Hi, just wonder how I could show bar chart instead of a traditional line graph in ploty graphs?
Tried different approach such as type: bar
but no success at the moment. Any help would be appreciated. Thank you - JJ
Examine the examples, e.g. here: Daily energy consumption using statistics · dbuezas/lovelace-plotly-graph-card · Discussion #131 (github.com)
Thank you so much. Helps somehow.
But still struggling with the lamda function, looks no longer to be support, how could I change them to filter? Tx JJ
lambda: (ys) => ys.slice(0, -1)
- entity: sensor.airco_beneden_hourly
type: bar
texttemplate: '%{y}'
lambda: |-
(ys,xs) => {
const slicedx = xs.slice(-1)
const slicedy = ys.slice(-1)
slicedx[0].setMinutes(0)
return {x:slicedx, y:slicedy};
Best stick to the large post… check here and re-raise if needed
Plotly interactive Graph Card - Share your Projects! / Dashboards & Frontend - Home Assistant Community (home-assistant.io)
