Play mpd playlists,podcasts and internet radio with out AI V0.5
Oke I build a even better database system with levenshtein function.
And if the function does not find it a spotify api search takes place. The result is stored for offline use.
After a podcast is ended the music plays again. (but that is part of my grand yet to document and in progress snapcast system)
the only thing of the change is that the python script does not run on HA so i have a ssh connection to a linux server. I use a unique ssh key for the command.
added php scripts to get a latest podcast is also a remote system.
alias: speaker slaapkamer voice
description: ""
  - platform: conversation
    command:
      - speaker[s] [s]la[a]pkamer speel[t] {artist}
      - Spiekerslaapkamer speel[t] {artist}
      - Speaker's loudcomers speel[t] {artist}
      - Spiekenslapkamer speel[t] {artist}
      - Speaker's slaapkamer speel[t] {artist}
      - Speaker slotkamer speel[t] {artist}
      - Speaker's Laapkamer speel[t] {artist}
      - Spieken slapkamer speel[t] {artist}
      - Spiekers slaapkamer speel[t] {artist}
      - " Speaker's Laadkamer speel[t] {artist}"
      - Speaker slaaptamer speel[t] {artist}
      - Spieken [s]la[a]pkamer speel[t] {artist}
      - Spieke[r][s] Slauwkamer speel[t] {artist}
condition: []
  - service: input_text.set_value
    metadata: {}
      value: "{{trigger.slots.artist }}"
      entity_id: input_text.mpd_playlist
  - service: shell_command.mpd_playlist
    metadata: {}
    data: {}
    response_variable: result
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ (result.stdout|from_json).sort== \"playlist\" }}"
            metadata: {}
              media_content_type: "{{(result.stdout|from_json).type }}"
              media_content_id: "{{ (result.stdout|from_json).source }} "
              entity_id: media_player.bedroom_speaker
          - service: media_player.select_source
            metadata: {}
              source: mpd_bedroom
              entity_id: media_player.vision_snapcast_client
          - service: media_player.volume_mute
              entity_id: media_player.speaker_slaapkamer
              is_volume_muted: false
      - conditions:
            value_template: "{{ (result.stdout|from_json).sort == \"podcast\" }}"
            metadata: {}
              value: "{{ state_attr('media_player.vision_snapcast_client','source') }}"
              entity_id: input_text.pod_bedroom
            metadata: {}
              media_content_id: "{{ (result.stdout|from_json).source }}"
              entity_id: media_player.bedroom_speaker_pod
            metadata: {}
              source: mpd_bedroom_pod
configuration.yaml
shell_command:
   mpd_playlist:  /config/bin/mpd_search.sh '{{ states('input_text.mpd_playlist') }}'
#!/bin/bash
echo "$@" | ssh -i /config/ssh/id_rsa_mpdir user@linux -T
ON the linux box
.ssh/authorized_keys (use ssh-copy-id)
command="./bin/mpd_search.py \"$(cat)\"",restrict ssh-ed25519 AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA root@123456-ssh
daft@doorman:
#!/usr/bin/python3
mport MySQLdb
import json
import sys
import base64
import requests
# Replace with your own Spotify API credentials
client_id = ''
client_secret = ''
def search_artist(query):
    access_token = get_access_token(client_id, client_secret)
    if access_token:
        search_url = 'https://api.spotify.com/v1/search'
        params = {
            'q': query,
            'type': 'artist'
        headers = {
            'Authorization': 'Bearer ' + access_token
        response = requests.get(search_url, params=params, headers=headers)
        data = response.json()
        if 'artists' in data and 'items' in data['artists'] and data['artists']['items']:
            return data['artists']['items'][0]
    return None
def get_access_token(client_id, client_secret):
    token_url = 'https://accounts.spotify.com/api/token'
    headers = {
        'Authorization': 'Basic ' + base64.b64encode((client_id + ':' + client_secret).encode()).decode()
    payload = {
        'grant_type': 'client_credentials'
    response = requests.post(token_url, headers=headers, data=payload)
    return data.get('access_token')
def lookup_artist(search):
    conn = MySQLdb.connect(
        host="localhost",
        user="karin",
        password="BTy!KagQKwc2Orek",
        database="ha_music"
    # Create a cursor
    artist = search_artist(search)
    cursor = conn.cursor()
    query = "SELECT `p`.`name`, `p`.`playlist`, `t`.`type`, `p`.`id` \
             FROM playlists AS p \
             JOIN `ha_music`.`type` AS t ON p.type = t.id \
             JOIN `playlist_weblookup` AS w ON p.id = w.playlist_id \
             WHERE `w`.`web_lookup` = %s"
    cursor.execute(query, (str(artist['name']),))
    result = cursor.fetchone()
    if result:
        query_add = "INSERT INTO playlist_alias (`playlist_id`, `alias`) VALUES (%s,%s)"
        cursor.execute(query_add, (result[3],str(search),))
        conn.commit()
        cursor.close()
        conn.close()
        return json.dumps({"sort": "playlist", "source": result[1], "type": result[2]})
    else:
        return False
def find_playlist(artist_name):
    # Connect to MySQL database
        host="localhost",
        user="karin",
        database="ha_music"
    # Create a cursor
    # Query to find the playlist for the given artist name
#    playlist_query = (
#        "SELECT * FROM `playlist_view` WHERE `name` LIKE %s LIMIT 1"
    playlist_query = (
        "SELECT * , levenshtein( %s,`name`) as levenshtein FROM `playlist_view` WHERE levenshtein( %s,`name`) BETWEEN 0 AND 1 ORDER BY levenshtein LIMIT 1"
    cursor.execute(playlist_query, (artist_name,artist_name,))
#    cursor.execute(playlist_query, (artist_name ,artist_name',))
    playlist_result = cursor.fetchone()
    # If playlist is found, return JSON
    if playlist_result:
        cursor.close()
        conn.close()
        return json.dumps({"sort": "playlist", "source": playlist_result[1], "type": playlist_result[2]})
    # Query to find the podcast for the given artist name
    podcast_query = (
        "SELECT *, levenshtein( %s,`name`) as levenshtein  FROM `podcast_view` WHERE levenshtein( %s,`name`) BETWEEN 0 AND 1 ORDER BY levenshtein LIMIT 1"
#    podcast_query = (
#        "SELECT * FROM `podcast_view` WHERE `name` LIKE %s LIMIT 1"
    cursor.execute(podcast_query, (artist_name,artist_name,))
    podcast_result = cursor.fetchone()
    # Close cursor and connection
    cursor.close()
    conn.close()
    # If podcast is found, return JSON
    if podcast_result:
        return json.dumps({"sort": "podcast", "source": podcast_result[1], "type": podcast_result[2]})
    lookup = lookup_artist(artist_name)
    if lookup:
        return lookup
    else:
        return None
if __name__ == "__main__":
#    if len(sys.argv) != 2:
#        print("Usage: {} <artist_name>".format(sys.argv[0]))
#        sys.exit(1)
    artist_name = ' '.join(sys.argv[1:])
    if not artist_name:
        sys.exit(1)
    json_result = find_playlist(artist_name)
    if json_result:
        print(json_result)
    else:
        print("Playlist or podcast not found for artist:", artist_name)
SQL
-- phpMyAdmin SQL Dump
-- version 5.2.1deb1
-- https://www.phpmyadmin.net/
-- Host: localhost:3306
-- Gegenereerd op: 19 feb 2024 om 15:26
-- Serverversie: 10.11.6-MariaDB-0+deb12u1
-- PHP-versie: 8.2.7
SET SQL_MODE = "NO_AUTO_VALUE_ON_ZERO";
START TRANSACTION;
SET time_zone = "+00:00";
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
/*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
/*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
/*!40101 SET NAMES utf8mb4 */;
-- Database: `ha_music`
-- Tabelstructuur voor tabel `playlists`
CREATE TABLE `playlists` (
  `id` int(10) UNSIGNED NOT NULL,
  `name` varchar(50) NOT NULL,
  `playlist` varchar(100) NOT NULL,
  `type` int(11) NOT NULL DEFAULT 1
) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_general_ci;
-- Tabelstructuur voor tabel `playlist_alias`
CREATE TABLE `playlist_alias` (
  `playlist_id` int(11) NOT NULL,
  `alias` varchar(50) NOT NULL
-- Tabelstructuur voor tabel `podcasts`
CREATE TABLE `podcasts` (
  `name` varchar(100) NOT NULL,
  `url` varchar(300) NOT NULL,
  `type` int(10) UNSIGNED NOT NULL
-- Tabelstructuur voor tabel `podcast_alias`
CREATE TABLE `podcast_alias` (
  `podcast_id` int(11) UNSIGNED NOT NULL,
  `alias` varchar(100) NOT NULL
-- Tabelstructuur voor tabel `type`
CREATE TABLE `type` (
  `type` varchar(30) NOT NULL
-- Gegevens worden geƫxporteerd voor tabel `type`
INSERT INTO `type` (`id`, `type`) VALUES
(1, 'music'),
(2, 'playlist');
CREATE  VIEW `playlist_view`  AS SELECT `p`.`name` AS `name`, `p`.`playlist` AS `playlist`, `t`.`type` AS `type` FROM (`playlists` `p` join `type` `t` on(`p`.`type` = `t`.`id`))union select `a`.`alias` AS `name`,`p`.`playlist` AS `playlist`,`t`.`type` AS `type` from ((`playlist_alias` `a` join `playlists` `p` on(`p`.`id` = `a`.`playlist_id`)) join `type` `t` on(`p`.`type` = `t`.`id`))  ;
CREATE  VIEW `podcast_view`  AS SELECT `p`.`name` AS `name`, `p`.`url` AS `url`, `t`.`type` AS `type` FROM (`podcasts` `p` join `type` `t` on(`p`.`type` = `t`.`id`))union select `a`.`alias` AS `name`,`p`.`url` AS `url`,`t`.`type` AS `type` from ((`podcast_alias` `a` join `podcasts` `p` on(`p`.`id` = `a`.`podcast_id`)) join `type` `t` on(`p`.`type` = `t`.`id`))  ;
-- Indexen voor geƫxporteerde tabellen
-- Indexen voor tabel `playlists`
ALTER TABLE `playlists`
  ADD PRIMARY KEY (`id`);
-- Indexen voor tabel `playlist_alias`
ALTER TABLE `playlist_alias`
-- Indexen voor tabel `podcasts`
ALTER TABLE `podcasts`
-- Indexen voor tabel `podcast_alias`
ALTER TABLE `podcast_alias`
-- Indexen voor tabel `type`
ALTER TABLE `type`
-- AUTO_INCREMENT voor geƫxporteerde tabellen
-- AUTO_INCREMENT voor een tabel `playlists`
  MODIFY `id` int(10) UNSIGNED NOT NULL AUTO_INCREMENT,;
-- AUTO_INCREMENT voor een tabel `playlist_alias`
  MODIFY `id` int(10) UNSIGNED NOT NULL AUTO_INCREMENT;
-- AUTO_INCREMENT voor een tabel `podcasts`
-- AUTO_INCREMENT voor een tabel `podcast_alias`
-- AUTO_INCREMENT voor een tabel `type`
ALTER TABLE `type`
COMMIT;
/*!40101 SET CHARACTER_SET_CLIENT=@OLD_CHARACTER_SET_CLIENT */;
/*!40101 SET CHARACTER_SET_RESULTS=@OLD_CHARACTER_SET_RESULTS */;
/*!40101 SET COLLATION_CONNECTION=@OLD_COLLATION_CONNECTION */;
DELIMITER $
CREATE FUNCTION levenshtein( s1 VARCHAR(255), s2 VARCHAR(255) )
    RETURNS INT
    DETERMINISTIC
    BEGIN
        DECLARE s1_len, s2_len, i, j, c, c_temp, cost INT;
        DECLARE s1_char CHAR;
        -- max strlen=255
        DECLARE cv0, cv1 VARBINARY(256);
        SET s1_len = CHAR_LENGTH(s1), s2_len = CHAR_LENGTH(s2), cv1 = 0x00, j = 1, i = 1, c = 0;
        IF s1 = s2 THEN
            RETURN 0;
        ELSEIF s1_len = 0 THEN
            RETURN s2_len;
        ELSEIF s2_len = 0 THEN
            RETURN s1_len;
        ELSE
            WHILE j <= s2_len DO
                SET cv1 = CONCAT(cv1, UNHEX(HEX(j))), j = j + 1;
            END WHILE;
            WHILE i <= s1_len DO
                SET s1_char = SUBSTRING(s1, i, 1), c = i, cv0 = UNHEX(HEX(i)), j = 1;
                    SET c = c + 1;
                    IF s1_char = SUBSTRING(s2, j, 1) THEN
                        SET cost = 0; ELSE SET cost = 1;
                    END IF;
                    SET c_temp = CONV(HEX(SUBSTRING(cv1, j, 1)), 16, 10) + cost;
                    IF c > c_temp THEN SET c = c_temp; END IF;
                    SET c_temp = CONV(HEX(SUBSTRING(cv1, j+1, 1)), 16, 10) + 1;
                    IF c > c_temp THEN
                        SET c = c_temp;
                    END IF;
                    SET cv0 = CONCAT(cv0, UNHEX(HEX(c))), j = j + 1;
                END WHILE;
                SET cv1 = cv0, i = i + 1;
            END WHILE;
        END IF;
        RETURN c;
    END$
DELIMITER ;
php code to get the lastest episode of a podcast
  GNU nano 7.2                                                    latenightlinux.php
<?php
$xmlurl = "https://latenightlinux.com/feed/mp3";
$xml = simplexml_load_file($xmlurl);
if (@$_GET['info']) {
$title = $xml->channel->item[0]->title;
$timestamp = $xml->channel->item[0]->pubDate;
$date = DateTime::createFromFormat('D, d M Y H:i:s O', $timestamp);
// Get the current date and time
$now = new DateTime();
// Calculate the difference in days
$interval = $now->diff($date);
$daysAgo = $interval->format('%a');
echo "$title $daysAgo dagen geleden";
die();
$url = $xml->channel->item[0]->enclosure['url'][0];
header("Location: $url");
v0.0001 post
I saw a great example to use voice assistant with music assistant with AI support. But i want to keep everything local so i made my own with out AI.
It uses a chatgtp generated bash script that greps the list of playlists (artists in my system) from a txt file and gives back the best result.
so that you can give a partial name or a name with typos.
#!/bin/bash
# Check if the argument is provided
if [ $# -eq 0 ]; then
    echo "Usage: $0 <search_query>"
    exit 1
fi
# Read the list of artists from the file
artists_file="/config/artists.txt"
# Function to find matching artist names
find_artist() {
    local query="$1"
    # Convert query to lowercase for case-insensitive matching
    query_lower=$(echo "$query" | tr '[:upper:]' '[:lower:]')
    # Iterate over the list of artists
    while IFS= read -r artist; do
        # Convert artist name to lowercase for case-insensitive matching
        artist_lower=$(echo "$artist" | tr '[:upper:]' '[:lower:]')
        # Check if the query is a substring of the artist name
        if [[ "$artist_lower" == *"$query_lower"* ]]; then
            echo "$artist"
            return 0
        fi
    done < "$artists_file"
    # If no match found, return non-zero exit status
    return 1
# Call the function with the provided argument
if find_artist "$1"; then
    exit 0
else
    echo "No matching artist found."
    exit 1
fi
description: ""
    command:
      - speaker slaapkamer speel {artist}
      - Spiekerslaapkamer speel {artist}
      - Speaker slaapkamers speel {artist}
      - Speaker's loudcomers speel {artist}
      - Spiekenslapkamer speel {artist}
      - Speaker's slaapkamer speel {artist}
      - Speaker slotkamer speel {artist}
      - Speaker's Laapkamer speel {artist}
      - Spieken slapkamer speel {artist}
      - Speaker slaapkamer speelt {artist}
condition: []
    metadata: {}
    metadata: {}
    data: {}
    metadata: {}
      media_content_type: playlist
      media_content_id: mpddir_{{result.stdout}}
    metadata: {}
      source: mpd_bedroom
Still work in progress.
I can now detect rooms
Easyer command working for every room.
while one assistant is active.
    sensors:
      active_room:
        friendly_name: "Active Room"
        value_template: >
          {% set sleep_sensor = states('binary_sensor.m5stack_atom_echo_241ec0_assistent_bezig_met_verwerken') %}
          {% set study_sensor = states('binary_sensor.192_168_5_8_call_in_progress') %}
          {% set living_sensor = states('binary_sensor.192_168_5_50_call_in_progress') %}
          {% set blue_mage = states('binary_sensor.blue_mage_assistent_bezig_met_verwerken') %}
          {% if sleep_sensor == 'on' and study_sensor == 'off' and living_sensor == 'off' and blue_mage == 'off'  %}
            Slaapkamer
          {% elif sleep_sensor == 'off' and study_sensor == 'off' and living_sensor == 'on' and blue_mage == 'off'%}
            Woonkamer
          {% elif sleep_sensor == 'off' and study_sensor == 'on' and living_sensor == 'off'and blue_mage == 'off' %}
            Studeerkamer
          {% elif sleep_sensor == 'off' and study_sensor == 'off' and living_sensor == 'off' and blue_mage == 'on'%}
            Blue_mage
          {% elif sleep_sensor == 'off' and study_sensor == 'off' and living_sensor == 'off' and blue_mage == 'off'%}
            Glitch
            None
alias: voice speel artist
description: ""
    command:
      - spe[e]l[t]{artist}
      - spil{artist}
condition: []
    metadata: {}
    metadata: {}
    data: {}
  - choose:
      - conditions:
          - condition: state
            entity_id: sensor.active_room
            state: Slaapkamer
          - choose:
              - conditions:
                    metadata: {}
                    metadata: {}
                      source: mpd_bedroom
              - conditions:
                    metadata: {}
                      value: >-
                    metadata: {}
                    metadata: {}
      - conditions:
          - condition: state
            state: Woonkamer
          - choose:
              - conditions:
                    metadata: {}
                      entity_id: media_player.player
                    metadata: {}
                      source: mpd_bedroom
                      entity_id: media_player.kupo_snapcast_client
                      entity_id: media_player.speaker_huiskamer
              - conditions:
                    metadata: {}
                      value: >-
                        state_attr('media_player.kupo_snapcast_client','source')
                      entity_id: input_text.pod_mpd
                    metadata: {}
                      entity_id: media_player.player_pod
                    metadata: {}
                      source: mpd_pod
      - conditions:
          - condition: state
            state: Studeerkamer
          - choose:
              - conditions:
                    metadata: {}
                      entity_id: media_player.study_speaker
                    metadata: {}
                      source: mpd_study
                      entity_id: media_player.squire_snapcast_client
                      entity_id: media_player.speaker_study
              - conditions:
                    metadata: {}
                      value: >-
                        state_attr('media_player.squire_snapcast_client','source')
                      entity_id: input_text.pod_study
                    metadata: {}
                      entity_id: media_player.study_speaker_pod
                    metadata: {}
                      source: mpd_study_pod
      - conditions:
          - condition: state
            state: Blue_mage
          - choose:
              - conditions:
                    metadata: {}
                    metadata: {}
                      source: mpd
              - conditions:
                    metadata: {}
                      value: >-
                    metadata: {}
                    metadata: {}
                      source: mpd_pod
Forgot my android phone
Oke I made a script that looks up partial or error artists into the most popular result using spotify.
I gona make the system learn the partial artist if a result is found.
#!/usr/bin/php
<?php
// Replace with your own Spotify API credentials
$client_id = '7d8e';
$client_secret = '3aa';
function search_artist($query) {
    global $client_id, $client_secret;
    // Get the access token using client credentials flow
    $token = get_access_token($client_id, $client_secret);
    if ($token) {
        // Prepare the search query
        $search_url = 'https://api.spotify.com/v1/search';
        $params = array(
            'q' => $query,
            'type' => 'artist'
        $headers = array(
            'Authorization: Bearer ' . $token
        // Make the search request
        $ch = curl_init();
        curl_setopt($ch, CURLOPT_URL, $search_url . '?' . http_build_query($params));
        curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
        curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
        $response = curl_exec($ch);
        curl_close($ch);
        // Parse the response
        $data = json_decode($response, true);
        if (isset($data['artists']['items']) && !empty($data['artists']['items'])) {
            // Assuming the first result is the artist we want
            return $data['artists']['items'][0];
    return null;
function get_access_token($client_id, $client_secret) {
    $ch = curl_init();
    curl_setopt($ch, CURLOPT_URL, 'https://accounts.spotify.com/api/token');
    curl_setopt($ch, CURLOPT_POST, true);
    curl_setopt($ch, CURLOPT_POSTFIELDS, 'grant_type=client_credentials');
    curl_setopt($ch, CURLOPT_HTTPHEADER, array(
        'Authorization: Basic ' . base64_encode($client_id . ':' . $client_secret)
    curl_close($ch);
    return isset($data['access_token']) ? $data['access_token'] : null;
// Main execution starts here
if (count($argv) < 2) {
    echo "Usage: php search.php <artist_name>\n";
    exit(1);
$query = implode(' ', array_slice($argv, 1));
$artist = search_artist($query);
if ($artist) {
    echo $artist['name'] . "\n";
} else {
    echo "No artist found for the query: " . $query . "\n";
Well there is a bug in music assistant with local music. To bad
Oke switched to english for better reconision.
I wrote added the spotify lookup to my mpd script. It looks up a spotify artist if no local match is made and if the local artist exist the spoken match is added to the alias db so that it also works for that match if the internet is down.
Multi room setup goes pretty well.
Hi @Daft
If I understand correctly, from the widget you are using VLC as a player on your android smartphone, right?
Yes part of my undocumentated music system.
I sent a ident to tasker that gets a playlist from home assistant to vlc.
OK, but does it also work when you are away from home?
Yup. Mpd playlists, radio and podcasts
I always hope that some kind soul will sooner or later make the Home assistant companion app a media player. It would solve a myriad of problems.
However, you’re doing a good job! :+1:
https://www.youtube.com/shorts/KciUksVwlHw teaser.
See
m3u8, mpd, mp4, mov, webm
playlist m3u
