Please remove
Hi :slight_smile:
First of all, thank you for this blurprint.
maybe you can add a sensor for humidity. so when you are in shower it knows you are in the rum an will not turn off the light :slight_smile:
It would be nice to have an option if a light or light group is triggered manually/locally, then reset the timeout timer. I understand that sometimes motion detectors can be less than perfect, so sometimes I have to hit the light. I also see it as beneficial if there are NO other sensors in the room (motion/media/presence, etc.)
Could be optional and an added feature to integrate under one blueprint.
Nvm. Still posting before I troubleshoot. Should have learned by now.
Adding a request for this.
If occupancy is on for any defined room, and the household changes to not_home and guest input boolean is off, then turn off occupancy input_boolean for that room.
I’ve covered with adding to away script triggered by automation, but would prefer this being a part of the blueprint.
Thanks!
This is a great idea, as a person that spends a lot of their free time on the computer, my computer being in use could be pretty useful data for room occupancy. Maybe you could work IOT link sensors into this?
I believe this is not working on the motion side if presence sensors are additionally used. I am finding that when the bluetooth goes ā€œoffā€, it overrides all of the above including motion + timer.
I will work to improve the blueprint on my side (@gdeboos) with over 1K clicks, do you intend to maintain this further?
There is indeed a bug in the motion timeout logic. You need to change the following variables in the blueprint to make it work:
motion_timeout: '{{ states(''input_number.motion_occupancy_timeout'') | float(10) }}'
motion_last_changed: '{{ states[motion_sensor].last_changed.timestamp() | float(0) }}'
motion_is_timed_out: '{{ (time_now - motion_last_changed) > (motion_timeout * 60) }}'
motion_timeout had no default value and wasn’t converted to seconds for motion_is_timed_out.
I tried fixing this myself with the suggestions you made, but after saving the automation from the blueprint, it does not appear in 'ā€˜automations’.
Stinks, I’d really like to be able to use this, even with motion disabled, and presence detection and a door sensor, its fires off every 20 seconds until it maxes out
I’m trying to use this without media players (as they are optional), and it’s consistently failing with the error ā€œMessage malformed: Missing input media_playersā€. (The media player toggles are also disabled and I’ve tried removing the default media player text as well.)
you need to set it to ā€˜media_player.none’
However, this blueprint seems to be broken, for me. Althoguht its exactly what I needed for room assistant.
Your assist helped and I’ve now got it working on my end and was able to create an Automation. Are you seeing any errors in the logs?
Are you using room assistant? If I use room assistant it makes this automation go berserk and try to turn off on 100 times until HA kills it.
This is newer, and I agree, I am getting updates now with every distance change which is triggering the automation. I’m looking into rate limiting or something. This is crazy!
Edit: Something seems wrong in the triggering of this automation. It is only using the ā€œstateā€ of the entity, not the attributes, so it should NOT be firing when only the distance changes…
This should NOT trigger since the state is staying the same:
  idx: '4'
  platform: state
  entity_id: sensor.xxx_pixel_3a_room_presence
  from_state:
    state: Family Room
    attributes:
      distance: 9.3
      last_updated_at: '2022-04-13T13:02:52.480Z'
      icon: mdi:bluetooth
      friendly_name: xxx Pixel 3a Room Presence
    last_changed: '2022-04-13T13:02:14.795064+00:00'
    last_updated: '2022-04-13T13:02:52.552215+00:00'
    context:
      parent_id: null
      user_id: null
  to_state:
    state: Family Room
    attributes:
      distance: 8.2
      last_updated_at: '2022-04-13T13:03:12.326Z'
      icon: mdi:bluetooth
    last_updated: '2022-04-13T13:03:12.395774+00:00'
    context:
      parent_id: null
      user_id: null
  for: null
  attribute: null
  description: state of sensor.xxx_pixel_3a_room_presence
Ok so what I have discovered (in chatting on discord) is that Automation ā€œStateā€ triggers on attribute changes also: Automation Trigger - Home Assistant
If we don’t want the automation to trigger on an attribute change (distance) we need to, per the docs:
To trigger on all state changes, but not on changed attributes, set at least one of from or to to null .
So what I did is I modified:
  - platform: state
    entity_id: !input presence_entities
to:
  - platform: state
Will see if that works!
I have essentially torn down my room-assistant array sans two devices, the price of Pi’s was just too much and they were needed other places. But if you do get this blueprint working with RA please do report back, as I this automation would be useful.
Hey all, I wanted to let you know that with permissions, I have taken @gdeboos 's great work and ā€œforkedā€ this into my own version.
I’ll create a separate post, but if you want to test it out alongside me, you can import via this link:
Moved to a new thread, please post any updates or questions there:
