Easiest solution: https://www.aliexpress.com/item/1005007168934730.html
I know it is a year old but thanks for getting me over the hump. I was stuck on the add peripheral stage forever. Here are my steps if someone is using a standard USB power source with pin numbers. Also I will be drawing up a case for the Uni Plus for 3d printing if there isn’t already one in thingiverse.
My steps - this is for running off of a standard 5v usb cable
- To power the Uni cut a usb cable and wire positive to pin 6 and negative to pin 7
- Connect load to be measured positive to pin 3 and negative to pin 7
- All other steps as Jonas stated above
