I have a camera with motion detection. I have it at the entrance to the room. I want it to turn on the light when it detects motion, and then turn off the light when there is no motion for a minute.
I found this example in another post, people seemed happy with it, said it worked well. I modified to suit, and it does turn ON the light, but after I leave the room, it doesn’t turn it off.
As far as the boolean, I’m not pretending to understand why, but I modified the automation in a post and the explanation was:
It requires that you create input_boolean.gym_patio_lights to serve as an indicator (to keep track of who turned on the light, namely you or the automation).
My understanding is that if you want a light or switch (or anything else Home Assistant can control) to turn off automatically, but only if it was turned on with an automation, you need to use the boolean.
Tell us more about this camera-based motion sensor. For example, after you leave the room, how much time must pass before the motion sensor’s state changes from on to off. You can observe its state in Developer Tools > States.
Seems like you now have a perfect reason to learn how to use it.
I use a timer to turn off a light after 10 minutes. This might be a better option. My yaml looks like this.
You first need to create the timer - Settings - Devices - Helpers, then refer to the timer as below, One automation switches on the light and starts the timer, the other switches off the light after 10 minutes.
- id: downtoiletmove001
alias: Turn on Down Toilet when motion detected
- platform: state
entity_id: binary_sensor.sonoff_1_motion_occupancy
to: 'on'
- service: timer.start
duration: '0'
entity_id: timer.light_down_hall_toilet
- service: switch.turn_on
entity_id: switch.sonoff_t4_down_toilet
- id: downtoiletmove002
alias: Turn off Down Toilet light 10 minutes after last movement
- platform: event
event_type: timer.finished
event_data:
- service: switch.turn_off
If the camera-based motion sensor “does not go to off” it implies it’s permanently on.
If it’s permanently on it can’t be used in a State Trigger.
Yet you stated your automation does succeed to turn on the light which means the automation’s State Trigger did detect an off to on state-change for the motion sensor.
The two statements are contradictory; either the motion sensor is capable of reporting off or it isn’t. Which is it?
I will give it a shot, thanks. Wish I knew why the one I have didn’t work, I know there are a million automations for lights on and off with motion but they all have different twists. Certainly more than one way to do ANYTHING in HA.
Throwing an error, I think I did everything right. First created a timer called timer.office_off_timer, it is enabled. Then typed this, but got errors:
Message malformed: extra keys not allowed @ data['0']
- id: Office Light On and Off by Timer
alias: Turn on office light when motion detected
- platform: state
entity_id: binary_sensor.birch_neolink_1_motion
to: 'on'
duration: '0'
entity_id: timer.office_off_timer
entity_id: light.jasco_products_43080_light
- id: Office Light Off
alias: Turn off office light 10 minutes after last movement
- platform: event
event_data:
