Platform:time automation triggered too late
I got the Amazon echo dot speaking HA notifications, a Sonoff Panel display my entities, but I can’t get a simple automation triggered in time. :frowning:
Running out of ideas here …
The automation below scheduled for a specific time gets triggered about 20 mins late. Anyone seen this before and knows how to solve this?
Trace:
Triggered by the time at 10. Oktober 2022 um 07:22:39
Test if any of 2 conditions matches
Benachrichtigung: Send a notification via alexa_media_stefans_echo_dot
Finished at 10. Oktober 2022 um 07:22:39 (runtime: 0.03 seconds)
Automation:
alias: "Kind: Morgens um 7 aus dem Haus"
description: ""
  - platform: time
    at: "07:00:00"
  - condition: or
    conditions:
      - condition: state
        entity_id: sensor.dayoftheweek
        state: Monday
      - condition: state
        state: Friday
  - service: notify.alexa_media_stefans_echo_dot
      message: >-
        Hey ... es ist 7 Uhr. Es wird langsam Zeit, wenn Du den Bus
        erwischen möchtest...
        type: tts
As you can see from the trace, the automation gets executed and I can hear the message. Just way too late…
This is a relatively common occurence with a couple different types of VM software. If you are using a VM, you will need to check that the system time of you VM is correct, check the setup of your machine’s NTP server connection, or disable paravirtualization…
VirtualBox system time is correct, NTP server up and running, but disabling paravirtualization did the job.
Thanks a lot! :slight_smile:
