Pollen Sensor for Germany based on DWD (Deutscher Wetter Dienst)
I’m sorry, I didn’t understand that. Could you please be a little more specific. Could not find anything about it … or under HACS can not be installed?!
it’s not in hacs afaik but you can just google it and you will find the install instructions (or just add https://github.com/Mariusthvdb/custom-ui as a custom repsitory in hacs)
The second part means its if (state == '0') return '#5ebf0f' not if (state === '0') return '#5ebf0f'
now that I’m here anyway I can share my (not very elegant but working) way of switching between Pollen for today and tomorrow.
first you have to create a sensor for tomorrow
#Pollenflug sensor Morgen
  sensors:
    pollenflug_ambrosia_morgen:
      friendly_name: "Ambrosia"
      value_template: "{{ state_attr('sensor.pollenflug_ambrosia', 'state_tomorrow') }}"
  sensors:
    pollenflug_beifuss_morgen:
      friendly_name: "Beifuss"
      value_template: "{{ state_attr('sensor.pollenflug_beifuss', 'state_tomorrow') }}"
  sensors:
    pollenflug_birke_morgen:
      friendly_name: "Birke"
      value_template: "{{ state_attr('sensor.pollenflug_birke', 'state_tomorrow') }}"
  sensors:
    pollenflug_erle_morgen:
      friendly_name: "Erle"
      value_template: "{{ state_attr('sensor.pollenflug_erle', 'state_tomorrow') }}"
  sensors:
    pollenflug_esche_morgen:
      friendly_name: "Esche"
      value_template: "{{ state_attr('sensor.pollenflug_esche', 'state_tomorrow') }}"
  sensors:
    pollenflug_graeser_morgen:
      friendly_name: "Gräser"
      value_template: "{{ state_attr('sensor.pollenflug_graeser', 'state_tomorrow') }}"
  sensors:
    pollenflug_hasel_morgen:
      friendly_name: "Hasel"
      value_template: "{{ state_attr('sensor.pollenflug_hasel', 'state_tomorrow') }}"
  sensors:
    pollenflug_roggen_morgen:
      friendly_name: "Roggen"
      value_template: "{{ state_attr('sensor.pollenflug_roggen', 'state_tomorrow') }}"
Now (after a restart obviously) you can add a card like this for switching between today and tomorrow:
type: custom:vertical-stack-in-card
cards:
  - type: custom:slider-button-card
    entity: input_boolean.pollenflug
    slider:
      direction: left-right
      background: solid
      use_state_color: false
      use_percentage_bg_opacity: false
      show_track: false
      toggle_on_click: true
      force_square: false
    show_name: true
    show_state: false
    compact: true
    icon:
      show: true
      tap_action:
        action: toggle
      icon: ''
    action_button:
      mode: custom
      icon: mdi:power
      show: false
      show_spinner: false
      tap_action:
        action: toggle
    card_mod:
      style: |
        :host {
          --slider-color: #333333 !important;
  - type: conditional
    conditions:
      - entity: input_boolean.pollenflug
        state: 'off'
    card:
      cards:
        - type: glance
          title: 'Heute:'
          entities:
            - entity: sensor.pollenflug_ambrosia
            - entity: sensor.pollenflug_beifuss
            - entity: sensor.pollenflug_birke
            - entity: sensor.pollenflug_erle
          show_state: false
          state_color: true
        - type: glance
          entities:
            - entity: sensor.pollenflug_esche
            - entity: sensor.pollenflug_graeser
            - entity: sensor.pollenflug_hasel
            - entity: sensor.pollenflug_roggen
          state_color: true
          show_state: false
  - type: conditional
    conditions:
        state: 'on'
    card:
      cards:
        - type: glance
          title: 'Morgen:'
          entities:
            - entity: sensor.pollenflug_ambrosia_morgen
            - entity: sensor.pollenflug_beifuss_morgen
            - entity: sensor.pollenflug_birke_morgen
            - entity: sensor.pollenflug_erle_morgen
          show_state: false
          state_color: true
        - type: glance
          entities:
            - entity: sensor.pollenflug_esche_morgen
            - entity: sensor.pollenflug_graeser_morgen
            - entity: sensor.pollenflug_hasel_morgen
            - entity: sensor.pollenflug_roggen_morgen
          state_color: true
          show_state: false
needs slider button card installed from hacs and everything prepared like in my previous post
It will then look like this:
1
2
EDIT: oh yeah, and I created an input boolean to switch between today and tomorrow view named input_boolean.pollenflug
or use the swipe-card:
type: custom:swipe-card
parameters:
  spaceBetween: 8
  scrollbar:
    hide: false
    draggable: true
    snapOnRelease: true
cards:
  - type: custom:vertical-stack-in-card
    cards:
      - type: glance
        title: 'Pollenflug heute:'
        entities:
        show_state: false
        state_color: true
      - type: glance
        entities:
        state_color: true
        show_state: false
    cards:
      - type: glance
        title: 'Pollenflug morgen:'
        entities:
        show_state: false
        state_color: true
      - type: glance
        entities:
        state_color: true
        show_state: false
Thanks, everyone in this thread. Now I have a very helpful and visually pleasing info, which pollen is currently killing me and will continue to do so the next day.
I did everything as described, unfortunately I don’t see any icons in the card.
fontawesome, custom-ui and vertical-stack-in-card installed with HACS.
Where is the mistake?
pollen_card
configuration.yaml
did you put the icons in the correct folder?
@MaSt
Don´t know why, but working now. Thank you
