I’d also like to know if it’s possible to kill the stream.
I’m hoping to use this as a baby monitor, so it’d be ideal if I could turn it on until I want to turn it off!
Edit: figured out a workaround. If you send a new stream, it replaces the old stream. I set the initial stream to play for 2 hours, then send a subsequent stream for 1 second. Effectively kills it on demand.
Love this so much. Thanks for the hard work – it works so well!
larsvb88
(coax)
February 16, 2023, 12:22pm
84
I followed the guide but nothing happens when i send a rest command. im running the pipup app on my google tv dongle.
it shows up as a restful command in Developer service.
when i try to send command in service, it shows sendt.
is there a way to see some log or how to identify the problem?
rohangopal
(Rohan Gopal)
February 16, 2023, 1:24pm
85
Hi, I have the same issue, i have:
installed Pipup on TV
created the services in HA (able to see it on Dev tools, and call the service successfully)
successfully did the “adb shell appops set nl.rogro82.pipup SYSTEM_ALERT_WINDOW allow” to my TV
Did all above but still nothing shows on TV at all i.e. no popup or anything at all after calling service
Any ideas people - I have tried all/various options.
larsvb88
(coax)
February 16, 2023, 5:18pm
86
what is this doing? and how ?
Scroll down to the side loading section…it is explained there.
larsvb88
(coax)
February 16, 2023, 9:09pm
88
ah okay , does that also applies if you have installed it through the play store ?
MRobi
(Mike)
February 16, 2023, 9:43pm
89
You should remove the playstore version and sideload the modified version. This is likely why you have nothing popping up.
I would also recommend this version
Releases · desertblade/PiPup (github.com)
It’s forked from the one linked above to allow for http instead of just https. This makes it much easier to keep the feed local to your network without having to setup dns rewrites at the router level.
larsvb88
(coax)
February 16, 2023, 10:00pm
90
I will definitely try that out , thank you very much
rohangopal
(Rohan Gopal)
February 17, 2023, 12:41pm
91
Hi, I am using the desertblade pipup install - but absolutely nothing shows on TV i.e. no popup, no text, no image … zero (the service call is successful from HA, but nothing happens on TV … I have no clue why sigh
mhoogenbosch
(Martijn Hoogenbosch)
February 17, 2023, 12:44pm
92
And did you execute:
as @larsvb88 already asked what was happening when executing. Because this command should allow the pop up.
larsvb88
(coax)
February 17, 2023, 4:05pm
94
It all works now after sideload the apk
only thing I struggle with is to show my cam, but that is because I only have rtsp stream
larsvb88
(coax)
February 18, 2023, 9:25am
95
Anyone in here now how to get the http stream from RTSPtoWEB integration in HA, the add-on works fine and can stream camera, but cannot figure out to get the HTTP stream?
rohangopal
(Rohan Gopal)
February 20, 2023, 4:04pm
96
Like I mentioned, nothing happens on the TV at all (no popup, no message, nothing at all).
But on HA, the service ran successfully (no errors at all)
I added some testing instructions to my write up: PiPup/home_assistant.md at 11c72184338e59ed292ea5bf0e3a2c297af123fc · desertblade/PiPup · GitHub
Start PiPup on your fireTV manually and run the tests. Sometimes it does not start automatically, or you could have a permission issue.
I believe that a if the call is not formatted correctly PipUp just absorbs the it with no feedback.
rohangopal
(Rohan Gopal)
April 17, 2023, 11:59am
98
Thank you @DesertBlade - i don’t have the TV anymore - will buy another soon, and will retest etc.
ThomasFTL
(Thomas)
August 14, 2023, 4:57pm
99
I’m having trouble viewing images.
The test under Developer Tools → Services works and the image is displayed.
service: rest_command.pipup_image_on_tv
details:
ip: 192.168.1.203
title: PiPup
message: Notifications are working!
url: https://mir-s3-cdn-cf.behance.net/project_modules/max_1200/cfcc3137009463.5731d08bd66a1.png
But in Node Red the image doesn’t show up.
“ip”:“IP-TV”,
“duration”:10,
“title”:“Titel”,
“message”:“Text.”,
“width”:460,
“height”:500,
“media”:{
“image”:{
“uri”:“https://mir-s3-cdn-cf.behance.net/project_modules/max_1200/cfcc3137009463.5731d08bd66a1.png ”
Title and text are displayed.
When I use pipup_url_on_tv in Node Red, it shows a white rectangle instead of the image.
I was also surprised that I had to write url and not uri in the test under Services.
Thanks for every tip
Thomas
@dsm150 I am about to reproduce your rest_command - do you set it in the configuration.yaml?
Is there a way to test before saving and restarting my HA each time?
If you visit the Developer Tools section of HA and scroll down you can find rest entities as something you can refresh without a restart.
If you try it let us know if it works!
Finally, got it working and displaying the stream on the TV correctly. Thanks.
