ping_cmd, stdout=subprocess.PIPE, stderr=subprocess.DEVNULL)
try:
pinger.communicate()
return pinger.returncode == 0
except subprocess.CalledProcessError:
return False
def parp(self):
"""Get the MAC address for a given IP."""
arp = subprocess.Popen(self._parp_cmd, stdout=subprocess.PIPE)
out, _ = arp.communicate()
match = re.search(r'(([0-9A-Fa-f]{1,2}\:){5}[0-9A-Fa-f]{1,2})', str(out))
if match:
return True
return False
def update(self, see):
"""Update device state by sending one or more ping messages."""
failed = 0
while failed < self._count: # check more times if host is unreachable
if self.ping():
see(dev_id=self.dev_id, source_type=SOURCE_TYPE_ROUTER)
_LOGGER.info("Ping OK from %s", self.ip_address)
return True
_LOGGER.info("No response from %s failed=%d", self.ip_address, failed)
if self.parp():
_LOGGER.info("Arp OK from %s", self.ip_address)
return True
_LOGGER.info("No MAC address found")
failed += 1
def setup_scanner(hass, config, see, discovery_info=None):
"""Set up the Host objects and return the update function."""
hosts = [Host(ip, dev_id, hass, config) for (dev_id, ip) in
config[const.CONF_HOSTS].items()]
interval = config.get(CONF_SCAN_INTERVAL, timedelta(seconds=len(hosts) * config[CONF_PING_COUNT]) + SCAN_INTERVAL)
_LOGGER.info("Started ping tracker with interval=%s on hosts: %s", interval, ",".join([host.ip_address for host in hosts]))
def update_interval(now):
"""Update all the hosts on every interval time."""
try:
for host in hosts:
host.update(see)
finally:
hass.helpers.event.track_point_in_utc_time(
update_interval, util.dt.utcnow() + interval)
update_interval(None)
return True
Thanks, i will take a look
Hi, what is now the latest code which I can use for ping+arp function?
- Can somebody give me some example of configā¦
Thank you for answerā¦
Hi Ronald @rdehuyss,
As my housemates and myself are using Android devices and I found the default ping integration not to be reliable, I want to give āyourā version with PING and ARP a try.
I already have a custom_components folder in my config folder. In the custom_components folder I made a subfolder called āping_arpā. Inside are 2 files:
ini.py without any content and device_tracker.py where I copied / paste your code.
Furthermore in configuration.yaml Iāv put:
count: 5
consider_home: 180
iface: eth1
hosts:
name1_ping_arp: 192.168.100.50
name2_ping_arp: 192.168.100.51
When I check my configuration, before I want to restart I get an error:
Configuration invalid:
Platform error sensor.ping_arp - No module named 'custom_components.ping_arp.sensor'
Iām using HA OS core-2021.3.4
Could you please help me on the configuration to get it up and running?
How should work it? Will it create new entities āname1ā and āname2ā and will their state change between āhomeā and ānot_homeā based on the ping/arp result?
Thanks in advance!
remove the configuration for the āplatform:ā and restart HA.
Then add the code for the ping_arp sensor back in.
tight now it is checking the code against things it has previously loaded but the new custom integration isnāt included in that since you never restarted HA after installing it so HA doesnāt know about it yet.
Hi, @finity,
Thanks for your reply,
I followed your instructions. After I removed āplatform:ā from my configuration.yaml, the configuration check passed, with the 2 new files in custom_components/ping_arp folder.
I restarted HA and put back the āplatform:ā in the configuration.yaml.
Checked once more the configuration and it gives the same error:
from the error it seems you put the ping_arp code under the āsensor:ā section of your configuration.yaml?
If so then you need to move it to the ādevice_tracker:ā section.
Thanks, I forgot to put the code under device_tracker.
Could restart HA after a successfull configuration check.
I suspected to have 2 new entities but it seems it doesnāt work like that or the iface: xxx is incorrect.
Iām currently not at home so probably the interface is not correct named.
I have to check the correct name but I guess Iām not able to see that in the HA GUI.
@finity, thanks for your help once more.
I checked the interface in the HA command line and found enp0s3 as ethernet interface:
A strange name but I entered it in the config, restarted HA and had indeed the new entities. Tried by putting my phone in flightmode and⦠it worked. Me happy
I did as instructed. Added the py file to custom_components/ping_arp, rebooted. But if I try to add the config it errors saying the platform ping_arp is unrecognized.
You need a manifest.json file in the directory too now, here is my dummy one:
"domain": "ping_arp",
"name": "Ping ARP",
"documentation": "https://www.example.com",
"dependencies": [],
"codeowners": [],
"requirements": [],
"iot_class": "local_polling",
"version": "0.1.0"
Just for anyone elseās benefit Iāve uploaded my working directory to https://github.com/jamespo/home-assistant
Hi all and @jamespo in particular. Many thanks for sharing your working directory. Could you also please share the lines in your configuration.yaml?
I keep getting the error message Platform error device_tracker.ping_arp - Integration āping_arpā not found, when testing my configuration.
I copied all your documents to the folder: /config/custom_components/ping_arp/
I hope anyone can help as this sounds like an interesting iphone tracker!
device_tracker:
count: 5
scan_interval: 60
iface: eth0
hosts:
7t: 192.168.0.137
iphone: 192.168.0.146
It looks like everything is working well with the installation but I did not get any new device_track
I use this configuration :
device_tracker:
count: 5
scan_interval: 60
iface: eth0
hosts:
test: 192.168.1.113
@jamespo Iāve added your files to custom_components/ping_arp and restarted HA. Then when I add the device tracker to configuration.yaml when I check the configuration in developer tools before restarting I just get the below error:
Configuration Invalid: Platform error device_tracker.ping_arp - Integration 'ping_arp' not found.
configuration.yaml
count: 5
scan_interval: 60
iface: eno1
hosts:
host1: 192.168.1.157
