Platform Legacy Error - Google Maps
I just started looking at how to install hass.io, but I’ll look into the component store.
You would need python 3.7 installed on your Windows machine and then you can follow https://mapscookiegettercli.readthedocs.io/en/latest/installation.html to install and https://mapscookiegettercli.readthedocs.io/en/latest/usage.html to use it.
Hi @dennyreiter Thank you for taking the effort to get this solved. I installed your custom component but get this error:
locationsharinglib.locationsharinglibexceptions.InvalidUser: /config/.google_maps_location_sharing.cookies.track_xxx_xx
I am using Gsuite so have my own domain. Should this work too? I created the loocation_sharing.cookies twice without different results.
I use mine with Gsuite, so it does work. Are you renaming the cookie with a slugified email address?
Yes I did rename it. From the error message I get it does find the file but can not find the user. Will try again this evening.
Found it, I was still running hass.io 95.4 which uses the older locationsharinglib. After update it works as expected. Keep up the good work :slight_smile:
Hi all
I’m trying to install mapscookiegettercli via pip3 on a LinuxMint environment
But I get this error during the installation process
ERROR: Command errored out with exit status 1:
 command: /usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-4rhaj3lu/mapscookiegettercli/setup.py'"'"'; __file__='"'"'/tmp/pip-install-4rhaj3lu/mapscookiegettercli/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base pip-egg-info
     cwd: /tmp/pip-install-4rhaj3lu/mapscookiegettercli/
Complete output (3 lines):
  File "<string>", line 1, in <module>
ImportError: No module named 'setuptools
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
What can I check?
