That sounds fantastic! I am more than happy to test it, and to help in any meaningful way. Please feel free to summon me for any extent of involvement
FYI, I’ve made some progress on this, but it turns out there are lot of odd edge cases to consider. Not the clean, simple solution I had hoped…
I’ll update if/when I’m able to make it reliable enough to use generally.
@Supertim it might turn out this is because the playMedia
command was missing a param. At first glance it doesn’t appear important but clearly is.
Are you able to test with this branch of plexapi
to see if it fixes your clients? https://github.com/pkkid/python-plexapi/pull/826
@jjlawren that PR decisively fixed the issue on both the Samsung and the LG TVs.
This is really an outstanding solution, thanks so much for digging into it!
Great, thanks for confirming. I’ll try to get it into the release ASAP.
PR submitted: https://github.com/home-assistant/core/pull/56163.
I’ve marked it tentatively for 2021.9.7, but no guarantees.
