Pluggit ventilation unit ( modbus )
I also only know of this solution here
No, there is nothing else in existence for Pluggit and Home Assistant. Great to hear that Dantherm and Pluggit are mostly the same thing.
Can we do anything to help adapting your integration for Pluggit? You can have me (and most likely neotigger) for real-life, real-device tests. I also happily provide you pcapng packet captures from the Pluggit App and the Pluggit AP310 device, if needed.
If anyone is interested, there is a Pluggit integration here. If something doesn’t work or is missing, please let me know.
Very cool, thanks for your work on it! I will try it out when I have some spare time.
Can you confirm that manually setting TmaxSummer and TminSummer works?
I have never been able to set these 2 particular settings via modbus…
Thank you! :slight_smile:
Hello juskalalie. Yes, that works. If the values ​​are set using HA, they are read correctly in the iFlow software and vice versa.
Just to clarify. Summer means the values ​​apply to summer time and the two values ​​without summer mean winter time.
Hope that helps.
Fantastic news, thank you very much!!
I’ll try to replace my modbus code with your integration when I get some time. :slight_smile:
So I have migrated from manual modbus configuration to your integration, which works really great! Thank you so much for building it!
Do you know if there is a way to force complete manual bypass operation, i.e. disregard Tmin and Tmax values and never open or close the bypass automatically?
The reason is that in my building, the outdoor air (T1) is somehow pre-heated (probably long path from intake to the pluggit unit), so the automatic management of the bypass never makes sense.
Thanks! :slight_smile:
Hello juskalalie
Sorry for the late reply. For better communication, it’s best to open a new issue on GitHub.
No, unfortunately I don’t know. The manual bypass is also protected at 9°C. Maybe it’s just not intended?!
But you can set the duration of the manual bypass to 480 minutes. That’s 8 hours, after all. Together with Home Assistant automations, you might find a good solution.
Or have you tried something else?
